Author Topic: Video of issue with low revs  (Read 447 times)
Offline crag antler
  • COG#: 8277
« on: June 16, 2019, 11:18:24 pm »
Still hunting for issue of low revs issues. Checked plug wires and caps. Seem to be tight.
Pulled carbs, checked diaphragms and all good w/ no tears, holes or issues.
Cleaned carbs again to check pilot jets were clean. Found one tip missing on pilot air screw. Replaced all 4 and adjusted to 2 turns out. Checked float level and all @ 17 mm at 45% angle. All per shop manual.
Still getting slight smoke out exhaust that smells like gas. Never did that before :-[
Included video of tonight’s run
https://youtu.be/RoiICvfQptA
Emailed SISF a week ago about carb service but have not heard back. Don’t know if he is still doing C-10 carbs or still unpacking. I know moving is a bear.
Doug aka crag antler
00 Kawasaki Concours 60,000+ miles. Bafflectomy,Bar risers, Murphs kneesavers, blockoff plates, allen head screw set,headlight upgrade. LED headlight, driving lights, free power mod, JC Whitney trunk, Go Pro mount,’06 header w/Jet-Hot ceramic coating, over flow tubes, 2 minute mod, carb spa and Performance Exhaust Sprocket by SISF,fairing extenders, CAT O-ring cruise control
Offline Pbfoot
  • COG#: 10807
Re: Video of issue with low revs
« Reply #1 on: June 16, 2019, 11:24:08 pm »
1-1/4-1-1/2 turns out are what I've seen on stock Concours.
Offline batboy
  • COG#: 12983
« Reply #2 on: June 16, 2019, 11:42:14 pm »
I have done tons of searching for carb info lately. The most common number of turns for the pilot screw from what I saw was 1.5 to 2 turns. I wrote this down in my notes, think Steve S. said it: "Set carbs pilot screw to 2 turns out and forget it."
EDIT: Service manual says 1-1/2 turns.
« Last Edit: June 17, 2019, 12:22:51 am by batboy »
Offline DC Concours
  • 2001 Concours, ~25K miles
« Reply #3 on: June 17, 2019, 01:13:03 am »
Your idle is good. It burped a little around 600 rpm. Is that what you are talking about?
Offline crag antler
  • COG#: 8277
« Reply #4 on: June 17, 2019, 08:46:43 am »
The concern is when it gets to the 2000 RPM’s and hits a wall.
Should be able to keep climbing but doesn’t. With the slight smoke and all, I’m thinking of pulling the valve cover and checking the valve specs again.
I only really did 3 things to the motor.
Valve adjustment, exhaust sprocket install and carb cleaning.
My thinking it has to be one of these three or....
Still keeping the faith as I know what she is capable of :motonoises:
Offline batboy
  • COG#: 12983
« Reply #5 on: June 18, 2019, 12:54:15 am »
If you are running poorly at higher RPM, that sounds the opposite of problems with pilot jets. So many thing could make it fall flat as RPM increases.
« Reply #6 on: June 18, 2019, 01:02:52 am »
what screws did you use? OEM Kaw, or the K&L "kits"..?
also, did you make sure to account for the flat washer and o-ring, under the spring, on each needle screw? jussssst checking...
K& L kits have a slightly longer/and gentle taper, and often as I have found, actually respond best at 2 to 2-1/2 turns out..
Offline crag antler
  • COG#: 8277
« Reply #7 on: June 18, 2019, 08:52:26 am »
OEM w/ new washer and o- rings, in the proper order :rotflmao:
