Author Topic: Mystery Part - Please Identify  (Read 763 times)
Offline klr4evr
« on: February 09, 2018, 11:56:33 pm »
Wiring in some grip heater and I found this kinda loose stuck in the wire bundle by the rad neck. Anybody know what it is? It has a cut in it. isn't straight so maybe it didn't come that way. Also has a groove on the inside around the diameter as if it would fit on something to keep it from sliding. Different diameter holes on each end. Stands about 1 3/16" high(long).
Thanks for the assistance.
"It's a friggen motorcycle, it's not supposed to be comfortable, quiet or safe. The wind noise is supposed to hurt your ears, the seat should be hard and riding it should make you s*** your pants every now and then. "
  • --2006 Concours--
Re: Mystery Part - Please Identify
« Reply #1 on: February 10, 2018, 12:06:50 am »
If it's hard rubber, it may be one of the dampers the tank sits on.
There's one on each side of the tank in the front on the bottom.
They have a habit of popping off, then dematerializing and going
to the 5th dimension...  with lighters and socks.
Offline mnbikeguy
« Reply #2 on: February 10, 2018, 12:26:47 am »
Offline klr4evr
« Reply #3 on: February 10, 2018, 01:54:57 am »
Part 92071-1143 Grommet
You the man. Makes sense finding it tucked in the wire bundle. Thanks for solving that. I owe you a cool one.  :beerchug:
Offline Greenie
  • COG#: 1019
« Reply #4 on: February 10, 2018, 09:09:58 am »
I wrap electrical tape around the steel stub these things go on to make them stay put.
Offline klr4evr
« Reply #5 on: February 10, 2018, 02:57:05 pm »
You say "these things" - is there more than one??
Offline Stasch
  • COG#: 6830
« Reply #6 on: February 10, 2018, 04:08:05 pm »
There is only one of the actual part in question - which goes on the clutch hydraulic line up by the steering head.
Others are referring to the fuel tank bumpers of which there are 2.
  • --2006 Concours--
« Reply #7 on: February 10, 2018, 07:55:25 pm »
It looked like a tank damper from the picture....  I was wrong  :(
Mnbikeguy got it right...  I need glasses for my glasses I guess.  :o
