Author Topic: Maintenance and the new owner  (Read 130826 times)
Offline turbojoe78_MA
  • COG#: 8645
Re: Maintenance and the new owner
« Reply #125 on: October 15, 2016, 12:30:40 pm »
I have a 2001 game 1000 concourse it runs good at the low-end speeds but I can't get like beyond 80 miles an hour it has no power on the highway I have the aftermarket carburetor kit with the sponges that controls the air I wonder is that getting enough fuel or not getting enough air  any help out there
Your problem seems simular to a problem my friend had on his 88 C10.  He said it seemed to run fine at low speeds and his idle was fine but it would not go over 80 to 85 mph on the highway.  This all started after he did a valve adjust so he knew it should have gone much faster than that.
I went over to help him check over the valve adjust he had done and long story short his problem turned out to be he had put his plug wires on numbered to the firing order instead of the cylinder numbers.  The #3 and #4 were swapped so he was only running on the #1 + #2.
Rock,  start your bike and let it warm up a little then check the header pipes with a laser temp gun or by spraying water on them to see if their all getting to around the same temp.
The wires on the left coil should go to the #1 plug (left most plug when sitting on the bike) and the #4 plug. (right most plug)  The wires on the right coil should go to the #2 and #3 plugs.  (two plugs in the middle)  The cylinders are numbered 1-4 going from left to right when sitting on the bike.
« Reply #126 on: October 15, 2016, 02:25:15 pm »
I did notice some fuel leaking from the herb box where the filter goes in once it does look a lot
Can you explain this sentence?
If you have fuel leaking into the air box, you have carb problems.
One thing we haven't thought of is insufficient fuel.
If your lacking power at higher rpm's or under load, it's possible the fuel line is kinked and your not getting enough fuel.
Sometimes the kinked fuel hose if fine until the engine heats things up.
It doesn't cause problems until the engine heat softens the hose and allows it to bend a bit more.
Check your fuel line...
Offline Corlitoa
« Reply #127 on: November 02, 2016, 02:48:05 am »
Hi guys I'm new to this group I just got my Concours 1000 2 weeks ago and I'm loving it I just have a quick question about the cam chain tensioner mine is making a small rattling noise when idling is there a way I can adjust the original one or I just have to buy a new one I don't want to get the manual one I was reading something about taking the middle school out and type in it in the center will the screw goes with a small screwdriver and then reinstalling the spring and the pin again
« Reply #128 on: November 02, 2016, 02:19:30 pm »
You have the idea right.
If your bike makes the noise primarily at idle until it warms up,,, it may help.
How many miles on the bike?
Carefully remove the top screw.
  (Be careful when you do as a spring and small pin will jump out).
Put a flat ended punch or screwdriver in the hole.
It will rest against the adjuster when inserted.
Give the punch a sharp tap. (Don't bash the hell out of it).
If there is sufficient chain slack the adjuster will move to the next step and quieten the motor.
Re-install pin/spring top bolt, and see if it helped.
NOTE: All Connies have a certain amount of chain noise, I suggest you compare with others.
I suggest; join the club and come ride with us.
                Then you'll have lots of Connies to compare with and I guarantee you'll like the group!
Offline Grant
  • HOTROD TRUCKS & BIKES
  • COG#: 12666
« Reply #129 on: June 03, 2017, 01:50:50 am »
Well Steve and his YouTube videos is what brought me to COG . Ihave to say sounds like solid advice, bikes do fall over the plastics on mine are proof  :))
Offline kurt
« Reply #130 on: October 12, 2018, 12:36:22 am »
ok , I just rejoined and cannot find my topic so thought general topic forum might be the place to ask.  So my bike has been in the garage and not ridden in four years. Now retired, it is time. But reading all the hydrolock issues I get the fear of it.  What I do not see, cannot find, is an article on. Once a bike is coming out of storage, what is the procedure. I would guess, replace all liquids etc. But the main question is now that I am worried about hydrolock, I assume as long as there is no gas in the tank there shouldn't be a problem ? Do I , should I,  pull the carbs, should I pull the spark plugs and squirt a few drops of oil into cylinders.  I think I am over thinking this. but there must be an understood list of steps.
thanks
Offline Pbfoot
  • COG#: 10807
« Reply #131 on: October 12, 2018, 08:38:24 am »
Kurt.  Change the oil. If the bike was stored with fuel stabilizer, dumping all the old fuel and adding a gallon of new and attempting to start would be what I would do. At some point I would replace the petcock as well. If not, the carbs need to be pulled to check for green goo.
« Last Edit: October 12, 2018, 08:42:28 am by Pbfoot »
