Author Topic: Tcro's stick coil replacements  (Read 577 times)
Offline Derick
    • BeginnerBikers.org
  • COG#: 11628
« on: August 10, 2017, 12:03:43 pm »
Has anyone figured out what coils are compatible with Tony's stick coil system? I reached to him on this project bike and got no reply. I'm just worried about the 06 which has the stick coils and when they fail. Not sure what to replace them with....
Current Bikes:
Offline Eddie-FL
  • COG#: 7073
Re: Tcro's stick coil replacements
« Reply #1 on: August 10, 2017, 01:02:58 pm »
He uses different ones. Mine were from a 2004-2007 Honda CBR600RR (not the F4). Tony's usually good about responding.
Anderson, SC
1969 Triumph Bonneville
Offline RWulf
  • COG#: 7122
« Reply #2 on: August 10, 2017, 01:37:49 pm »
I make a set for another bike I have that had a bad coil.
I think they came from  one of the smaller Kawasaki. They
are almost all the same (I think). Got 4 off E-Bay for $35.
If making your own be sure to get the connects.
Offline Outback Jon
  • COG#: 9506
« Reply #3 on: August 10, 2017, 02:49:10 pm »
Sadly, thanks to Photobucket's big "FU" to their clients, the pictures from this thread are gone, but there is still a list of stick coils that will work.
https://www.tapatalk.com/groups/gtr1000/stick-coils-a-how-to-for-the-gtr1000-t4707.html
You can use any of the following:
Suzuki Partnumber 33410-35F10/35F00 (Denso p/n 129700-4400/4150, COIL ASSY,IGNIT, fits the following models:
Suzuki GSX-R600 2001 (K1)
Suzuki GSX-R600 2002 (K2)
Suzuki GSX-R600 2003 (K3)
Suzuki GSX-R600Z 2003 (K3)
Suzuki GSX-R750 2001 (K1)
Suzuki GSX-R750 2002 (K2)
Suzuki GSX-R750 2003 (K3)
Suzuki GSX-R750 2004 (K4)
Suzuki GSX-R750 2005 (K5)
Suzuki GSX-R750 2000 (Y)
Suzuki GSX-R1000 2001 (K1)
Suzuki GSX-R1000 2002 (K2)
Suzuki GSX-R1000 2003 (K3)
Suzuki GSX-R1000 2004 (K4)
Suzuki GSX-R1000Z 2004 (K4)
Or Kawasaki: ZX10/14 (04-07) oem p/n 21171-0005/1.5 ohms
ZX9 (99-03) + ZX12 (03-05) oem p/n 21171-1265/1286
Z1000 (03-07) + Z750 (05-06) 21171-1286
Z1000 denso p/n 129700-4580/1.5 ohms
ZX6 oem p/n 21171-1282/mitsubishi#F6T560
ZX9 denso p/n 129700-3630/1.3 ohms
ZX10 mitsu.#F6T549/560
ZG14/08(Concours) # F6T560
Cost can vary considerable - bike wreckers I approached wanted $40 to $70 each so I waited and lurked on eBay until I got a set of Kawasaki ZX9 stick coils for $65
The coils must be 1.3 to 1.5 ohms each - measure this with a volt/ohm meter - and check the ohms of the connected probes before measuring the ohms of the coils - a probe on each coil connector (+ and -) then subtract the base ohms of the leads and you have the ohms of the coil.  This is important because we are going to wire the coils up in series and total ohms should be between 2.6 and 3.0 ohms for a pair of stick coils.
I then bought a wiring loom from a Suzuki for $20 and modified that for the GTR1000.
Offline Derick
  • COG#: 11628
« Reply #4 on: August 10, 2017, 06:47:19 pm »
Thank you sir, that's perfect...and yeah photobucket has pissed me off various times because of their BS...and I dont even use them!
Current Bikes:
Offline Outback Jon
  • COG#: 9506
« Reply #5 on: August 10, 2017, 09:16:21 pm »
That thread had some really good pictures along with the instructions.  That, along with a few emails to Tcro, and I had my stick coils wired up and firing on the first try.
Then I had to get one of Tcro's shifter linkages.   ;D  Figured he should make a couple of $ off me for the help he willingly gave on the coils.
« Reply #6 on: August 10, 2017, 11:52:01 pm »
   TCro's shift linkage!! :)   No more missed shifts. No whimpy shift linkage ALLOWED!!!!
           http://forum.cog-online.org/c-10-emporium/heavy-duty-precision-shift-linkage-for-zg1000/
