Author Topic: CDA Broken Right Mirror (mount only??) Help!!  (Read 1167 times)
Offline Pastor Miller
  • COG#: 12629
« on: August 17, 2017, 02:43:48 pm »
(Not sure if the first post came through...)
So I rolled up to a parking spot on a slopped lot. Dropped on the right side. Sigh...Broke the right mirror bracket, I think. PLEASE help with these questions:
1. Clymer says I need to take off the lower, middle, and upper fairings to get at the mirrors. Is that right?? If not, how do I easily get at the mirros?
2. Where is the best place to get a new mirror bracket or other replacement parts for whatever is broken?
I really do NOT want to take this to the local bike shop to get it fixed when I think I could do it with a little help from my friends :-)
PLEASE help a guy out.
Thanks in advance!
Re: CDA Broken Right Mirror (mount only??) Help!!
« Reply #1 on: August 17, 2017, 04:40:17 pm »
I am not sure if anyone is issuing new numbers for drops anymore?
If I were you I would post your repair question to the correct area.  There you may get an answer faster.  I hope to never know the answer.
  • COG#: 12629
« Reply #2 on: August 17, 2017, 06:53:29 pm »
I did fix it without removing all the fairings (or any of them, actually.)  Which would have been the proper area?
Offline Jerdurr
« Reply #4 on: August 18, 2017, 12:45:48 pm »
Had the same problem a while back: zero speed drop, slopped road, couldn't find my right footing, by the time i did, weight was already too much due to angle, bike went down on the right side.
hated seeing the mirror all scuffed, so I purchased a new one.
To install it, you need to remove the upper right cowling (the black flimsy plastic that covers the upper right side of the tank). I believe you also need to remove the side fairing, but don't quote me on it. maybe these pictures will help you
http://www.pbase.com/fredharmon/mirrorchanges
Kudos to Fred Harmon for putting it together!
Cheers
Best,
JD
