Author Topic: Stalling problem  (Read 1084 times)
Offline Neil_Schlosser_AB
  • COG#: 7615
Stalling problem
« on: July 13, 2008, 11:52:00 am »
I'm relatively new to my '06 Concours and have a strange, intermittent stalling problem. The typical situation is I've arrived at my destination, put the bike in neutral but leave it running as I maneuver to park. When I put it back in gear (still running) to move forward again, as soon as the clutch starts to engage the motor dies! (not due to lack of rpm either). Restarting and trying again results in the same behavior. It must be shut off with the key and restarted before things work again as expected. Anyone know what is going on here?
Offline 2linby
  • I rode today, did you?
  • COG#: 5539
Stalling problem
« Reply #1 on: July 14, 2008, 12:04:00 am »
Neil,    Could be several different things. I'd start with chekcing your clutch switch and connections and your side stand switch and connections first. Could be something simple like a wire being disconnected..  AKA "2linby" That's 2-lin-by folks!  Northwest Area Director  COG #5539  AMA #927779  IBA #15034  Team Oregon MC Instructor    http://community.webshots.com/user/2linby  http://tinyurl.com/njas8 (IBA BunBurner Gold Trip)  http://tinyurl.com/lwelx (Alaska trip)
Stalling problem
« Reply #2 on: July 14, 2008, 01:25:00 pm »
If the side stand is down then that is what the bike should do.  It is a safety feature.  If the side stand is down and the bike is in gear then as soon as you let the clutch out it will die.  If the side stand IS up then the switch is not working correct and needs to be cleaned or is bad??? since its an 06.  Do you drive on cruddy roads a lot.  ----------------------------------  I will answer any question.  It is up to you to figure out if I should have.    <p align="left">My Photos<br
  • COG#: 7615
Stalling problem
« Reply #3 on: July 14, 2008, 02:27:00 pm »
I'll bet my ignorance of the sidestand switch is the problem.  Most likely, as I'm parking, I've already got the sidestand down while fine tuning my park.  I'll test and report back - thanks!
