Author Topic: Valve adjustment costs  (Read 7807 times)
Offline Fred_Harmon_TX
  • COG Technical Editor
  • Industry Member
    • Angel Ride Videos
  • COG#: 2170
  • Membership Level: Tech Editor
« on: April 18, 2013, 02:04:12 pm »
Just curious, those of you that have taken your bike in to a dealer and had the valves adjusted on it, what are the dealerships charging you to do this service?
Fred H.
Concours 1400 Maintenance Videos
http://www.angelridevideos.com
Offline thundermax
  • COG#: 11056
Re: Valve adjustment costs
« Reply #1 on: April 18, 2013, 02:19:36 pm »
I am curious too. Fred, what do you think the charge should be considering doing the job right?
Riding since 1966 at 13. Just purchased my tenth bike in my life. Now have two at same time. 2009 C14 and 2012 C14. Here are bike I have owned: 1958 Cushman model 721 Highlander, 1960 Cushman Super Eagle, 1971 Honda SL 100, 1974 Yamaha RD350, 1975 Honda 750 Four, 1971 Honda SL 175, 1998 Vmax, 2005 Vmax, 2009 C14, 2012 C14. COG#11056, South Central Area, Oklahoma.
Offline azc14
« Reply #2 on: April 18, 2013, 02:51:15 pm »
$320
I had removed all of the plastic before i took the bike to the dealer
this was just to check the valves and replaced the plugs (plug cost was extra)
« Last Edit: April 18, 2013, 05:12:48 pm by azc14 »
2014 ZX14R
2008 C14
2008 ZX14
2008 Yamaha Rhino
2000 ZX12
Offline JPavlis_CA
  • San Jose CA
  • COG#: 2293
« Reply #3 on: April 18, 2013, 02:55:09 pm »
One of the big moto dealers in Silicon Valley quoted me ~$700 for the valve adjust. This included new gaskets for the valve cover and pulser cover. Did not include any needed shims or plugs.
I just did it for ~$150 in parts.
« Last Edit: April 18, 2013, 03:42:49 pm by JPavlis_CA »
All God's male children tend to be low-life, sleaze-ball, early apexers - Terry Earwood, Chief Instructor, Skip Barber Racing School.
Offline rsorrell2
  • COG#: 10440
« Reply #4 on: April 18, 2013, 03:30:05 pm »
my service cost me $500 for both the 15K and 30K and they made no adjustments and I just dropped it off without taking anything off or any prep.  Was a large dealer here in so. cal.
running mobile 1 syn oil
  • Industry Member
    • Angel Ride Videos
  • COG#: 2170
« Reply #5 on: April 18, 2013, 03:51:33 pm »
That's what I'm trying to figure out. I know its a huge job, and I suspect the actual hourly rate would be outrageous if they charge the actual time it takes to do the job.
Fred H.
  • Industry Member
    • Angel Ride Videos
  • COG#: 2170
« Reply #6 on: April 18, 2013, 03:53:15 pm »
So they charged you $500 and didn't even pull the cams or change any shims, correct?
Fred H.
Offline Mad River Marc
  • Moderator
  • COG#: 8442
« Reply #7 on: April 18, 2013, 04:55:06 pm »
Razee charged me $499 for the 30k service including checking the valves,  if they had to pull the cams it was an extra 90 bucks plus whatever shims they couldn't swap around...
You only need two tools in life – WD-40 and duct tape. If it doesn’t move and should, use the WD-40. If it shouldn’t move and does, use the duct tape.
Offline Ron
« Reply #8 on: April 18, 2013, 06:58:45 pm »
my local dealership quoted me $800 not including shims.
This is my shocked face...  ::)
Offline Russ
« Reply #9 on: April 18, 2013, 07:09:07 pm »
I was quoted $600 for a check, adjustment would be done on hourly + parts rate.
