Author Topic: J-Box buzz when pressing starter button  (Read 338 times)
Offline Gitbox
« on: April 07, 2014, 01:30:30 pm »
I thought I would mention this in case it helps anyone.
I was using the "tap starter button" method to position the cams for doing a valve clearance adjustment when I kept getting this buzzing noise from my j-box. I had already replaced the relays and cleaned up the solder joints so I didn't think I had an issue there. If I hit the starter button with some force, there was no buzz, so I though it might be a starter button issue. After a complete disassembly and thorough cleaning, it now works perfectly even with the slightest touch. No buzz at all anymore.
By the way, the spring is part of the circuit, so don't forget to polish that.
In retrospect, I should have taken a before photo. This one is after cleaning.
2008 Yamaha FJR1300A
2004 Yamaha FJR1300 (sold)
2000 Concours ZG-1000 (sold)
Offline VTconnie
  • COG#: 11081
Re: J-Box buzz when pressing starter button
« Reply #1 on: April 07, 2014, 03:31:33 pm »
Good stuff, it seems like alot of people have traced a no-start to the switch itself. Was it just normal oxidation/corrosion?
Offline Gitbox
« Reply #2 on: April 07, 2014, 06:39:42 pm »
Yeah, just normal stuff after 125K miles. :-)
It cleaned up nice with a Dremel and wire brush.
