Author Topic: Valve adjustment without removing pickup coil cover?  (Read 818 times)
Offline captainporksword
  • COG#: 12668
« on: August 29, 2017, 09:26:49 pm »
I noticed in Steves video on valve adjustment he just tapped the starter to turn the crankshaft. Am i missing something or does this mean i can just take the valve cover off and not worry about lining up the TDC mark eyeballing the position of the lobes.
Offline Harry Martin
  • ☺ Cartoonist ☺
  • Fear is not boring
    • Harry Martin Cartoons
  • COG#: 4090
Re: Valve adjustment without removing pickup coil cover?
« Reply #1 on: August 29, 2017, 09:52:47 pm »
That's how I been doing mine for years.
As long as you do it right...it comes out right.  :)
Harry in Wild and Windy Casper, WY - 1986 Vintage "Silverdammit" - 2015 "Greendammit"
Offline VTconnie
  • COG#: 11081
« Reply #2 on: August 29, 2017, 10:45:00 pm »
Pull the plugs to make the engine turn real easy, good time to check or replace them anyway.
Offline GeorgeRYoung
« Reply #3 on: August 29, 2017, 11:59:22 pm »
There's also a little plug that let's you see TDC without having to take the whole cover off.
  • COG#: 12668
« Reply #4 on: August 30, 2017, 02:31:21 am »
started doing it by the book its so annoying to prevent the screw from moving while torquing the nuts wish i got that little wrench from murphs too or had crows foot wrenches
Offline Jim
  • Jim
« Reply #5 on: August 30, 2017, 11:01:38 am »
If you have the shop manual, check section 4-20.  You can use the marks on the cam sprockets when they line up with the top of the head.  Looking at the sprockets, with EX and IN markings upright, and the mark (line) is lined up with the head, adjust
Intake : #2 and #4
Exhaust: #3 and #4
Rotate engine until EX and IN are inverted, and the mark (line) is lined up with the head, adjust
Intake : #1 and #3
Exhaust: #1 and #2
« Last Edit: August 30, 2017, 11:14:55 am by Jim »
Offline Grant
  • HOTROD TRUCKS & BIKES
  • COG#: 12666
« Reply #6 on: August 30, 2017, 12:03:58 pm »
Just ensure that the valve you are adjusting is on the base circle of the cam. I haven't done my Connie yet but on all the others with the plugs out bike on the center stand or Jack and in 6th or top gear it is easy to reach out grab the rear wheel and rotate the engine to the point you need...
Offline kkja13
  • Tyler, TX
« Reply #7 on: August 30, 2017, 01:48:58 pm »
+1 for the 6th gear wheel rotate method.
2004 C10
2003 Suzuki SV650s
« Reply #8 on: August 30, 2017, 01:55:34 pm »
That's all you really need to do. Just turn the motor until a cam lobe faces away from the lifter. Adjust all the valves that have the lobe facing away from the lifter, then turn the motor until another lifter is on the base circle... adjust some more... turn again... Keep a chart of which ones you have done, so you don't miss any.
  • COG#: 12668
« Reply #9 on: August 30, 2017, 04:27:28 pm »
nice to know for next time i highly regret buying new throttle cables too getting that deeper one on is frustrating
Offline SteveJ.
  • COG#: 5603
« Reply #10 on: September 01, 2017, 11:37:48 am »
Leave the old cables in place if you haven't removed them yet. It makes it a lot lot easier on the side of the road to hook up your spare and they won't take up space elsewhere. You may want to put them back in place at your next service.
Make sure to wrap the ends with good black tape (3m) to keep crap out.
IBA 19221
Offline VTconnie
  • COG#: 11081
« Reply #11 on: September 02, 2017, 12:36:01 am »
That is a really good idea, I will do that when I install the new cables I have waiting.
Offline Bob_C_CT
« Reply #12 on: September 02, 2017, 01:23:55 am »
I have to ask, Steve J you mean to wrap ends with good electrical tape of the spare set you stow away and not to add the tape as part of an install, correct?
97 C10,ZRX Front, Meanie Rear
Offline SteveJ.
  • COG#: 5603
« Reply #13 on: September 02, 2017, 10:46:20 am »
the spare set, to keep corrosion limited
IBA 19221
« Reply #14 on: September 02, 2017, 02:42:16 pm »
That's assuming you are replacing cables while the old cables are still usable. Preventative maintenance!
Offline Bergmen
« Reply #15 on: September 02, 2017, 11:29:54 pm »
I always used the starter bump/plugs out method to position the cam lobes for adjustment. I start with #1 and watch the piston rise on the compression stroke (after intake valves close, watch piston with a flashlight). As others have mentioned, you do not have to be precise, just make sure the piston is close to TDC and you are good) I progress to #2, then #4, then finally to #3.
No need to remove any covers.
Dan
--2014 Yamaha FJR1300A--
--ZGRX 1200 Concours (sold)--
--SPOOFAK Inventor--
