Author Topic: Shifter  (Read 635 times)
Offline Redbarron
  • COG#: 10045
Shifter
« on: May 24, 2018, 12:36:26 am »
Hello everyone:
Is their a cure for sloppy shifter syndrome or a kit that may still be available?
Thank You
Offline BobT_MA
Re: Shifter
« Reply #1 on: May 24, 2018, 10:54:19 am »
Re: Shifter
« Reply #2 on: May 24, 2018, 12:31:00 pm »
 My C10 usually had problems getting into second gear. Would have to click the shift lever twice to get to second gear. ::)  Yeah, it's really too bad but T Cro's shift linkage is no longer available . :'( There is a pic of what it looks like. It was one of the best upgrades I installed on my C10!!  :)
« Last Edit: May 24, 2018, 10:06:45 pm by Mettler1 »
Offline m in sc
Re: Shifter
« Reply #3 on: May 24, 2018, 01:12:24 pm »
https://www.mcmaster.com/#rod-ends/=1czbq0h
https://www.mcmaster.com/#coupling-nuts/=1czbqi0
and drill and get some nuts/bolts. done. you get the idea.
 :beerchug:
Offline DC Concours
  • 2001 Concours, ~19K miles
Re: Shifter
« Reply #4 on: May 24, 2018, 02:29:24 pm »
There is a problem like this? what do you mean sloppy? mine has no issues.
Offline m in sc
Re: Shifter
« Reply #5 on: May 24, 2018, 03:03:56 pm »
some do, some dont. Mines good, but ive seen other bikes with same setup where it was super sloppy.
on a few i have had, if the rivet is loose on the arm, i will take it off and carefully weld it back down to the arm. (usually seems to be hondas for some reason) if the ball joint is loose, i drill it out and use a rose joint (heim joint).
Offline Big D
