Author Topic: oil capacity  (Read 557 times)
Offline Richard
oil capacity
« on: October 22, 2018, 02:06:34 am »
Out of curiosity, what would happen if you added 3.9 quarts of oil after an oil change? Is that too much? Is there a danger of damage? 2004 Concours.
Offline DC Concours
  • 2001 Concours, ~19K miles
Re: oil capacity
« Reply #1 on: October 22, 2018, 02:51:14 am »
That is too much oil if the engine is wet. Did you add all that?
Usually oil would seep through the breather hole, water pump seal should pop out and there may be some damage to the engine and oil pump due to the pressure.
Re: oil capacity
« Reply #2 on: October 22, 2018, 03:02:51 am »
  Yup. 3qts with an oil filter change. When I do mine (on the center stand) I let the engine run 'til the cooling fan kicks in. Shut down for several minutes and then look at the crankcase sight glass. Oil should cover 2/3 of the sight glass. That's what I have done for the last 24 yrs. Works for me. :great:
Offline ron203
  • COG#: 9847
Re: oil capacity
« Reply #3 on: October 22, 2018, 06:33:24 am »
It takes more if you have the SPOOFAK kit depending on which filter you use (Search the forum for that) and a spin on oil filter, but that's still too much. If you have the OEM set up, 3 is all you need.
2014 C-14
2008 Goldwing
Offline CaffeineMan
  • In the shadow of the Valley of Death
  • COG#: 7763
Re: oil capacity
« Reply #4 on: October 22, 2018, 12:54:46 pm »
3 quarts for my C10 as well, changing both oil and filter, both stock and with SPOOFAK using Kawasaki spin-on 16097-0008 (Kawi replacement for 16097-0004).
I try to "calibrate" the process by watching how much is needed the first couple of times, then I just use the same parts and put in the same amount all the time.  Quick check of the window and I'm good.  Makes it easy to change the oil frequently.
On another note, I see Mettler1 is getting into the spirit of Halloween, having installed the SPOOKFAK version of the kit.  Either that, or it's a special CIA black-ops research project he can't tell us about.   (Sorry, couldn't help myself) ;D ;D ;D
"You put antiseize on those, right?"
01 C-10 Sonic Blue ("Old Blue") - Touring by Sport Touring:  Progressive 465 rear shock, Race Tech emulators and 1.0 springs, EBC rotors, Nissin 4-piston calipers, Spiegler hydraulic lines, Russell Day-Long saddle, Cee Bailey windshield.
17 C-14 Candy Imperial Blue ("Baby Blue") - Sport by Sport Touring
Re: oil capacity
« Reply #5 on: October 22, 2018, 01:27:01 pm »
  CaffeineMan got me after all these yrs. I have spelled "SPOOFAK" wrong these yrs. Well I ain't gonna change it after all this time!! ::)
Re: oil capacity
« Reply #6 on: October 22, 2018, 06:37:11 pm »
I can't say that the filter makes a big difference, but I installed SPOOFAK's on both my bikes, and using the long or short Purolater filter made little difference...
after draining from BOTH drain plugs, and using a new filter, I prefill the filter from a fresh quart, Install the filter, dump the remaining oil in, and follow it with 2 more quarts, and 5 ounces.... and never worry... that is actually the correct oil level in the book, based on Liter amount noted, and it always comes up correct in my oil window...  so my opinion is 3 quarts + 5 ounces...
I have never 'added oil' by using the window as a 'gauge', I just use that as verification the oil is in there, and at the line.
YMMV
Offline DC Concours
Re: oil capacity
« Reply #7 on: October 22, 2018, 06:41:06 pm »
MOB, I drain from both drains. My window still gets full at about 2.5 qts. What am I doing wrong? Only thing, I just never warm up my bike before draining. It sits overnight and to me that is good enough.
Offline CaffeineMan
  • COG#: 7763
Re: oil capacity
« Reply #8 on: October 22, 2018, 07:00:50 pm »
SPOOKFAK looks better anyways.  I'm just being a pest...  Couldn't resist...  ;D ;D ;D
Re: oil capacity
« Reply #9 on: October 22, 2018, 09:36:07 pm »
I have no idea.  2.5 quarts = 2.36 Litres.. that is not enough, by the book...with or without a new filter...
I do my changes with the bike cool also and sitting on the centerstand..
drain, remove filter, prefill spin on, and use the quantities I noted above...
the book says:
2.7 litres with no filter change (I never change oil without filter' but that is equal to 2 qt's + 27 oz.)
3.0 litres with a filter change  (3 Qt's + 5 oz)
and that's what I've always done,pre SPOOFAK and after SPOOFAK; and my fill line is right on the money after running the bike, and it is sitting tires on the ground.
YMMV.
« Last Edit: October 22, 2018, 09:39:19 pm by MAN OF BLUES »
  • --2006 Concours--
Re: oil capacity
« Reply #10 on: October 22, 2018, 10:32:52 pm »
My '06 takes more than 3 quarts, but not much.  Factory filter set up.
It's less than a 1/4 quart more, but it is more.
I fill my oil to just below the top line...  The '06 oil light on hard braking issue is resolved with a wee bit more.
I fill 3 quarts, run the bike on the CS for a minute, then shut it off, let it rest for 15 minutes, then top off
with the last few ounces.  Done.
Offline Strawboss
  • COG#: 5852
Re: oil capacity
« Reply #11 on: October 24, 2018, 02:59:17 pm »
Crap! You gotta change the oil in these things? ;D
01 Concours  1982 KZ550A  1979 Triumph Bonneville  1995 Honda scooter  COG#5852  AMA Life 302525  NRA 9098599  SASS 28759
  • --2006 Concours--
Re: oil capacity
« Reply #12 on: October 24, 2018, 10:29:44 pm »
 :hee20hee20hee: :hee20hee20hee:
The REAL question is which oil?    >:D
Re: oil capacity
« Reply #13 on: October 25, 2018, 02:17:18 am »
  The kind I use is best!!! :beerchug:
