Author Topic: hydrolocked years  (Read 838 times)
Offline joe in calif
hydrolocked years
« on: May 12, 2017, 09:02:35 pm »
i posted about looking at a 99 Concours and was informed about the hydrolock problem. Is there an years of the 1000 Concours that do not have that problem?
Re: hydrolocked years
« Reply #1 on: May 12, 2017, 09:13:58 pm »
Nope...
Every year has the potential, the carbs and petcock are the same on all....
Just understand that the older the bike, the more it may have sat unused... the lack of use is the main cause...
And object in motion tends to stay in motion, or so it seems.... :beerchug:
Offline DC Concours
  • 2001 Concours, ~19K miles
« Reply #2 on: May 12, 2017, 11:27:05 pm »
Don't worry. The fix is easy and fairly inexpensive.
when will you check out the c10 you want to buy?
