Author Topic: Roll rear wheel on a board for getting Connie on center stand  (Read 1100 times)
Offline LeeM
  • COG#: 12454
« on: November 07, 2017, 06:30:14 am »
This evening I could not get my Connie on the center stand. I was puzzled as I used to be able to swing the bike up on the center stand usually in  a single try.
I rolled the rear wheel of the bike on a piece of 3/4" plywood. Hoisting the rear wheel gave me just enough altitude that I could get the bike on the center stand.
Attached photo shows the wood and bike.
Thinking back to the last time I worked on the bike, I had been playing around with the rear air shock. The air shock pressure valve linkage was out of order.  I pumped the shock to 45 psi. The previous owner may have had the shock pumped to 65 or the shock may have been at 0 psi. In any case, I think playing with the air shock caused the bike to be hard to get onto the center stand.
Does the air pressure level in the shock make a difference in how the bike rides and handles? Is 45 PSI about right for a 220 lb rider?
Re: Roll rear wheel on a board for getting Connie on center stand
« Reply #1 on: November 07, 2017, 12:21:56 pm »
  I use a piece of 2 X 6. Stick it under the back wheel and drive up on it. Then I use the kickstand.
« Last Edit: November 08, 2017, 10:18:38 pm by Mettler1 »
Offline Victor Salisbury
  • COG#: 3673
« Reply #2 on: November 07, 2017, 02:14:03 pm »
The higher the air pressure in the rr shock, that raises the bike, makes it 'easier' to centerstand. No air in the rr shock makes it real challenging.
I have a 2X4, (with some non-slip on the bottom of it) I roll my back tire onto, easy peasy up on the centerstand.
Vic Salisbury
COG #3673
'97 Connie "The Grinch"
Sarasota, FL
www.cog-online.org
Offline Red Eagle
« Reply #3 on: November 08, 2017, 02:57:30 pm »
LeeM:
After reading your post and the replies, I checked my owners manual ['86 model]. The manual says for a 150 lb. rider, 7.1 lbs of air would be about right. I'm no math major, but I divided 150 by 7.1 and came up with 21.13 body weight lbs. I'm 200 lbs. on a good day, so I checked my shock air pressure and it read 10.0 lbs. which made my happy because that's what my math was close to.
Not sure if this is "the" way to figure it out and I'm sure other folks will chime in.
HTH,
Bob Young
COG #5753
Bob Young   COG #5753 C-10 A-1 CDA#307
Offline Warwgn
« Reply #4 on: November 08, 2017, 03:22:18 pm »
Another advantage of the car tire on mine, it is a piece of cake to put on the center stand now :beerchug:
Offline Sparkie
« Reply #5 on: November 08, 2017, 04:20:02 pm »
When I had my C10 I would use small pcs of 3/4" plywood and that would make all the difference in getting the bike up.  I'm a lightweight 160 lbs and usually kept the shock around 25-30 psi. You don't want to exceed max pressure which if I remember correctly was around 50 psi as you can damage the shock internals. But I would think that most guys at 200 plus lbs. need way more than 10 psi in the shock.  Of course its all personal preference but thats a pretty soft mushy ride.
2006 Kawasaki Concours (Sold)
2006 Ducati 620 Multistrada
2016 Yamaha FJR 1300A
« Reply #6 on: November 22, 2017, 05:06:05 am »
I borrowed this trick from you C10 guys to get my Z1 900 on the center stand. It used to be I could put one of those on the center stand no problem. now that I'm old its not as easy as it was back  in the 70's. The C14 is easy without a board.  Tim
« Reply #7 on: November 22, 2017, 02:57:52 pm »
Lee, fyi; max pressure in a C-10 rear shock is 50 psi.
In all the years I had my C-10 I kept 40-50 psi in it.
Recently I installed C-14 shock on my C-10.
I was setting the sag, and it dawned on me that the proper way to decide air requirements {on a stock C-10 shock} would be to set the sag height.
  ie: (Similar to setting preload on a spring), adjust air pressure to get the right sag. (approx. 30 - 40 mm)
If I'm right, I think you can adjust the air pressure just like they adjust spring preload.
This video shows an easy way to do the measurement's.
    https://www.youtube.com/watch?v=ZtzTyCKh5fY
« Last Edit: November 22, 2017, 03:11:46 pm by connie_rider »
Offline jacksdad
« Reply #8 on: December 07, 2017, 05:11:11 pm »
Just reading this post: Is it possible to service the standard C10 shock?
On my GPZ900R, I removed the tyre valve and tipped it over then pumped what little, 30 year oil was left inside, left it upturned for a few days to get out all the oil. I then refilled using a printer ink refill syringe, cannot remember what grade of oil, or quantity, has anyone done this on the C10 version?  :beerchug:
Offline Jim
  • Jim
Offline jacksdad
« Reply #10 on: December 07, 2017, 06:15:11 pm »
Thanks Jim!
I looked but failed to find this post, will be great if I can save my shocker, I just cannot afford a new one, and buying old, used parts is just a lottery  :)
Offline Thud300
« Reply #11 on: December 07, 2017, 08:54:17 pm »
One thing that makes a big difference with the center stand:
LUBE. Specifically, engine oil.
It's a lot easier to use if the pivots arent dry. But if you're scrawny like me you probably still need a board under the rear tire
1991 Voyager XII "Xaviera"
1989 454 LTD "Merlin"
