Author Topic: my new 2003 concours  (Read 335 times)
Offline George
« on: March 12, 2015, 02:30:31 pm »
Hi ,I have some questions on my 2003 concours ,cleaned carbs , and runs pretty good but number 1 cilinder is 350 degrees 2) is 250
3) is about 325 and  4) 350 is that OK? how can i get the  temps more even or dose it matter ? Also my bevel gear casings paper gasket is leaking . can I live with that? Also dose anyone no a concours Guru in the
Houston - Galveston area ?
Thanks -George
COG #392  1986 Kawasaki Concours  1992 Ducati 900SS  1978 Ericson 35 Mk II "CIRRUS"
Offline Jorge
  • COG#: 9297
Re: my new 2003 concours
« Reply #1 on: March 12, 2015, 02:53:20 pm »
First, welcome to the forum. There's lost of good knowledge and experience in the group.
Just curious, how did you measure the temperatures?
Jorge
Offline George
« Reply #2 on: March 12, 2015, 03:36:11 pm »
Jorge , I used a hand held infra red thermometor
« Reply #3 on: March 17, 2015, 04:28:19 pm »
You are not getting much help because this is posted in the wrong area really.
Did you test and set the float levels?  If not than that cylinder may be pulling in to much gas cooling it down.
Did you do the test for bent rods?  If not that one may be bent enough to have lower compression and temps.
Ted is in Houston and knows all this stuff.  Connie_Rider I think is his screen name.
Offline dan4aspen
« Reply #4 on: March 17, 2015, 04:37:21 pm »
Check with SiSF also. Shoodaben Engineering is his company, Steve in Sunny Florida is his screen name.  He has a Carb Spa to include overflow tubes that prevents Hydro Lock.  He has many useful links on his webpage, and youtube.  Here is his You Tube channel with his videos!!!
BURN RUBBER, NOT YOUR SOUL!!!!!!!
