Author Topic: Mean Streak wheel conversion question  (Read 1999 times)
Offline Reaper1
  • Captain E.B. Hammonds ('89-'94 US Marines, '01-'06 US Navy, '07-'09 US Army)
  • I'm with the government and I'm here to help!!!
    • The Comms Shop - Tactical Division
  • COG#: 10520
« on: December 12, 2012, 04:24:42 am »
Have people been using the Mean Streak rotor also or keeping the C10's?
COG# 10520
1999 ZG1000 in Olive Drab and running around half necked. (The Blacksheep)
Purveyor of firearm accessories found at www.commstactical.com
Offline Eddie-SC
  • COG#: 7073
Re: Mean Streak wheel conversion question
« Reply #1 on: December 12, 2012, 11:36:36 am »
Looks like the C10 rotor doesn't work; 6 bolts vs 7 bolts on the Mean Streak wheel. Here's a link...
http://cog-online.org/clubportal/ClubStatic.cfm?clubID=1328&pubmenuoptID=35726
Scroll down to Mean Streak conversion.
Anderson, SC
1969 Triumph Bonneville
Offline Bob_C_CT
« Reply #2 on: December 12, 2012, 12:15:40 pm »
I turned down the OD of the Meanstreak rotor because it came with the rim. Worked fine
« Last Edit: December 12, 2012, 12:23:55 pm by Bob_C_CT »
Southern Connecticut.
Offline worncog
  • COG#: 9584
« Reply #3 on: December 12, 2012, 12:47:42 pm »
I went with a Nomad rotor off of Fleabay. Easy fit-up, but can be difficult to find used in serviceable condition. The previous pair were worn to the service limit.
RWTW, COBDR, SM 500, BVF...
Offline GF-in-CA
« Reply #4 on: December 12, 2012, 02:18:15 pm »
As already stated, the C10 rotor unfortunately has too few bolts and won't work.  The Mean Streak rotor is too large (300 mm)and needs to be turned down to 280 mm to work.  I used the Mean Streak rotor without turning it down or machining the wheel, but made my own caliper bracket to make it work.  My guess is most people who do the conversion use the Nomad rotor.  Just curious, from the pictures of you bike, it appears you already have the Mean Streak wheel installed, are you looking for another rotor?
There are a pair of Nomad rotors on ebay now, you can use one and sell the other to another C10 owner  :great:
http://www.ebay.com/itm/99-Kawasaki-Vulcan-VN-1500-G-Nomad-Front-Rotors-GO-/150939685029?pt=Motorcycles_Parts_Accessories&hash=item2324b4d0a5&vxp=mtr
HTH,
Gary F.
1998 ZGX1100
Central Valley California
Offline Reaper1
  • COG#: 10520
« Reply #5 on: December 12, 2012, 06:03:51 pm »
I'm not in the market right now with so many other things I gotta do, but I'm thinking about getting a rear rotor that has a similar appearance to the front...
COG# 10520
