Author Topic: Steve's coolant recipe  (Read 1154 times)
Offline The Dude
  • COG#: 11820
« on: October 27, 2018, 05:45:46 pm »
No matter what combination of key words I use, I cannot find SiSF's coolant recipe.  Can someone help me out?
Past: '84 KZ700, '91 VFR750
Current: '02 CONCOURS (Smooooth Project #3)
Offline Sailor Rich
  • COG#: 9318
Offline Nosmo
Re: Steve's coolant recipe
« Reply #2 on: October 27, 2018, 06:30:55 pm »
If water wets, and water-wetter wets wetter than water, does water-wetted water wetter wet wetter than water-wetter?
2003 Connie    2007 Wee-Strom
Offline Lee
  • COG#: 12558
« Reply #3 on: October 29, 2018, 05:21:02 pm »
Other discussion info related to my experience with cocktail.
http://forum.cog-online.org/concours-c10-zg1000-general-chat-and-tech/coolant-cocktail!/msg635546/#msg635546
Offline Lee
  • COG#: 12558
« Reply #4 on: October 29, 2018, 05:23:55 pm »
Approximately 104-106 oz total. Of which 12oz is Water Wetter, 56 oz 50/50 Asian formula antifreeze, 36-38 oz  or so distilled H2O. Fill to high point of pump bleed then close bleeder, fill to thermostat bleed then close. Run to warm only to remove any remaining air. Thermostat needs to open. Replace Rad Cap. Place remaining mix of fluid in reservoir. As stated could not find any pump lube that did not contain leak stop additive. So I left that out of mix substituting distilled water. Also used a antifreeze calculator, found on net to figure freeze point temperature. There are many out there and some discrepancy between them. This is just a bastardisation of Steve's formula found on COG search and modified for my expediciency. Did as he has indicated, dramatically lowered temp. My fan has yet to turn on at long idle in traffic anymore. Something it was doing frequently before change of new fluid combo. Thanks again Steve
Offline Cali Cruiser
  • COG#: 12770
« Reply #5 on: October 29, 2018, 06:58:18 pm »
It’s no different than what everyone runs in track and race bikes- been going on forever.
Offline CRocker
  • '02 C10 CDA # 416
« Reply #6 on: October 29, 2018, 07:02:49 pm »
Stop it... :rotflmao:
Offline RWulf
  • COG#: 7122
« Reply #7 on: October 29, 2018, 11:20:44 pm »
All the race bikes I ever ran had to have straight water and no additives.
All that extra stuff makes the track slippery.
And Nosmo, you just mess up my night.
Offline Tour1
  • COG#: 9226
« Reply #8 on: November 02, 2018, 02:59:02 am »
I mixed up a 30% coolant version of Steve's formula.  Using a quart bottle as a measuring tool.  I think I did well but I have a question.  I used Dex Cool that says it should be 50-50 minimum coolant.  It was the only stuff that specifically said non-silicate on the label.
So just for giggles I put a bit of mix into a zip lock sandwich bag and put it in the freezer.  I didn't mix the mix like I would for paint or resin, but it didn't have any swirls in it or any tequila sunrise effects.
The pic shows the mix after a day in the freezer.  The wife put food in or out and said she found the baggie on the floor then put it back in.  The thermometer on the top shelf of the door said 25F.  I could feel flakes of ice in the bag but they were not strong, they crused or maybe even mused although I was carrying the back around the house by then.  The mix definitely did not freeze.  Not sure how it would perform after running around an engine or what 'normal' antifreeze does below freezing.
1987 Concours
Offline Tour1
  • COG#: 9226
« Reply #9 on: November 02, 2018, 11:45:08 am »
Update: After 8 hours without opening the door to the freezer the temperature on the top shelf was at 20°F and the formula was still liquid, say 99-44/100% liquid.  I still saw some of the slush flakes but could not feel them.  They seem to be from a very thin layer at the top surface.
Fresh water ice floating on salt water can cut through the wooden hull of a small boat, according to folk wisdom.  This stuff is well contained by a dollar-store zip lock bag so it is definitely not very strong.  Outside temp reach 0°F here sometimes and I am going to store my bike outside this winter.  I'm thinking of saving the formula for the springtime or just bumping the Dex ratio up to 50%.
Any thoughts on this from folks north of 40° latitude or having info about Dex Cool?
1987 Concours
« Reply #10 on: November 02, 2018, 01:40:06 pm »
The more coolant , the less the heat shedding effect. I believe I covered that in the writeup. steve
Offline Tour1
  • COG#: 9226
« Reply #11 on: November 02, 2018, 09:37:14 pm »
I get that part  :great:
What I read in an article about Ethylene Glycol (not propietary or other coolant mixes) is that (confession: I just googled it) it melts/freezes at 8.78°F.  I expect it would make a bad impression on customers if they found their antifreeze frozen in the bottle, so maybe they premix some H2O in to lower the freezing point to the minimum expected storage temperature.
I can continue my experiment outdoors all winter, the gallon of SISF formula will be stored in an unheated garage alonng with what's left of the distilled water.  I haven't had any bottles burst in the past.  The record setting low temperature 2 towns from here was -3°F.  That would dictate a 37% ethylene glycol mix.  Looking at the chart again I may have remembered the °C value instead of the °F.   That makes the most sense since I've been running 50-50 and a 37% version of the formula should be an improvement.  I'm still not sure it's wise to assume that Dex Cool is virtually pure ethylene glycol.
1987 Concours
Offline Lee
  • COG#: 12558
« Reply #12 on: November 02, 2018, 10:27:57 pm »
HIGHER H2O RATIO BETTER COOLING
HIGHER ANTIFREEZE RATIO BETTER FREEZE PROTECTION
Would strongly advise those C10 owners in all hot states to use any of the online antifreeze calculators to mix coolant/antifreeze by temp range you will see in your area.
This will insure maximum heat transfer from engine to outside air. This is more important than protection against a low temperature you will never see.
Most bikes and cars are overdosed with antifreeze!
Offline SteveJ.
  • COG#: 5603
« Reply #13 on: November 03, 2018, 12:35:14 am »
Living in FLA I only need protection to about 20*
However, IIRC, you need a minimum of 33% coolant for lubrication and corrosion protection, assuming no other additives.
Tick Tock, baby (Ironbuttal)
Offline Tour1
  • COG#: 9226
« Reply #14 on: November 04, 2018, 01:13:47 pm »
Just an update on the experiment:  I put the thermometer on the bottom of the freezer with the baggie of SISF 30% mix and left it... I'll say at least overnight.  This morning it read 8 degrees F and I didn't see any of the slush flake effect at first, then only a little as I kneaded the bag.  Unlike the 1st time I couldn't feel any solid/gel.
I'm thinking either the mix wasn't mixed well or it was affected by the frequent door opening and 2 feet of warmer air rising to where the thermometer was on the top shelf.  It's an under-counter model with a front door so the cold air spills out the bottom when the door is opened.  The thermostat is at mid height if I recall correctly.
I still need to bump the coolant ratio up to 37% to reach -3F per an online ethylene glycol chart.
1987 Concours
Offline Tour1
  • COG#: 9226
« Reply #15 on: November 04, 2018, 03:39:46 pm »
DST --> EST gave me an extra hour this morning so I'll adjust the % this way:
I need 7% more coolant so 128/.93= 137.63 total oz.
137.63-128= 9.63 oz. pure coolant to add
9.63/32= .301 = need to about .3 of my quart bottle measuring instrument.
That should handle the coldest night on Long Island, NY.
1987 Concours
Offline Tour1
  • COG#: 9226
« Reply #16 on: November 07, 2018, 02:55:29 pm »
 :deadhorse:
Dayum!  I found an old coolant tester and (a few days after adjusting the Dex Cool percentage)  the tool says I'm at maybe +8F protection.  That stuff is not pure ethylene glycol unless the Water Wetter is very differnt.  There isn't much WW in there anyway.  I am glad I didn't just put this in my bike.  Of course nobody would respect blazing a traiL of compromise between the instructions on the bottle and the wise men of COG.
1987 Concours
Online MAN OF BLUES
« Reply #17 on: November 07, 2018, 09:19:21 pm »
 :-\ :-\ :-\ :-\ :-\ :-\ :-\ :-\ :-\ :-\ :nananana: :rotflmao: :rotflmao: >:( :-\
we are now in the process of banning you, from any coolant post, because you uttered the words "DEX-Coool"
the worst invention of coolant, from GMC, to ever surface as a reliable, coolant.
the horror, the horror... DEX Cool... OMG... burn at the stake the horror...
not kidding, it ruined every GM vehical I owned, and cost me tons of money to correct, and repair... green coolant is good.... orange is bad... ummmkay?
 :truce: :truce: :truce: :rotflmao: :rotflmao: :rotflmao:
Offline Tour1
  • COG#: 9226
« Reply #18 on: November 17, 2018, 03:09:38 pm »
MOB, you could have mentioned something similar to this little tidbit I found by googling ( no endorsement intended):
Quote from: holidayautomotive.com
Can you mix other coolants with Dex-Cool?
Technically, you can mix coolant types but before you go ahead and do it, let's cover some things. Firstly, Dex-Cool and traditional anti-freeze don't mix well. Though they can work together in a pinch, after extended use, they can react and create a gel, which can be very damaging to multiple components of your cooling system.
react and create a gel?
 :-[  :-[  :-[  :truce:  :truce:  :truce:
« Last Edit: November 17, 2018, 03:15:08 pm by Tour1, Reason: trying to fix the quote thing »
1987 Concours
Offline Lee
  • COG#: 12558
« Reply #19 on: November 20, 2018, 04:13:35 am »
Precipitates from mixing antifreeze types plugs radiators and other mischief. On hot tempered C10 would think this to be suicidal for cooling system and head gaskets. Scary stuff nightmares are made of.
Offline Tour1
  • COG#: 9226
« Reply #20 on: November 20, 2018, 01:40:29 pm »
It's got me wondering if the gel-flakes visible in my photos are a product of Dex-Cool plus Water Wetter.  There's no standard anti-freeze in the mix.  My gallon bottle was windshield washer fluid (empty and dry) rinsed twice with tap water then once with the distilled water.
  Also in a brilliant move (not) to make room in the gallon of DC-SISF-mix I dumped some in the coolant reservoir of my ford.  I'd like to just declare a loss & put this stuff on the curb with a "free" sign but it seems wrong not to take it to a dump.
  This mistake began (for me) because of the non-silicate coolant mandate.  If anybody who knows why it has to be non-silicate is still reading this thread, please tell me why the recipe says non-silicate?  My old coolant is just coolant, not much descriptive text on the bottles of cheap stuff.
1987 Concours
Offline bajasam
« Reply #21 on: November 20, 2018, 01:53:23 pm »
i wouldn't worry about dexcool, that formulation was back in the 1980's over thirty years ago, todays dexcool isnt the same as it was 30 years ago. if your really worried mix your recipe in whatever ratio you choose in a clear container and set it on the shelf for a week or two or heat it cool it whatever you want, i promise you it wont gel or form flakes or whatever any other wives tale senario. just dont cheat and put in a box of cherry jell-o.
Offline cra-z1000
  • Keeping it upright..
  • COG#: 9790
« Reply #22 on: November 21, 2018, 01:38:05 am »
+1
Hasn't changed much if at all.
1987 C 10
80 Kawasaki KZ 1000 MK 2
74 Honda 750 four ss
73 Suzuki 550 triple
72 Honda 550 four
Offline Fix ur Critter
« Reply #23 on: November 21, 2018, 09:41:08 pm »
+1
/quote]
Amazing how bad/false/old information never goes away. humans have a hard time accepting new facts.. Dex-cool has been used in MILLIONS and MILLIONS of cars for many many years with out a problem.. but I knew a guy, that had a cousin..
Be Kind, especially to the innocent
Spay/Neuter always
Show interest to a kid, they will remember it for life
Offline CRocker
  • '02 C10 CDA # 416
« Reply #24 on: November 21, 2018, 10:27:34 pm »
Now...that’s funny!
