Author Topic: Need some advice on rear wheel  (Read 203 times)
Offline cornponious
« on: July 15, 2018, 10:52:01 am »
 I have taken my rear wheel off of my 2003 Concours, in anticipation of replacing the rear brake disc and pads.  While the wheel is off, I was looking for advice on what and where I might ought to apply new grease. Should I clean off old grease from parts before applying new grease? Also, what type and brand of grease do you recommend?
Re: Need some advice on rear wheel
« Reply #1 on: July 15, 2018, 12:48:31 pm »
  I have Honda moly 60 grease that I bought some time ago. I clean the splines of old grease and use a small brush to apply the moly grease.
   Don't know if you can still get the Honda moly grease.
   You can try these sources.
http://forum.cog-online.org/tires-suspension-c14/honda-moly-60-discontinued-best-spline-lube/
« Last Edit: July 15, 2018, 12:59:58 pm by Mettler1 »
