Author Topic: I bought it. I have two 99 concours. Broken highway peg?  (Read 1283 times)
Offline The ice man
  • COG#: 12605
« on: March 20, 2019, 04:06:31 am »
 The new connie that I bought has one highway peg on the right side.  The left side is broken off in the fairing bracket.. these highway pegs just go straight out, he cut holes in the fairing for them. The lower fairing bracket is bolted to the engine in two places, he just took out the bolts and screwed in the highway pegs.  The left highway peg broke off  when he crashed. I drilled a hole ,with a left hand drill bit,  and attempted to use a a screw extractor to remove the bolt part of the highway peg. The screw extractor broke off.#.$ !,!..$..&.?.!..#.$.?.. =. . I would like to remove the lower fairing bracket from the bike.  I Think I can remove the fairing bracket even with the broken off highway peg in it..? After the bracket is removed I believe I can remove the bolt with vise grips or a pipe wrench. I would welcome any suggestions?
Offline The ice man
  • COG#: 12605
Re: I bought it. I have two 99 concours. Broken highway peg?
« Reply #1 on: March 20, 2019, 01:27:34 pm »
I asked the previous owner for the broken left side highway peg, but he could not find it.
« Reply #2 on: March 20, 2019, 01:37:47 pm »
Randy sent me pics of the situation.  I'll post them when I get back to my computer later today.  Stay tuned.
2013 Kawasaki Concours 14
« Reply #3 on: March 20, 2019, 02:11:21 pm »
Here ya go.
« Reply #4 on: March 20, 2019, 02:14:53 pm »
Another one
Offline The ice man
  • COG#: 12605
« Reply #5 on: March 20, 2019, 02:15:16 pm »
Harbor freight has motorcycle lift for $89.99 #61632 I can get 20% off with coupon. I don't have a concrete floor to work on, I am outside with dirt floor. I think I could slide the lift under the bike and use it in the dirt to Make it easier to work on the bikes? Maybe?
« Reply #6 on: March 20, 2019, 02:25:36 pm »
Won't work on your bike because of exhaust
« Reply #7 on: March 20, 2019, 02:26:37 pm »
Another one.
« Reply #8 on: March 20, 2019, 02:30:15 pm »
Last one.
Offline The ice man
  • COG#: 12605
« Reply #9 on: March 20, 2019, 03:03:46 pm »
I think would need to remove the radiator to remove the bracket. I don't know if I would have to remove the oil cooler?.?
Offline The ice man
  • COG#: 12605
« Reply #10 on: March 20, 2019, 03:27:11 pm »
I used a 5/32 drill bit and I think a #3 screw extractor. The screw extractor broke off  approximately flush with the end of bolt. I don't think I can remove the broken off screw extractor? Even if I could remove it, I am not sure it would help?
Offline Chuck Landis
  • COG#: 10486
« Reply #11 on: March 20, 2019, 03:51:16 pm »
I'm not sure how to tell you to proceed. But there maybe locktight on those threads. A little heat will make it come out easier. be care with heat around the radiator hose. Good luck.
Chuck
06 Connie
York Pa.
Offline m in sc
    • 2strokeworld.net
  • COG#: 13057
« Reply #12 on: March 20, 2019, 04:54:34 pm »
mig tack weld a nut (through the hole) onto the extractor carefully, then back that whole mess out.
« Reply #13 on: March 20, 2019, 06:22:13 pm »
That was my thought.  I just didn't know if you could weld to the extractor.  I'm guessing that he doesn't have a welder though.  I think the easiest for him is just pull the radiator and remove the bracket.  Time consuming but not hard.  It would give him an opportunity to give the radiator a good cleaning and maybe get a look at things that are hard to see with all of that on.
Offline The ice man
  • COG#: 12605
« Reply #14 on: March 21, 2019, 02:29:34 pm »
 I think I can remove the bracket? Anyone who has removed the radiator,would have a better understanding of if this is possible?  I would like to hear from someone who has removed the radiator?
« Reply #15 on: March 21, 2019, 04:50:38 pm »
I replaced my bracket last year sometime because it was bent.  If you pull the radiator, the bracket will come off.
Offline The ice man
  • COG#: 12605
« Reply #16 on: March 21, 2019, 04:53:31 pm »
I took the radiator off. Tried to remove the bracket. I have to move bracket to right about 1 inch so the bolt will clear the block. I can't do that because the bracket hits the exhaust manifold. I can move the bracket only about 3/8 inch to the right. #$×$+/$=?
« Reply #17 on: March 21, 2019, 05:08:04 pm »
If you're going to replace the bracket, cut the bracket so it will come off.  Maybe take a ratchet strap and wrap around the bracket and try to collapse the bracket.  If trying to save the bracket, maybe some vice grips to remove the peg stud after it's moved over?  If it's me, I'll buy a bracket and do what I have to do to get the old one off.  I guess you could pull the exhaust to get it out of the way if you don't like the other options.  If you went that far, there are those that would suggest you replace the o-rings in the front coolant log while you have access.
Offline The ice man
  • COG#: 12605
« Reply #18 on: March 21, 2019, 05:42:12 pm »
If I could remove the screw extractor then I could drill out about 5/8 inch of the stud then I could get it out. It is beginning to look cutting bracket and removing the bracket in pieces may work.
Offline The ice man
  • COG#: 12605
« Reply #19 on: March 21, 2019, 05:52:58 pm »
In some places it is easy to cut the bracket, but close to the stud is not so easy and that is where I need to cut it,to allow the bracket to clear the exhaust manifold and the inner radiator pipe. I wonder what I have to do to remove the inner radiator pipe?
« Reply #20 on: March 21, 2019, 05:56:00 pm »
Send me a pic.
Offline The ice man
  • COG#: 12605
« Reply #21 on: March 21, 2019, 06:59:38 pm »
I  removed the bracket, I pulled left side of bracket out and the stud on the right side broke off. I was lucky it did.....
Offline The ice man
  • COG#: 12605
« Reply #22 on: March 21, 2019, 07:13:03 pm »
I sent pictures, I still have to get the stud out of the bracket.
Offline The ice man
  • COG#: 12605
« Reply #23 on: March 21, 2019, 07:25:40 pm »
I removed stud with vise grips,
« Reply #24 on: March 21, 2019, 08:09:15 pm »
Randy's pics
