Author Topic: Oil capacity  (Read 20639 times)
Offline Bergmen
Re: Oil capacity
« Reply #25 on: August 06, 2012, 12:11:14 am »
The power windows hot all the time, key or not? Absolutely fabulous! ......All cars should have the option to have windows hot with or without the key. Crank up/down windows never needed the key.
Thanks for making it easier to steal your Tundra, Dan.  When's the next time you're coming down to Mountain View?  :))
Nobody knows the windows are hot except people I know here. A short list of suspects for sure. Plus, you'd have to bust the window to get to the switch which sort of defeats the risk.
I was just down in Santa Clara last Friday, I run down there about once a week these days. The last project I was assigned to (with one other ME) took two years to develop and they sold enough instruments in one week (at $250,000 each) to cover the total R&D investment (which was NOT cheap). They're happy and I'm happy.
Dan
--2014 Yamaha FJR1300A--
--ZGRX 1200 Concours (sold)--
--SPOOFAK Inventor--
Offline Strawboss
  • COG#: 5852
Re: Oil capacity
« Reply #26 on: August 06, 2012, 12:22:06 am »
Checking my oil level is part of my everyday pre-ride check list right after tire pressure and lights. Should I not be doing this? ;D
01 Concours  1982 KZ550A  1979 Triumph Bonneville  1995 Honda scooter 1982 CB125s 1980 BMW R-65  COG#5852  AMA Life 302525  NRA 9098599  SASS 28759
Re: Oil capacity
« Reply #27 on: August 06, 2012, 12:59:14 am »
  Can if you want. I just put in 3 qts.,warm up the bike-- shut it off and ckeck the glass in an hour or so. If oil level is good an see no oil on the garage floor after a ride I may check the oil level every month or so. It's worked for 18 yrs.
Offline Redbarron
  • COG#: 10045
Re: Oil capacity
« Reply #28 on: August 06, 2012, 10:38:38 am »
Hello all:
Clymer manual misprint ?? 3.7L or 3.9q.  If the engine was designed to run using almost 4 quarts per the engineers that designed it
Then why would we only use 3.0 quarts?
I myself have never read the actual Kawasaki  technical manual  could someone please scan the specification page and post it.
Thank You
Offline wild man
  • COG#: 6174
Re: Oil capacity
« Reply #29 on: August 06, 2012, 11:04:03 am »
Thats for a newly assembled motor, one thats never seen oil.
Bill
USAF Ret, KC0IGL
AMA#333772, IBA#19247
2007 KLR 650, 1997 ATK 605
Offline Eddie-SC
  • COG#: 7073
Re: Oil capacity
« Reply #30 on: August 06, 2012, 09:24:05 pm »
Yep...completely dry. No oil in cooler, pump, lines, puddled in the head, etc. Dry as a popcorn f@rt!
Anderson, SC
1969 Triumph Bonneville
Re: Oil capacity
« Reply #31 on: August 06, 2012, 10:27:21 pm »
  Are they REALLY dry? :popcorncouple:
Offline Eddie-SC
  • COG#: 7073
Re: Oil capacity
« Reply #32 on: August 06, 2012, 11:12:06 pm »
That's what they tell me!!  :)
Anderson, SC
Offline JPavlis_CA
  • San Jose CA
  • COG#: 2293
Re: Oil capacity
« Reply #33 on: August 06, 2012, 11:18:26 pm »
Clymer is wrong. There's so many misprints I'm surprised anyone uses it except for the pictures. There'a also some bad user supplied info. (yes - they actually contacted COG while developing the manual. And they actually trusted what some people who had no clue told them. Trouble is, they never came back to us for review before going to print)
And Dan - it's easy to pry the door frame put enough to get a probe in there to hit the window switch. No bustin' windows required.   :))
