Author Topic: Re: What did You Do to your C-10 Today?  (Read 17947 times)
« Reply #150 on: January 27, 2019, 01:10:22 pm »
Replaced the brake and clutch levers.  The pivot screw and master cylinder bushing were worn so those got replaced.  Applied a fresh coating of grease on all the wear points.  No more floppy clutch lever!
Offline Boomer
  • Me dwarfing Vivian
    • Boomers GTR Site
« Reply #151 on: January 27, 2019, 03:53:19 pm »
Yesterday I fitted my home made LED tail/brake light 'bulb'. Then ordered some LEDs to replace my high-level (trunk) brake lights from Fleabay and ordered tip over bars, a screw set, and some Speed-bleeders from Murphskits. Today fitted the rebuilt rear brake system with a new bracket, lever and a good used caliper. Soon I won't have anything else left to do and will have to start prepping for the respray. :-(
George "Boomer" Garratt
Wickford, UK
CDA-007
« Reply #152 on: January 27, 2019, 04:02:52 pm »
If you want, we'll be happy to think of more Farkles for you to add to the bike?
Offline Boomer
    • Boomers GTR Site
« Reply #153 on: January 27, 2019, 11:29:26 pm »
Go on then Ted, I dare ya to come up with something useful to modify the C10 that ain't been done already! <LOL>
Wickford, UK
CDA-007
« Reply #154 on: January 29, 2019, 01:00:29 am »
Boomer, as you know, I've been tinkering on the old bike lately.
    {mostly because I was bored and just wanted something to tinker on}..  >:D
     Here's the recap.
On my C-10, I ; replaced the rear shock with a C-14 shock and lowering rocker,
                        removed 4" from the front springs to stiffen the front suspension,
                       Found and installed inexpensive cartridge emulators that cost 1/3 the cost of a gold valve,
                        replaced the 150/80-16 belted rear tire with a 180/60-16 radial tire,
                        replaced the 120/70-18 front tire with a 110/80-18 radial.
                        cut the windshield and built an adjustable deflector {similar to MRA Vario design}
                         LED head and tail light bulbs.
The only things I did {that may not have been done by someone else} was; the 180 rear tire, inexpensive emulators, MRA style deflector.
« Last Edit: January 29, 2019, 03:42:17 pm by connie_rider »
« Reply #155 on: January 29, 2019, 03:28:30 am »
  NOTHING!!!!!    It's 10 degrees and my C10 is on the centerstand with the battery charger plugged in!!!  Full tank of fuel and TCW3 for the winter!! Just waiting for some spring weather!  :)
Offline donaldj
  • Proud Vet!
  • Blessed!
  • COG#: 4879
« Reply #156 on: January 29, 2019, 05:27:19 pm »
Installed ZZr 1200 calipers w/SS lines.
Had my carbs totally Shoodabened.
New carb boots and springs.
In the process of:
New fork springs and emulators installation.
Bergman spin on oil filter. (Should have kept the one off of my other Connie) Of course new Amsoil.
Headlight and headlight harness upgrade.
Valve adjustment.
Running lights.
Radiator flush and new coolant.
Have a rear ZZR1200 shock to maybe install, last on list right now. ::)
Replaced the Summer air in my tires with Winter air.
Other odds and ends. :beerchug:
Vintage43
Offline Captsparrow
« Reply #157 on: January 29, 2019, 11:08:55 pm »
G'Day Guys, sort of feel sorry for those bikes and riders in the shed for those extensive period of times. Down here we can ride pretty much all year round.....thousands of kms to do, places to go.......hope your Spring comes around soon. Ride safe and keep those mods coming.
« Last Edit: January 30, 2019, 03:21:39 am by Captsparrow »
Offline Thud300
« Reply #158 on: January 30, 2019, 01:17:44 am »
 :??: Plugged in the trickle charger and stared outside at the frozen tundra.
1991 Voyager XII "Xaviera"
1989 454 LTD "Merlin"
Offline Kelly E
  • Geriatric Hooligan
« Reply #159 on: January 31, 2019, 03:48:55 am »
I rebuilt the rear brake caliper, installed the new line, refilled and bled. I also took apart the front master cylinder and cleaned it out along with the right front caliper. I got the master back together so tomorrow I will pull the left caliper, rebuild both of them and reassemble with the new two line system. The front brake was starting to get squishy feeling at the lever so it was time to install all of the new parts I had been collecting. I rebuilt the clutch system with a new line last year so now I need a new speedometer cable and need to install the straight rear subframe, the stock one is twisted a little bit.
1994 Kawasaki ZG1000A-The Long Rider
1984 Honda VF700S Sabre-The Bike
1986 Honda CB700SC Nighthawk S The Hooligan Bike
1974 Honda CB550 K0
Offline MichiGlenn
  • "Wherever you are, be all there" Jim Elliot
  • COG#: 10892
« Reply #160 on: January 31, 2019, 10:09:05 am »
Me too!  This is getting ridiculous.
2001 C-10
1977 Honda CB750K Sold
1978 Honda CB750K Long Gone
1972 Honda CL175 Ancient History
Heald Super Tryke 8hp, Wards T555 Trike
« Reply #161 on: January 31, 2019, 01:48:56 pm »
Hope you guys up north are safe in all this cold..
To us southerners, it sounds like it's gone from uncomfortable to a bit dangerous..
Stay warm..
Boomer asked for things to tinker on, and then nothing.
Do ya'll think we overwhelmed him with suggestion's?
« Last Edit: January 31, 2019, 09:39:39 pm by connie_rider »
  • Stayin' for the people....
« Reply #162 on: January 31, 2019, 05:46:27 pm »
Stay warm..
Do ya'll think we overwhelmed him?
I started test fitting and measuring out Connie's new spot in the upcoming
Garage 2.0 upgrade.  Should be nice when it's all done.
Let's review that whole global warming thing....   ;)
High of 60*F in Florida?  I've got neighbors ordering snow blowers!
2016 BMW S1000XR Alpine White --- On its way!
Offline Tour1
  • COG#: 9226
« Reply #163 on: February 02, 2019, 10:43:08 pm »
I might have broke my C10.  Details in another thread.
Meanwhile, and I'm not saying I have a valid theory about Global Warming, I think our earth can be proportioned to a beer can where New York City is on the edge between the side and the top.  The top & bottom can be frozen over while the sides are red hot.  At least, it could happen if there weren't any beer inside.  So the solution is to convert fracking rigs into beer injection sites.  QA inspectors needed  :beerchug:
So, what I did in a positive way was start it, ran it, warmed it up & charged the battery some, then the little problem, and I bought a nice compression tester to check it out next opportunity.
1987 Concours
Offline Rideezdale
  • rideEZdale
  • COG#: 12728
« Reply #164 on: February 03, 2019, 01:03:54 am »
 I took the the cover off and sat on it and envisioned me riding down to Arkansas to attend the Horseshoe Mountain Rendezvous.
 ;D  :D :))
« Last Edit: February 03, 2019, 01:10:52 am by Rideezdale »
1973 Yamaha YZ80, 1977 Suzuki GS400, 1978 Suzuki GS1000E, 1983 Honda CB1100F, 1984 Yamaha Venture,  1987 Yamaha Venture, 1989 Yamaha FJ1200, 2003 Kawasaki Vulcan 1500 Nomad, 2000 Kawasaki concours
Offline CRocker
  • '02 C10 CDA # 416
« Reply #165 on: February 03, 2019, 02:31:31 am »
Finished removing the 4 into 1 and installed the stock exhaust...coolant is cooling down now...it’s going to be mid-60s tomorrow...might be riding...but, there’s all this plastic... :beerchug:
« Reply #166 on: February 03, 2019, 11:01:34 am »
Since we had the start of a short heatwave yesterday, I took the C10 out for a short spin.  Tested out my new to me aerostich roadcrafter one piece suit.  I like it!   :beerchug:
« Reply #167 on: February 03, 2019, 07:39:14 pm »
Rode it again!   :motonoises: :motonoises:67 Degrees today.  You never know what you're gonna get around here as far as weather is concerned!  Took the "Real Bud's" 87 out to Derby for a fill up of some "real gas".  $3.35 a gallon today.  It's a beautiful day in southern Indiana!
« Reply #168 on: February 03, 2019, 10:35:58 pm »
I'm paying $2.99 for "real gas" locally.. well worth it tho...
 :great: :great: :great: :great:
Offline who me?
  • COG#: 11932
« Reply #169 on: February 04, 2019, 01:11:21 am »
After my morning run with the C13 I got the C10 out for a short ride and filled it up for commuting this week
72 this afternoon and decent weather predicted thru the week
95 C10 The Mule
02 C10 parts are parts
Offline The Doctor
  • COG#: 12886
« Reply #170 on: February 04, 2019, 03:12:52 am »
Changed the front and rear wheel bearings Friday. Sat at home in the rain Saturday, pouting. And finally took her out today to some twisties now that the weather clear up. Smoooooooth. My first time actually taking the ol' gal into Red Rock (the twisties in my backyard that I'm familiar enough to genuinely play with). She's a lot lighter on her feet than I expected  ;D
It all started on a 250...
« Reply #171 on: February 04, 2019, 04:13:23 pm »
That's a clean looking machine, and the scenery ain't bad either...
What were the temps in that part of the world?
As you get more used to the Connie, she'll even feel better on the road.
Offline The Doctor
  • COG#: 12886
« Reply #172 on: February 04, 2019, 07:52:09 pm »
It was about 60 degrees F or so. It's the rainy season in Vegas, so we get sprinkles once a week or so.
The paint need some work. It's just old and weather beaten, so that's on my (increasingly shrinking) list of things to do. Along with suspension, new windscreen, and a new seat.
Offline Boomer
    • Boomers GTR Site
« Reply #173 on: February 04, 2019, 09:46:16 pm »
Already have a ZZR1200 shock, have cartridge emulators to fit soon, LEDs everywhere, Rifle, Russell, heated grips, Delkevic, full tank bra, braided hoses and Nissin front calipers. What I was looking for was a farkle or idea I've not heard of before. :D
Wickford, UK
CDA-007
Offline CRocker
  • '02 C10 CDA # 416
« Reply #174 on: February 05, 2019, 12:26:58 am »
Ran it for a while in the garage to warm up the coolant...and, make sure the leak is coming from the washer under the water pipe drain bolt...sheesh...the only part I didn't replace... :-[
