Author Topic: Looking to buy a 1992 C10 what to look for?  (Read 2786 times)
Offline Bob_C_CT
Re: Looking to buy a 1992 C10 what to look for?
« Reply #75 on: August 02, 2018, 10:16:16 am »
That is awesome. There is no greater value to be had for a proven Cross Country tourer, I guess he didn't want to be left behind.
« Reply #76 on: August 02, 2018, 01:40:56 pm »
Since both of you have a Connie and need a trip, here is a fyi.
South Central has 2 rides coming up that you might be interested in.
1 is to Big Bend, other is Arkansas.
Either would be a good break-in ride for ya, and you could meet some of the COGdom...
Info is available if your interested.
Offline Eric
« Reply #77 on: August 02, 2018, 02:22:07 pm »
Yeah we may do the big BBQ Arkansas thing
Offline Bob_C_CT
« Reply #78 on: August 02, 2018, 05:45:28 pm »
Eric, just let your Dad know that some 2006 models had oil pressure light coming on during heavy braking. Something to do with oil pump clearance issue on the last model year. I don't think there was any catastrophic damage to be worried about though.
Offline Eric
« Reply #79 on: August 02, 2018, 09:49:41 pm »
Yeah the previous owner talked to him about it so it’s good for now! Thanks!
Offline Eric
« Reply #80 on: August 11, 2018, 09:30:42 pm »
Hey guys i have a question on the other side of the air pressure knob of the handle bars there’s this thing with black paint chipping from it. It’s proby not the original cover where can i get one?
https://drive.google.com/open?id=1sz1DEaT_OoHNDRGNxGlOEva0NCgdSBlS
« Reply #81 on: August 11, 2018, 10:45:43 pm »
lemme look around, and see if I have one... send me via p/m your email, and ask in that email..
in the meantime..
   11012-1500   CAP,FORK TOP
wow, after looking these are 'unobtainium"
https://www.ronayers.com/oemparts/partsearch/kawasaki
lemme check my boxes.
Or, hit  up 'the wizard' on the forum where parts are sold.
Offline Eric
« Reply #82 on: August 12, 2018, 02:49:17 pm »
And another thing guys putting some murphs grips on cut both of the ends off but the left side opposite of the throttle seems really lose and didn’t hold with grip glue. Any suggestions
« Reply #83 on: August 12, 2018, 02:57:32 pm »
Can't imagine why it's loose and I would think that grip glue would handle it.
I also put a little gas or brake clean inside the grip, splosh it around, and dump the fluid, then slide onto the bar.
          After it drys, it's stuck.
  If not, I used hair spray as the glue. Has always worked for me.
Most important part of this is, let it dry completely before trying to see if it moves...
Offline Eric
« Reply #84 on: August 12, 2018, 06:21:56 pm »
Thanks so much just did the valves putting it back together and just had a question about this clear hose that comes out the lines going between carbs is it just a vent?
https://drive.google.com/open?id=1hEgKNyoe8lzRN07RGPUKn_tiqRbJ-MuR
Offline Grant
  • HOTROD TRUCKS & BIKES
  • COG#: 12666
« Reply #85 on: August 12, 2018, 06:24:59 pm »
My favorite thing to use for installing grips is Final Net hair spray, it acts as a great lube to slide the grip on and after just a few minutes locks it in position. I used to always have a can in the shop when I was racing motocross and never put it in my hair  ;)
« Reply #86 on: August 12, 2018, 11:00:32 pm »
   Yup, just a vent.  :great:
Offline Eric
« Reply #87 on: August 13, 2018, 01:25:18 am »
Sweet thanks guys got my valve job done and synced the carbs and the valves were all way tight so adjusted them, had a murphs tool but i didn’t really like it too much just using a wrench and flathead worked fine for me. The power is now super smooth and the bike feels great now! (Not that it wasn’t before :P)
« Reply #88 on: August 13, 2018, 02:44:40 am »
  Have to agree with you on Murphs' valve adjustment tool. I used it once and now it is somewhere in a dark corner of one of my tool boxes. ::) I think I have almost all of Murphs' goodies and think they are great. The valve adjustment just wasn't for me . Screwdriver and box end wrench worked best for me. :great:
   I have since gotten SiSF's torque cams which has better lobs than the oem cams. It is now longer between adjustments and I get a little more "umph" at lower revs.
« Reply #89 on: August 13, 2018, 02:45:47 pm »
Eric; On both of the bikes, there is a simple fix that might save you some future woe's.
        Stock, the footpegs will fold up "only a bit".
           If the bike is ever dropped, the footpegs can crack, or break off. {because of the stop that limits the amount they will fold.}
           Grinding away a little aluminum from the "stop" will allow them to fold up higher and there is less chance of them breaking.
Look at the footpeg's on both bikes and see if they have been modified. {also check for cracks}
   If you feel they were not modified, I highly suggest you remove them and do the quick mod.
If unsure of where to grind, we can supply that info.
