Author Topic: Smell gas? what to do?  (Read 346 times)
Offline alex9078
  • Livin the Dream
  • COG#: 11853
« on: April 22, 2018, 01:52:43 am »
When I first check out my bike and I do smell gas, should I call for a tow truck and take it to a dealer in Danbury Kawasaki? I don't have the room or garage to attempt anything with my bike. I did replace my front and rear tire, but I am using my neighbors garage so I don't want to push it. I am looking for other Connie riders in Sandy Hook or Newtown to ride with before June when my monsters come to the LakeHouse from NYC. We will be there sometime around the end of April. Looking forward to getting in some riding to Kent for a cup of coffee and conversations. I will be the Marine with the Marine Corps vest, and the blue Connie. Hoping I can meet some Connie riders there.
Offline Bob_C_CT
Re: Smell gas? what to do?
« Reply #1 on: April 25, 2018, 12:56:29 pm »
I’m in southern Ct. not sure if your asking or telling about smelling gas as you say your not there until end of the month. How long has it been sitting? I usually dump the gas out of the tank in the beginning of season and start off with fresh fuel.
Offline Locomotiveman
  • COG#: 12297
« Reply #2 on: April 25, 2018, 03:29:17 pm »
Reach around with yer fingers near the Petcock. If damp AT ALL you have a problem to fix. QUESTION: How full is the tank? Is there any chance it was chock full and warmer weather expanded it to overfull?
« Reply #3 on: April 25, 2018, 07:48:37 pm »
Over Flow Tubes- You need these ASAP. Maybe you have them- most likely you dont.
 If you dont you better get them installed. Please  There are videos you can watch or get help to remove the carbs and send them to Sunny Steve to have them installed, better yet get them serviced while they are off. Dont out this off please. It is very very important.
There is a little nipple on the bottom of each carb. put a small tygone tubing/ hose on that nipple and blow- if it is blocked then you dont have over flow tubes installed
2000 Red C10 1052 kit
