Author Topic: Igniter Schematic  (Read 440 times)
Offline connieklr
  • COG#: 1608
Igniter Schematic
« on: December 06, 2017, 08:42:38 pm »
A couple of folks have mentioned SISF’s “Free Power Mod” to me, and after a search I read someone’s comment about a revelation they had as to why their stick coils weren’t working (at the time). Since I may be getting ready to try a set in the near future, it had me dig out an old schematic of the C10 Igniter that someone sent me years ago, so passing it along here for no apparent reason.
Not sure if this is already up here somewhere, but if so, apologies for the repeat. I can pull it down.
________________
Guy Young
COG #1608
COG Life Member
Semi-Civilian
GB Young Services, LLC
Offline Bob H
  • COG#: 788
Re: Igniter Schematic
« Reply #1 on: December 06, 2017, 09:52:20 pm »
I think the primary reason stick coils don't seem to work as well on the C10 as on the C14 is that the stick coils are designed to work with the high voltage pulse generated by the C14's ignition system, and they don't really put out full voltage when driven by the simple switch circuit used on the C10.  They can be made to work, but they probably aren't delivering full high voltage to the spark plugs.
If you decide to try stick coils, be sure you make the ground wire mod.  You need all the voltage possible out of the stick coils.
 '88 one owner:
« Reply #2 on: December 06, 2017, 10:37:24 pm »
connieklr, are you building up your own set, or using some of the T-Cro stick coils?
Wondering if it is possible to buy coils that (are wound differently) and require less power than others?
« Last Edit: December 07, 2017, 02:39:40 pm by connie_rider »
Gone but not forgotten; 00 and 86 Connie's
To contribute to "OtP", DO IT NOW!!
It's EZ: Go to the top of the Forum and follow the steps.
Offline Harry Martin
  • ☺ Cartoonist ☺
  • Fear is not boring
    • Harry Martin Cartoons
  • COG#: 4090
« Reply #3 on: December 07, 2017, 03:48:44 am »
Highly Mysterious Drive Circuitry Solved.
Harry in Wild and Windy Casper, WY - 1986 Vintage "Silverdammit" - 2015 "Greendammit"
Online Nosmo
« Reply #4 on: December 07, 2017, 04:19:32 am »
I have T-Cro's stick coil kit and it works GREAT.  But I accidentally (without knowing what I was accomplishing) did SISF's extra-power grounding mod way back when I was first doing the electrical additions to my bike, so perhaps I never experienced the low-voltage conditions.
2003 Connie    2007 Wee-Strom
« Reply #5 on: December 07, 2017, 02:58:26 pm »
   Yeah, I like TCro's stick coils. In fact I got them YEARS--- ago and it's one of my better upgrades!! :)
Offline Rev Ryder
    • Presbychuck
  • COG#: 7235
« Reply #6 on: December 07, 2017, 03:06:20 pm »
Harry, you are a genius!  I've imagined it differently for years, but now it all makes sense. Thanks!   :great:
Fortis non Ferox
 Shafties Can't Wheelie
« Reply #7 on: December 07, 2017, 03:37:22 pm »
Trv, ya sed it wrong.
It should be;;;;
Harry, you are a genius have a sick mind!
            I've imagined it differently for years, but now it all {kinda} makes sense {in a perverted sort of way} .
                     Thanks!   :great:
