Author Topic: Looking at buying an '02. Need some advice  (Read 996 times)
Offline Brentos
« on: August 07, 2019, 12:52:17 am »
Hi, I have my eye on an 02 with 37k miles on it.  It has a broken pilot screw(?)  I believe that is what it is called.  The black plastic adjustment screw on the bottom of the quad carb assembly.  It will not start, it turns over fine but spits once and continues to turn over without firing.  The guy selling it says that it ran fine until the adjustment screw broke.  I have been reading as much as I can on this forum and have learned about hydrolock and other concerns (odd tire requirements,  ethanol is bad, and how Steve in Sunny Florida is the guru of the Connie).  The bike has been sitting for one year, when I checked it out there were no leaks to speak of, a little oil on the bottom of the drive where it connects to the rear wheel but the seal seemed like it was not dried out or cracking.  All of the hoses I could reach were pliable and the wires I could reach seemed in good shape.  So with that background here's my question:
What all maintenance should I expect with a Conours that has sat for a year to make it safe.  It has new plugs, spark wires, and battery.   It obviously needs new tires, oil, coolant flush, brakes look pretty good, the suspension seems like it needs adjusting (read a little on that here), the tank lock is broken so I'm figuring drain and flush check the petcock, have to remove it anyway to remove the carbs, fix the adjustment screw needle assembly.  In the process clean out the carbs of any gunk that has accumulated, and sync them.  What else should I look for?  Im trying to determine if I am buying into a sinking ship or what.  Also my knowledge of how to sync the carbs is from a Youtube video I found other than doing it by eye and then tuning them in with the bike running what special tools make it easier.   Im pretty mechanical no machinist but I like to wrench.  Am I dreaming here or is this pretty doable in my own garage?
Thanks in advance for any and all suggestions,
Noob.
Brent
Offline batboy
  • COG#: 12983
Re: Looking at buying an '02. Need some advice
« Reply #1 on: August 07, 2019, 01:47:54 am »
Black plastic screw? Do you mean the idle adjustment knob? The pilot screws should be brass and are hard to get to with the carbs on the bike. If it sat for a year without treating the gasoline, I would almost bet money the carbs are gummed up. Especially the pilot jets.
Offline Brentos
« Reply #2 on: August 07, 2019, 02:17:39 am »
Yes it must be the idle adjustment.  Its a black plastic knob.  The replacement has a cable attached that ends with a pointed brass pin.
Offline batboy
  • COG#: 12983
« Reply #3 on: August 07, 2019, 02:35:42 am »
When the pilot jets clog up, the bike won't idle very well, because it's lean. That's a telltale sign if the idle adjuster is maxed out from the owner trying to get it to idle. In this case, he turned it too much and broke it. So, count on the carbs needing cleaned and rebuilt. You really should get the overflow tubes installed by SISF too.
Offline DC Concours
  • 2001 Concours, ~25K miles
« Reply #4 on: August 07, 2019, 03:20:35 am »
Your information on the bike is limited. A non-running bike is a salvage bike.
If you are going in blind, then it all depends on the price.
For the right price it can be a gem or a lead weight around your head.
Choose wisely.
« Reply #5 on: August 07, 2019, 10:08:18 am »
Choose wisely.
How much is the seller asking for it?
2013 Kawasaki Concours 14
Offline JPD
  • COG#: 12064
« Reply #6 on: August 07, 2019, 11:39:33 am »
Choose wisely.
It depends on how mechanically inclined you are. If you have to pay dealer prices for all the work then free may be too much for the bike. Like wise if you need it to be running next week. A project bike that you can take your time with and you are willing to do the work, ok.
A good running C-10 can be found for south of $2000.00, maybe even with a lot of accessories.
Offline strum
  • COG#: 12307
« Reply #7 on: August 07, 2019, 11:46:40 am »
This where you either take a chance or ask him to let you do a hydrolock test. (which he probably wont seeing some things have to be taken apart)
  It does sound like carb work is in order so you have to be careful on the buying price.  A non running bike should be cheap .
2016 C-14
Offline Brentos
« Reply #8 on: August 07, 2019, 01:57:48 pm »
He's asking $500
« Reply #9 on: August 07, 2019, 02:10:51 pm »
$500 would be pretty fair.
As the idle screw is damaged, it's probable that he screwed it in al the way to get the bike to idle.
 This is an indication of stopped up pilot {or other} jets. A carb rebuild would cure this....
 There is a chance that the bike was hydrolocked. Hydrolock can result in a bent rod.
