Author Topic: Shock Adjustments  (Read 1091 times)
Offline Wess
  • COG#: 8010
Shock Adjustments
« on: August 02, 2008, 06:19:00 pm »
I have had Pearl for a year and am ready to start fine tuning her.  Would you folks please explain to me the dynamics of the two shock adjustments, air and clicks (specify from all the way in please)?      I am 6' and weigh 230 lbs.      I mostly commute super slab runnig GT's and while I enjoy the twisties I am too old to be extreme.  Respectfully Yours!  Wess Heavner  COG #8010 CDA #0239
Respectfully Yours!
Wess Heavner
Independence, MO
Offline Eddie-FL
  • COG#: 7073
Shock Adjustments
« Reply #1 on: August 02, 2008, 06:45:00 pm »
Wess, adding air serves the same purpose as spring preload on a non-air shock. More air = more preload. The Damping adjustment controls rebound damping. Position 1 (all the way in) is the lightest setting and 4 is the heaviest. I weigh 175 and usually run about 10 PSI and #2 solo and 35-40 PSI and #3 two-up or with the bags loaded. Rebound damping controls how fast the shock recovers after a bump. #1 is fastest and 4 is slowest. Hope this helps.    Eddie  2005 Concours  1969 Triumph Bonneville  AMA# 686667 COG# 7073 CDA# 0136   http://picasaweb.google.com/Eddie753
Anderson, SC
Offline Paulie
  • COG#: 4561
Shock Adjustments
« Reply #2 on: August 03, 2008, 07:50:00 am »
Yer Conc OM has a clear how-to on p108-113 to getcha started. Fer detailed tech n theory, google "motorcycle sag". Enjoy!   01 Conc, Mijami Floriduh  Over the Pond 06: http://tinyurl.com/2vk9o2 route map: http://tinyurl.com/4p7pmd
