Author Topic: Is a riser needed/available for Murph bar adapter?  (Read 94 times)
Offline crag antler
  • COG#: 8277
« on: April 14, 2019, 08:13:51 pm »
So the question is, if I go with the handlebar adapter from Murph's, can I get a bar riser or is it even needed?
I would most likely go with the superbike bend as I've used it in the past on both my KZ1000J and GS1100ED.
Have the riser on the stock bars and like the comfort level in relation of the Murphs kneesavers.
Doug aka crag antler
00 Kawasaki Concours 60,000+ miles. Bar risers, Murphs kneesavers, blockoff plates, allen head screw set,headlight upgrade. LED headlight, driving lights, JC Whitney trunk, Go Pro mount,
Re: Is a riser needed/available for Murph bar adapter?
« Reply #1 on: April 14, 2019, 08:31:34 pm »
When I had the storz adapter, I was running risers with that.  It's up to you whether you need them or not.
« Reply #2 on: April 14, 2019, 09:08:51 pm »
the whole "concept" on those adapters is that you can pick and choose any style tubular bars (based on height/pullback/width, etc.,) you may want... so adding "risers" is kind of a waste... you can see by the photo, that the bar 'pivot point" is actually about 3" above the tripple tree already, so again, adding another "riser below" is no benefit at all... I've had them on both my C10's, with low wide bars, which I love (superbike and Daytona bends)... you can find something out there for less than $30 that will fit your "dimensions" for sure...
I'm sure you read my post
http://forum.cog-online.org/concours-c10-zg1000-general-chat-and-tech/slow-speed-maneuvering/msg665264/#msg665264
so go online, and look at what bars you can find at Bikemaster, and Iron Pony, and other aftermarket places...
https://bikemaster.com/motorcycle-replacement-parts/control/handlebars.html?limit=all&store=
most people that by the Murph mount, do it so they can use a higher bar, that they can "rotate" back for shorter reach... I like the bars I used, because they are "flatter/wider/less wrist bend" for my ergo's.. most people never get that part of the concept, and I find them less fatiguing in the end result.
best of luck, those mounts turned my C10's into much better handling bikes, and have given me hours of enjoyable aggressive riding, which none of the "stock bars" ever did for me... the lack of "pain" between my shoulder blades became a blessing, and not having my elbows digging into my ribs all the time when negotiating Twisties... well... I can't say enough about that...
 :great: :motonoises: :motonoises:
« Last Edit: April 14, 2019, 09:43:23 pm by MAN OF BLUES »
Offline Jim Snyder
  • COG#: 7055
« Reply #3 on: April 14, 2019, 11:02:36 pm »
I ran two sets of risers under my Storz bar adaptor for many years. I also used the Daytona bars from Bikemaster. Sometimes you have to re-route cables and hoses depending on how the bars work with riders. Two to three inches of slack can be had on the throttle cables by moving them to the right side of the main frame tube. The only cable I ever had to buy longer was an extended choke cable
« Reply #4 on: April 15, 2019, 10:45:47 am »
One problem with the OP's question is that ergonomic likes and dislikes are HIGHLY personal.  MOB likes the daytona bars without risers, while someone else likes them with one or two sets of risers.  If I just had longer arms, I might have been happy with the daytona bars.  You have only one person to make happy.  That is you.  Nobody else can tell you what is going to feel good to your body dimensions and personal tastes.  I think the best advice that I can give you, is to go to a COG event and see the many ways a C10 can be set up.  Seats fall into this category as well.  Best of luck making your C10 fit YOU. :motonoises: :)