   This happens if the floats allow excessive fuel to flow before the engine is cranked.
  Turn the petcock to prime at let it set. See if you begin to smell or see gas at the carbs.
    If no {and if there is gas in the tank??}
   Question the seller and ask if it ever did hard knock when he was cranking it.
If anything points to a hydrolock, either take a chance, and/or walk away...
If the key is broken in the gas tank cap, removing the screws around the cap might make it possible to get the cap off for replacement. Possible a lock smith could get it to open as well.
Aftermarket (or used}T) replacement caps are pretty inexpensive.
Offline Brentos
« Reply #10 on: August 07, 2019, 02:43:32 pm »
I REALLY appreciate the input guys.  Thanks to all!
Offline DC Concours
« Reply #11 on: August 07, 2019, 02:57:15 pm »
$500 may be OK. But I wouldn't buy it. As you can see below, spend another 500 and get what seems to be a great bike. Why bother with a non-running bike. Your inspection is very limited.
http://forum.cog-online.org/c-10-emporium/2001-concours-for-sale-in-cookeville-tn/new/#new
I'd buy your salvage 2002 for $100 shipped.
Offline BrianD
  • COG#: 11685
« Reply #12 on: August 07, 2019, 04:05:20 pm »
Yeah, right.  Famous last words.  Reality is it was probably running like crap and he was trying to keep it running by turning the idle adjustment screw until he broke it and gave up.  Carbs will need to be gone through, which is $500 unless you do them yourself.  So right there you're into the bike for $1k if you give him his asking price.
I agree with DC - forget the '02 POS and jump all over the '01 for sale in TN for a grand.  Better hurry though - that bike will not last.
Brian Dutton
Coventry, CT
'02 Concours
Offline kkja13
  • Tyler, TX
« Reply #13 on: August 07, 2019, 04:18:14 pm »
And that '01 has farkles! (added accessories) :great:
2004 C10
2003 Suzuki SV650s
Offline batboy
  • COG#: 12983
« Reply #14 on: August 07, 2019, 04:50:51 pm »
If the pilot jets are clogged, sometimes it'll run if you use a lot of choke (not full choke, just more than normal). Hard starting is another indication and if you do get it started, it'll idle rough and will die with the choke off unless you give it some throttle.
Offline strum
  • COG#: 12307
« Reply #15 on: August 07, 2019, 05:03:23 pm »
Brent where are you located? asking so we can steer you to a better bike or someone close who may be able to help you.
2016 C-14
Offline Brentos
« Reply #16 on: August 07, 2019, 06:15:54 pm »
I'm in Alabama.
Offline DC Concours
« Reply #17 on: August 07, 2019, 07:02:05 pm »
Make a day trip to TN and back.
Offline strum
  • COG#: 12307
« Reply #18 on: August 07, 2019, 07:14:15 pm »
I'm in Alabama.
Ha a bro from Bama.    Im from just south of Huntsville.
 Back to the bike. This is a hard one without standing in front of it. We cant say anything about the condition. Other than it dont run.
  500 is not a bad price . maybe you can get him to go lower maybe not.
 If you feel like taking a chance and working on it youll get a lot of help here. The trick is to not put too much into it. While these are great bike and well loved here . the value is pretty low . I have a friend here with a 98 ready to ride coast to coast that can be bought very reasonably . Or the one DC pointed out looks like a fair deal too.
2016 C-14
Offline Brentos
« Reply #19 on: August 07, 2019, 07:30:25 pm »
Hey what do ya know.  Im outside of Birmingham.  I like the one in TN and looks good from my house.  I'm trying to see if I can shuffle a few things and head up there it's only 4 1/2 hours away.
Offline Brentos
« Reply #20 on: August 07, 2019, 07:37:10 pm »
strum, what does your buddy want for his?  Mileage?
« Reply #21 on: August 07, 2019, 08:15:47 pm »
Offline strum
  • COG#: 12307
« Reply #22 on: August 08, 2019, 12:30:48 am »
pm sent
2016 C-14
Offline Rod
  • COG#: 11095
« Reply #23 on: August 08, 2019, 12:39:15 am »
 There 05 c10 original owner low miles well take care of his COG member the name J.brooks he is north west Richmond,VA.
« Reply #24 on: August 08, 2019, 12:43:16 am »
 :popcorncouple: :popcorncouple: :popcorncouple: :popcorncouple: :popcorncouple: :popcorncouple: :popcorncouple: :popcorncouple: :popcorncouple: :popcorncouple: :popcorncouple: :popcorncouple: :popcorncouple: :popcorncouple:
