Author Topic: Tank damper location  (Read 341 times)
Offline Jeff in Des Moines
  • COG#: 11054
« on: August 10, 2013, 10:02:53 pm »
I pulled the gas tank on my 2006 for its 12,000 mile service and found that the tank was contacting the frame 3 1/2 inches forward of the square damper. The horseshoe damper was located 9 inches forward of the square damper. Is this the correct location for the horseshoe damper or should it be farther back or farther forward?
Thanks. Meanwhile on to the the valve clearance check!
Later, maybe this fall, I'll introduce myself, get my CDA patch, and make it to a Midwest meet up.
Re: Tank damper location
« Reply #1 on: August 11, 2013, 12:07:12 am »
  My horseshoe rubber is on the frame between the front and rear coil mounts. At the front of the tank there should be 2 round rubber bumpers mounted on a steel peg on both sides of the frame. The tank slides over these first and then the tank rest on the other rubber cushions. Some times the round ones fall off when removing the tank. Find them and glue the securely back on the pegs so the stay there forever and ever. They can be a bitch to find down there in netherland.   Hope this helps.
  • COG#: 11054
« Reply #2 on: August 11, 2013, 12:42:49 am »
Thank you!
That will move it back two inches from where it had been. Thanks so much!
Just picked up the feeler gauge to check the valve clearance. It was more of an effort than expected to get to this point.  So far everything seems in really good shape. This is my first motorcycle.  Had it about three months but put on 1/4 its miles. :-)
