Author Topic: speedometer needle vibration  (Read 462 times)
Offline JL
  • COG#: 775
« on: April 23, 2018, 11:31:09 am »
On my "new to me" 06 the needle starts to shake at 50 mph on up. Its not a jump just a vibration. 18k on the odometer.
Any help would be appreciated.
Offline works4me
  • COG#: 10594
Re: speedometer needle vibration
« Reply #1 on: April 23, 2018, 12:55:53 pm »
Remove the speedometer cable from the wheel hub.
Pull out the inner cable and inspect for damage.
Replace with a new one if there is any.
Online WillyP
« Reply #2 on: April 23, 2018, 01:12:20 pm »
Remember that lubes and rubber parts deteriorate and metal parts corrode even when the bike is not being ridden... a 12 year old bike is still 12 years old even though it may only have 18k on the odometer. Everything needs to be taken apart, inspected, cleaned and lubed.
And remember also... do as I say, not as I do!   :D
Offline Greenie
  • COG#: 1019
« Reply #3 on: April 26, 2018, 01:48:49 pm »
Last time I looked for speedometer cable lube I came up dry. Not much call for it any more with these new fangled speed sensors.
« Reply #4 on: April 26, 2018, 08:10:57 pm »
 :rotflmao: :rotflmao: :rotflmao:
Its right next to the Synthetic Blinker Fluid, on the shelf at the Unobtainium store.... :rotflmao: :rotflmao:
Just pull the cable out, slide the innerds out and wipe it clean with a solvent wetted rag, pump the old grease gun a half dozen times, and wipe down the cable liberally with that general purpose grease and insert it back in... done deal...
 :great: :great: :motonoises:
Offline Nosmo
« Reply #5 on: April 27, 2018, 12:22:02 am »
I don't know about speedo cable lube, but these guys do have the blinker fluid, etc: ;D
http://www.kalecoauto.com/
2003 Connie    2007 Wee-Strom
Offline Greenie
  • COG#: 1019
« Reply #6 on: April 27, 2018, 06:31:33 am »
The problem with grease is that it gets thick in cold weather - which will cause the speedometer needle to jump - as I found out when I tried using grease on a pickup truck speedometer cable. It might have only been at really low temperatures that you'd never see on a bike but I can't remember at what temperature it did cause problems.
