Author Topic: project build up *turbocharged*  (Read 53204 times)
Offline turbo-max
  • COG#: 10445
« on: September 17, 2012, 11:26:57 pm »
so, i guess i will get a thread started since i posted in the n00b section, then joined up.
 my plan is to slowly rebuild and upgrade this bike and go turbo, this weekend past i started by replacing the steering head bearing as they had a nice "dead" spot in them, i also replaced all the burnt out instrument cluster bulbs, and today, i went to the other coast to pick up a good low mile engine to swap in so i can build and forge the original while i still ride it., i will post up pic another day to document this as i move along. mmmMMMmmm booost.
 i would like to thank " Rev Ryder" for providing some good insight on this project seeing as he already went down this dark road that i so love to travel with everything i own  ;)
« Last Edit: November 24, 2013, 09:47:47 pm by turbo-max »
99 c-10 "the purple monster"
Offline Snarf
  • COG#: 8302
Re: project build up
« Reply #1 on: September 18, 2012, 10:43:53 am »
 :welcome: :popcorncouple:
Chris Lillie
02 concours (CC)
86 concours (spirit of cog)
« Reply #2 on: September 18, 2012, 12:39:39 pm »
please post up progress as the hotrodding gets under way. While most here don't do massive hotrodding, I do thing most find it interesting reading. I know I do! Steve
Offline turbo-max
  • COG#: 10445
« Reply #3 on: September 26, 2012, 03:27:45 am »
quick update...not alot to talk about yet, i do have another engine (stocker) and a few other spares and i have a set of the zx 636 throttle   bodies on the way!  :great:
Offline MikeDifonzo
« Reply #4 on: September 26, 2012, 11:41:10 am »
Looking forward to updates as you progress with this project; thanks.
Offline turbo-max
  • COG#: 10445
« Reply #5 on: September 29, 2012, 12:40:15 am »
okay, time to get a few pics of said project up...
the day after i got it from my dad, it was mod time already!
Offline turbo-max
  • COG#: 10445
« Reply #6 on: September 29, 2012, 12:42:36 am »
after reading a few posts on rust and crap in the fuel tank, i wanted to have a look, nice and CLEAN!!
Offline turbo-max
  • COG#: 10445
« Reply #7 on: September 29, 2012, 12:46:51 am »
so the first thing i did was replace the instrument cluster lights, add a fork brace and clean it up abit, then i took it apart again for more messing around/learning about the bike. updates to follow. ALSO i plan to repaint this bike white. <-- thoughts/input on this please.
Offline Redbarron
  • COG#: 10045
« Reply #8 on: September 29, 2012, 11:19:45 am »
Hey Turbo-Max:
Looks like a 2000 connie same thing I have :) what are you giong to do with all the spare kibbles?
Also have you removed the coolant hoses from her yet? I need a complete set for referance.
Keep those pics coming man,  I'll be getting into mine this week for some body work.
Offline turbo-max
  • COG#: 10445
« Reply #9 on: September 29, 2012, 02:13:05 pm »
Hey Turbo-Max:
it's a 2003 with 110k miles, dont plan to "lose" much as my dad also has a connie (this was his "old" one)
Offline turbo-max
  • COG#: 10445
« Reply #10 on: October 02, 2012, 12:51:57 am »
a few more mostly nekked pics..
Offline turbo-max
  • COG#: 10445
« Reply #11 on: October 02, 2012, 04:29:55 am »
took the plunge to do body work/color change.... first i did a ruff sand (80 grit), then a light primer to see the deeper scratches, then another smoother sanding (180 grit), will do more in the next day or so.
Offline turbo-max
  • COG#: 10445
« Reply #12 on: October 02, 2012, 04:34:02 am »
want to add that i might make some progress in short time, or might go days or weeks with no progress as i am also doing a restoration on a lamborghini diablo, as in  one of the pics you could see a few parts layed out on a table for that car  :o
Offline turbo-max
  • COG#: 10445
« Reply #13 on: October 02, 2012, 05:44:46 pm »
bondo bucket time!  :-[
Offline turbo-max
  • COG#: 10445
« Reply #14 on: October 03, 2012, 04:03:31 am »
after bondo was sanded down...
after sanding down the bondo, another coat of primer was applied,then sanded,
then a test paint just to see how the color will look. ( rattle can white enamel paint)
« Last Edit: October 03, 2012, 04:05:40 am by turbo-max »
Offline Rogue Booger
  • COG#: 9087
« Reply #15 on: October 03, 2012, 09:50:41 am »
It's looking good!  :beerchug:
Member# 9087  CDA# 317
« Reply #16 on: October 03, 2012, 12:22:37 pm »
I know it's late, but you shoulda cut the whole rear connector section off. No need for it, and oil changes are alot easier. HTH, steve
Offline turbo-max
  • COG#: 10445
« Reply #17 on: October 03, 2012, 02:13:25 pm »
;D never too late, i will end up sanding this down again to do more filler finishing as there is a few dips and such still in it, but thanks for that tip.  :great:
Offline turbo-max
  • COG#: 10445
« Reply #18 on: October 18, 2012, 03:02:45 am »
time for some updates with pics, tonight i relocated the coolant over-flow bottle.
after a quick "test fit" to see what i needed to change, i relocated the over flow drain nipple:
in this pic, you can see the location as if the bottle was in the "stock" attitude:
now fitted in it's new home:
now time to trim open the tool tray/battery hold-down:
tool pack still fits, just not down in the stock cubby:
that is all for now..still busy with the lamborghini resto...*sigh*
Offline Andrew
  • COG#: 10516
« Reply #19 on: October 18, 2012, 12:57:27 pm »
looks like fun.  any pics of the Lambo?
Offline zetec7
  • COG#: 10484
« Reply #20 on: October 18, 2012, 05:51:12 pm »
Wow!  Your work on the belly pan makes me think I should rejuvenate the spare I have - it's no worse than the one you're fixing, and I'd thought I'd just toss it.  I think I'll fix it instead!  Never know when somebody will need one...
"The Professor"
Offline Smooooth
  • Syracuse, NY
    • The Kaw Barn
  • COG#: 10396
« Reply #21 on: October 18, 2012, 07:12:07 pm »
I'd thought I'd just toss it.    :32:
98 C10
73 Honda CT70
'The Kaw Barn' on Facebook
73"s de WA2FDU
Offline turbo-max
  • COG#: 10445
« Reply #22 on: October 18, 2012, 10:19:55 pm »
i will have a few pics of the lambo, i have a ton of crap to do to it tonight!
*edit for lambo pics*
this is the pile of crap i was aiming to install tonight:
« Last Edit: October 19, 2012, 04:21:31 am by turbo-max »
Offline turbo-max
  • COG#: 10445
« Reply #23 on: October 19, 2012, 04:23:41 am »
i got 90% of what i wanted to get done installed...just having a hella time getting a couple of bolts started in the top of the front diff where there is bearly room for 2 fingers to hold/start the stupid bolts...had to walk away from it for tonight  >:(
Offline turbo-max
  • COG#: 10445
« Reply #24 on: October 20, 2012, 08:06:33 pm »
so today i blew my load and ordered a microsquirt and picked up a garrett gt20 turbo  :)
but now i am a broke biootch again...lol  :-[
