Author Topic: Signature Line Rules & Creation  (Read 19036 times)
Offline Forum-Admin
« on: August 14, 2008, 01:47:00 pm »
Rules
All signatures should not exceed the following size limits.    4 lines normal size, 8 lines small size and up to 90 chars per line. (Blank lines count as lines.)    For images in signatures: 1 image up to 300 pixels wide, 125 pixels tall and 20k in size    Duplicate links to the same URL in a signature are not allowed.
How To
Create a custom signature block:
First navigate to your profile: Profile > Forum Profile
There you will find the Signature section where you can add text and images to your profile.
You are able to add formatting tags similar to HTML to highlight or bold your text etc and add a link to an image image hosted elsewhere on the web. For example the code in a signature block can  look like this:
Code: [Select]
[b]Fred Blogs[/b]
[i]Bottle Washing Officer[/i]
AMA# 1082227
ROK# 20033345
[URL=http://rides.webshots.com/photo/2447706780100596652fCpIlv][IMG]http://thumb12.webshots.net/t/75/75/7/6/78/2447706780100596652fCpIlv_th.jpg[/img][/URL]
The b and /b in the square brackets says the text inside the brackets/braces is to be bold,
 the i and /i is to italicize the text.
The text/code for the image and link was taken straight from my Webshots account.
To copy the code above select the "select" link above and copy to your clip board and paste it into note pad or whatever to edit it with your own text and image link and then copy that to the signature section in your profile
It looks like this:
Fred Blogs
AMA# 1082227
ROK# 2003345
« Last Edit: December 08, 2010, 01:52:45 am by colinp386 »
Offline Shaft-Drive
    • Simon Sullivan Music
  • COG#: 9469
Re: Signature Line Rules & Creation
« Reply #1 on: May 07, 2011, 05:46:36 pm »
Dear Forum-Admin:
Is using a Webshots type of service  common practice due to storage limitations on the COG site?
I already have way too many Internet accounts, and I'm trying to simplify my digital existence:)
Cheers,
Simon
Offline Colin
  • I'd rather be riding!
    • Facebook
« Reply #2 on: May 07, 2011, 11:14:12 pm »
Good question.
Truth is that that info was originally posted up for the original forum that did not support server-side images.
This one (Simple Machines) does so you can use them.
it's not so much an issue of space as performance. The more files that are stored on the server the slower it will get . However that's not an issue at the moment, and probably never will be.
Bottom line is if you want to use the server store go ahead, but note there is a size limit.
Cheers
Colin
Colin Prior
Offline Shaft-Drive
  • COG#: 9469
« Reply #3 on: May 08, 2011, 04:49:15 pm »
Colin:
Thanks for the info. I'll give that a try. My "visited maps" are only 5KB each, so they shouldn't present any problem to the COG server.
Cheers,
Simon
Offline S Smith
  • Northeast Area Director
  • COG#: 3184
« Reply #4 on: May 08, 2011, 06:39:26 pm »
Colin:
Cheers,
Simon
IIRC, pics in sigs must be linked images.
| Steve Smith | COG #3184 |
BECOME A COG MEMBER
Offline Shaft-Drive
  • COG#: 9469
« Reply #5 on: October 30, 2012, 07:05:28 pm »
Okay, I have tried three different times to code my sig. to include my "travelled states" map from my PhotoBucket page, and this is the closest I got. No image shows up, but the word "image" is a hyperlink.
I couldn't HTML my way out of a paper bag.
Anyone have any suggestions?
Here's my block of dysfunctional code: SimonSullivan
2003C10
[IMG]
Ooh, boy, I just pasted it in, but it won't show up on the page. WTF?
Thanks,
Simon
« Last Edit: October 30, 2012, 07:10:54 pm by Shaft-Drive »
Offline S Smith
  • COG#: 3184
« Reply #6 on: October 30, 2012, 07:17:28 pm »
Simon...  does your tag line look like what you want now?  (the size is dictated by Photobucket's thumbnail size) The URL used was not correct.  View your profile to see what the code looks like now.  This is easily creatable by using getting the link from Photobucket's "share" button, click on the "Get Link Code tab" and then copy the entire code text for  "IMG for bulletin boards & forums -> clickable thumbnail"
BTW - pasted code in the post is treated the same as in the sig line.... the forum code will try to interpret & display it.
Hope this helps.
« Last Edit: October 30, 2012, 07:19:42 pm by S Smith »
BECOME A COG MEMBER
Offline JimO
  • COG#: 10132
« Reply #7 on: December 05, 2012, 07:08:21 pm »
I don't think I added the tag, Big Wheels, on my signature and I can't seem to find out how to delete it. Can you help?
Artaxerxes had served with great reputation in the armies of Artaban, the last king of the Parthians, and it appears he was driven into exile and rebellion by royal ingratitude, the customary reward for superior merit.
- Gibbon, The History of the Decline and Fall of the Roman Empire
Offline S Smith
  • COG#: 3184
« Reply #8 on: December 05, 2012, 07:10:42 pm »
That field is a humorous ranking field based on post counts and can not be removed.  More posts graduate user up the riding scale. Look at others rank titles to see the different ones.
BECOME A COG MEMBER
Offline JimO
  • COG#: 10132
« Reply #9 on: December 05, 2012, 07:30:59 pm »
Thanks. I wondered where it came from....
Offline Shaft-Drive
  • COG#: 9469
« Reply #10 on: December 14, 2012, 04:03:12 am »
Hope this helps.
Steve:
Okay, now the map shows up. And I did nothing in the meantime (during my 6-week coffee break from the Forum:).
I'll read your suggestions again, Steve, when my brain's working a little better.
As always, thanks.
Simon
Offline S Smith
  • COG#: 3184
« Reply #11 on: December 14, 2012, 10:23:00 am »
Hope this helps.
Steve:
As always, thanks.
Simon
Simon - we fixed the typo in your sig line for you.
BECOME A COG MEMBER
Offline Shaft-Drive
  • COG#: 9469
« Reply #12 on: December 17, 2012, 08:28:19 pm »
[/quote]
Thanks, Steve. You rock.
Simon
