Author Topic: Did NOT drop my 2014 C-14  (Read 494 times)
Offline Nickrides
  • Nickrides
  • Nickrides
« on: April 20, 2020, 09:38:07 pm »
I removed both wheels in my garage.
My bike was on the centerstand and stickered up under the oil drain area and headers. With wooden blocks.
It looked so precarious.
I made a sign for the family
Do Not touch under the Penalty of Death!
Got both wheels back on AOK
Offline Harry
  • Cartoonist at large
  • Fear is not boring
    • Harry Martin Cartoons
  • COG#: 4090
Re: Did NOT drop my 2014 C-14
« Reply #1 on: April 20, 2020, 09:42:28 pm »
The day is young.
Offline gsun
  • CDA #560
  • COG#: 9127
« Reply #2 on: April 21, 2020, 01:10:23 pm »
I don't think you have to remove the engine for a valve set. But it would be easier to do! ;D
What the heck made you do that?
Offline Nickrides
  • Nickrides
  • Nickrides
« Reply #3 on: June 13, 2020, 01:30:22 pm »
gsun
I had both wheels off so my tire man could put on 2 new tires.
Nick
Offline gsun
  • CDA #560
  • COG#: 9127
« Reply #4 on: June 14, 2020, 06:41:33 pm »
I think that should have been for a different thread!
Offline Texas Concours14
  • COG#: 9760
« Reply #5 on: June 15, 2020, 12:21:22 am »
I am not that brave. I deal with one wheel/tire at a time. But it worked out for you.
2010 Concours 14
Offline Ted
« Reply #6 on: Today at 01:27:11 am »
I have 2 motorcycles and the other one is a Busa that sits on the Harbor Freight bike lift.  I had to new tires to put on and put my Connie on the lift.  Even though the weight difference on paper doesn't seem like a big deal i could tell the stability factor was a little sketchy.  I used the center stand for the rear and kept the lift in the fully down position.  I have the wheel lifts for both front and back and used the front one for the first time on the Connie.  It wasn't  the greatest fitment and I had to maneuver things a bit to make everything clear with the axel coming out.
Here is where it got scary.  I wanted to detail the bike and I have already built a custom Kick stand bracket ( for the Busa )  because I wasn't going to do any wheel work beside cleaning the front wheel.  I can do the rear wheel with the center stand on the floor.   I have engineered one of those Harbor Freight double roller dolly that allows you to rotate your front wheel.    Its bolted into the deck of the lift and makes getting things cleaned up a bit easier on the front wheel.
Anyway... once I pumped up the lift and tested the stability of the bike lift I was spooked.  It seemed to be delicately balanced so I put it back down.
My solution?  I like to build stuff and do a little welding so  I am going to build a stabilizing system that can be engaged once its up to working height.  Looks like a weekend project to me...  a chop saw, clamps, grinder, and a my little wire feed and it shouldn't take to long... or so it would seem anyway.   :)
