Author Topic: Rear wheel conversion question  (Read 937 times)
Offline esmoojee
« on: June 06, 2018, 04:21:39 pm »
Hey guys,
So my question is this... what should the diameter of the back brake disc be with the mean streak rim? It calls for a Front disc off a Vulcan Nomad but according to the specs they are 320mm. It says to cut down a rear disc off a Mean Streak to 280.  Wouldn’t the nomads need to be cut down as well? Or am I confused? The stock rear disc on a Nomad is 270... couldn’t I just use a Nomad rear disc?
Re: Rear wheel conversion question
« Reply #1 on: June 06, 2018, 07:47:40 pm »
Offline esmoojee
« Reply #2 on: June 06, 2018, 08:02:15 pm »
Thats where I got the info from. It states that the mean streak needs to be cut to 280mm but the nomad front rotor stock is 320mm. I’m just wondering why you would cut a 300mm disc and not a 320mm disc.
Offline Jim Snyder
  • COG#: 7055
« Reply #3 on: June 06, 2018, 08:03:17 pm »
My conversion had the rotor on it when I got it and my stock rear caliper and bracket worked fine.
Offline esmoojee
« Reply #4 on: June 06, 2018, 08:11:08 pm »
Thanks Jim, did you buy it from a member here or on ebay?
Offline Kelly E
  • Geriatric Hooligan
« Reply #5 on: June 06, 2018, 08:40:14 pm »
I just bought a pair of nomad front discs(I can't remember the year) disc's last month off of fleabay and they are the correct 280mm diameter with 7 mounting bolts for $50. I have test fit the disc to the wheel and now all I need is to have the machine work done and wear out my current tires. :)
1994 Kawasaki ZG1000A-The Long Rider
1984 Honda VF700S Sabre-The Bike
1986 Honda CB700SC Nighthawk S The Hooligan Bike
Offline esmoojee
« Reply #6 on: June 06, 2018, 09:09:29 pm »
Interesting, maybe the specs i’m reading are off.
Offline esmoojee
« Reply #7 on: June 06, 2018, 09:33:11 pm »
Yea, the specs I found were definitely wrong. Thanks everyone!
« Reply #8 on: June 06, 2018, 11:42:12 pm »
Yes you have to order one more rotor bolt and as the old stock rim had 6 bolts and the new rim has 7.
I believe that is a typo and should be .030 and not .300
I did the new rotor from Murphs
A FRONT brake rotor from a Kawasaki Vulcan Nomad, 1999-2004, either used or Kawasaki P/N 41080-1447-CM, or EBC P/N MD4150RS
That is a great mod to do.  :great: :great:
2000 Red C10 1052 kit
Offline Jim Snyder
  • COG#: 7055
« Reply #9 on: June 07, 2018, 12:19:28 am »
If you need and extra rotor bolt I have several extra. Just PM me your address and I will mail you a couple.
Offline Kelly E
« Reply #10 on: June 07, 2018, 12:51:29 am »
So it is .030 not .300. That could have sucked to take too much off the Meanstreak wheel. I sure am glad you said that, thanks.
Offline Yamahawk
« Reply #11 on: June 07, 2018, 02:11:33 am »
You know, re-inventing the wheel is not a bad thing, but really unnecessary. If you use the Entire Mean Streak wheel/caliper/rotor assembly, all you have to do to fit it, is machine off a small amount of the outer side of the caliper bracket. Then, clock the rotor at 8:30/8:45 to the rear of the disk, and make a longer caliper stay that catches the Mean Streak bolt hole. For rotor clearance, I cut the inner part of the 'U' bracket on the stay, and used the appropriate bolt and length to fasten it. Works great, have about 12k miles on the Mean Streak wheel done this way, saves all the cost go the wheel machining for more useful things.... :)
Charlie
All Things work together for good, for those who Love God, and are the Called according to His Purpose. - Romans 8:28
The Only Thing Necessary for Evil to Triumph...
Is for Good Men to do Nothing - Edmund Burke
Offline Yamahawk
« Reply #12 on: June 07, 2018, 02:17:02 am »
Offline Bob_C_CT
« Reply #13 on: June 07, 2018, 08:04:29 am »
I wholeheartedly believe the .300" depth is correct, I think I had more chips than .030" worth of metal removal would of produced.
I had to tap the rotor holes deeper and .030" metal removal wouldn't of caused a reason to tap deeper.
Someone that has done this not so long ago or has better memory than me please confirm.
Offline Jim Snyder
  • COG#: 7055
« Reply #14 on: June 07, 2018, 09:31:21 am »
It is .300. Check the article in the tech pages section under wheels that's where I just verified it.
Offline Bob_C_CT
« Reply #15 on: June 07, 2018, 10:27:12 am »
Jim, that's the article they are questioning. I remember printing out that drawing and do not recall marking it up from .300 to .030".
« Reply #16 on: June 07, 2018, 11:47:56 am »
I do believe that I am wrong and it is .30 which  when I looked back the machinist removed 7.62mm and I did have to retap the holes deeper
Sorry , my bad
Offline Yamahawk
« Reply #17 on: June 07, 2018, 04:56:05 pm »
.300" sounds reasonable, I had to machine off about .25" of the Mean Streak caliper bracket to fit up inside the Concours swing arm. I didn't use the Concours caliper and bracket, I used everything off of the Mean Streak, and that gave me the larger rotor and 2 piston caliper. I really like the way it turned out, and you could measure the distance between your swing arm and the Mean Streak bearing side spacer, and then mike the caliper bracket for how much to remove from the Mean Streak bracket. But hey... I like the Easy way, and the better braking is a plus!
Charlie
« Reply #18 on: June 07, 2018, 05:49:15 pm »
Just checked with Dennis/machinist;  He has machined several of the Meanstreak wheels.
He said; It is 8mm (.316) off the face. Same diameter. You have to machine the top of the lip after as well.
Offline who me?
  • COG#: 11932
« Reply #19 on: June 07, 2018, 08:41:29 pm »
Ill add my .02
I printed off the page took it to the local machine shop So whatever the page said that is what I had taken off and the concours brake paraphernalia bolted up with no problem
A big thank you to whomever figured all the tech stuff out and posted it up :great:
95 C10 The Mule
02 C10 parts are parts
