Author Topic: New Concour owner here, bike fires right up then sputters and dies  (Read 105 times)
Nosmo and 1 Guest are viewing this topic.
Offline CJ
So, first I apologize if this is something I should of already found, but I've been searching for a few days to no prevail.
I recently was lucky enough to received a 2002 zg1000 for a mower I had gotten for free. Now it definitely has come with a few issues, but so far I've already managed to fix the clutch, neutral safety switch which was causing a no start situation without the clutch. Throughly cleaned, and rebuild the carbs as recommended, even spent a ridiculous amount of time setting floats due to one bowl having a broken drain screw (my luck). All of which are even with the mating line while level on a jig I made. Hooked it all up, and planned on syncing them, but it starts and runs great for about a minute then starts to stutter proceeded by shutting off. When I immediately try to crank i usually get a nasty backfire, however when I wait a minute it fires right up agaian, but with the same issue after. I've checked the resistance of the pulse coils (450ish on both at the connector) and I have power to each coil (with a nice big blue spark).
Free power mod gas been done.
Please help, I've had the carbs on and off at least 10 times in the past few days.
Also, thank yall for the wonderful forum.
P.s. thought it may be fuel supply, or a high fuel level, but it does it even if I remove my "auxiliary tank" (a makeshift German mineral spirits bottle) for a bit.
« Last Edit: Yesterday at 09:40:00 pm by CJ »
Re: Igniter Testing
« Reply #1 on: Yesterday at 09:33:41 pm »
Double check your work on the free power mod.  If the connections aren't solid, it will cause a stutter.  DAMHIK
quick, free check... look again at your plug wires, make sure the left coil wires go to plugs 1 & 4, and the right coils wires go to 2 & 3...
the backfire is a tell tale sign...
Offline CJ
Left coil wires red and black go to 1 & 4 in relation from sitting on the bike, red and green go to 2 & 3. Previous owner did a stick coil conversion so they're ran in series. Coils read correct resistance but I would be sure if he cross which side of the coil the wires run to. Would that cause an issue like this?
Note: the backfire is when I try to start it again
I think Rich was referring to a stock coil setup.
Offline CJ
I know, my apologies for failing to iclude the bike has a rather significant aftermarket mod that may be related to my problems 😅. Curious if the previous owner hooked the polarity of the coils up backwards...
I dunno... probably not... it ran before, right? I guess without having my grubby paws on the bike, all I can ask is "is the right coil, attached to the right plug? (not specifically meaning "right hand", but "correct" should have been the term..)
sounds like the stick coils are not on the correct plugs... thus the engine "runs" and dies, and fuel is in the exhaust, and backfires when re-started..   internet diagnosis is soooo hard... sorry. :'(
Offline CJ
No worries, any information is welcomed and helpful since I have only had the bike a week. As for the coils being on the correct plugs, I belive so, right now the bikes basically naked. So it looks like the set coming from the red and black go to 1&4 and red and green set go to 2&3.
I will definitely double check though and get back to you!
Thanks again 🙏
Offline CJ
Note: received the bike in a non running condition without knowing if it ran for a while before... which soo helpful i know... especially when asking people to help diagnose an issue they can't hear, and hope I'm delineating the issues properly too..
But it does fire up and idle smooth for close to a minute or two lol (just a tease). Not sure if that still means  it could be incorrect firing order
if you don't have an IR thermometer, try this... when the bike starts, and runs, have a wet rag handy... then, when it dies, take the wet rag, balled up, and touch each exhaust pipe, pay close attention to "how hot" each one is, if they all are the same temp, and react the same when "touched", you can count out "coil" failure... as the culpret.. well maybe, stick coils can "break down", but as a whole, they are pretty reliable.
Re: New Concour owner here, bike fires right up then sputters and dies
« Reply #10 on: Yesterday at 10:23:47 pm »
the backfire thing is still posing me the question, as this is a result of fuel in the exhaust, that never got burned during operation..
Offline CJ
« Reply #11 on: Yesterday at 10:29:28 pm »
Will do 👍 and I'll let you know. As for the accessories at the igniter. Should they have power when the key is off and kills witch off? Sorry if this is a doh question
Offline CJ
« Reply #12 on: Yesterday at 10:31:52 pm »
Well... think I found one issue.. the yellow wire on the starter solenoid is hooked up to the battery side, not the starter side.
« Reply #13 on: Yesterday at 10:47:30 pm »
hmmm
yellow goes to relay box.... cant say what is up with that... it's on the starter side, not the batt side...
 now I haveto look, and see what could end up as a "result" of that mis wire.. sometimes nothing bad, sometimes... well, bad things happen.. worst case is pretty much fuses, and a relay box... but not saying you need a box yet.. correct the wires, via the FSM... and make sure it's correct...
« Last Edit: Yesterday at 10:51:10 pm by MAN OF BLUES »
Offline CJ
« Reply #14 on: Yesterday at 11:08:26 pm »
All 4 exhaust pipes sizzling
« Reply #15 on: Yesterday at 11:53:32 pm »
ok, coils are right...
Offline CJ
Well.. long night with no success. Cleaned every ground with a wire wheel on a dremel including the main engine ground.
Although my stator seems to be finicky... it was reading a solid 14 until it got warm, now it's back and forth and has a draw on the battery once plugged in...
So I guess this means taking it to be tested.
Some good news though, pickup coils continue to read 450ish ohm even when hot.
Runs for about 5 minutes now, then a nice rough idle (sounds like lots of misfire) right before it dies.
Sidenote: igniter gets pretty warm as well during all this testing. Anyone know the testing procedure there? Or should I just start searching for one in the classifieds?
Thanks again MOB for helping diagnose and eliminate a few things so far 👍