08 C14
06 KLR650
SOLD - 04 VT1100 Spirit, 01 VT750 ACE, 1986 VFR750F, 1991 CBR1000F
AMA# 2794531
Offline BDF
  • COG#: 9125
  • Membership Level: expired
« Reply #10 on: April 18, 2013, 07:30:45 pm »
Kawasaki lists the labor quantity for checking the lash on a C-14 at 3.2 hours. Yep, that is Earth hours, not Jupiter hours. My local dealer doubles that time and still can't make it although it is not a loser (below theoretical hourly rate but not actually losing money). The local dealer's rate is $75 / hour so that would be $480 at 6.4 hours not including materials used. They actually charge $500 as Marc said and another $90 if the cams have to be removed to actually change shims. So the job is profitable although not really generating the shop rate, just like most service jobs. Then again, it is more profitable to do larger jobs and sell labor in larger chunks; it is better for them to sell 6 hours of labor than it would be to sell 12 units of 1/2 hour labor at a time. There is just no way to get 16 units of 1/2 hour of labor into an 8 hour day- it would seem that it should work that way but it does not because of inefficiency moving between jobs, consulting a manual perhaps, procuring materials and parts, etc., etc. So on a larger job the service dept. will get closer to the actual stated labor rate than on a lot more small jobs.
The down side to the larger jobs is that it takes more skilled help to do those jobs just because they are more involved and require more knowledge and skill on the part of the technician. Not a problem for a competent, quality dealer but that is where the 'fly by night' dealers get into trouble.
Brian
KiPass keeping you up at night? Has the low fuel warning burned your retinas? Find peace, harmony and the answer to these problems
Offline rsorrell2
  • COG#: 10440
« Reply #11 on: April 18, 2013, 09:48:10 pm »
Fred
yup, $500 and no adjustments but that was for the entire 15K/30K service with the bike just being dropped off. No work on my part.
Offline RoadRocket
  • Carving Mountains in N.C.
  • COG#: 10781
« Reply #12 on: April 18, 2013, 11:04:42 pm »
Fred, I sense you have something up your sleeve.  ;) Are you going to be offering your services here in the near future  :great:
Just wondering
2011 Kawasaki Concours
2009 Suzuki Hayabusa
2003 Honda Goldwing
2006 Yamaha Stratoliner
2005 Honda ST
2002 Yamaha Roadstar
2001 Suzuki Hayabusa
2000 Yamaha Royal Star
2003 Suzuki Volusia 800
1999 Suzuki Intruder
1995 Honda Magna
1985 Honda Nighthawk
1974 Harley Sportster
Email: Roadstar515@bellsouth.net
  • Industry Member
    • Angel Ride Videos
  • COG#: 2170
« Reply #13 on: April 18, 2013, 11:26:33 pm »
Just wondering
I'm considering it.
Fred H.
Offline Ride&time
  • COG#: 11207
« Reply #14 on: April 18, 2013, 11:46:25 pm »
Theres a shop by me I went to for a wheel bearing. (to purchase) They tried to sell me a used bearing as new. I would let them work on my lawn mower - maybe for free. If I were rich I would have to find a shop I could trust 1st and cost 2nd.
Offline Andrew
  • COG#: 10516
« Reply #15 on: April 18, 2013, 11:46:49 pm »
I can find a reason for a trip to Texas I'm sure  :)
Offline runnerb0y
  • If you don't think too good, don't think too much.
  • COG#: 10517
« Reply #16 on: April 19, 2013, 12:02:48 am »
I'm sure I could too!  :great:
| COG#: 10517  |  2012 C14 - Candy Arabian Red  |
Offline JerBear
« Reply #17 on: April 19, 2013, 01:20:08 am »
Fred I have a sister in Texas that I really want to drive my bike to visit this Spring/summer.  I have your videos so I know you got it down.  Now you just need to figure out what you are going to charge.  I'd like to meet you anyway.
2008 Silverdammit C14
Offline David
  • COG#: 10605
« Reply #18 on: April 19, 2013, 01:28:19 am »
Fred, I do not know if you got my PM thanking you - I added the Top Blocks, did the work myself due to your patience in answering all my questions. Everything was as you said, thank you again. :great:
"Speed is fine but accuracy is final"
1976 BMW R90 RS
1992 BMW K100 RS
2000 BMW K1200 RS
2011 Kawasaki C 14
Offline mtnbandit
  • 2011 C-14 Black
  • COG#: 9917
« Reply #19 on: April 19, 2013, 01:34:16 am »
  Hi Fred;
 I paid $610 for the valve job, gaskets, 4 new plugs and an FI sync. This included removing and replacing the fairing as well as    finding the FOB key, that I had lost several months before, down in the fairing.   :)
 This was at Wilsons Motor Sports in Fresno, CA.
 Brent
mtnbandit
  • Industry Member
    • Angel Ride Videos
  • COG#: 2170
« Reply #20 on: April 19, 2013, 01:53:43 am »
Glad to hear it all went well. I get a lot of messages, and sometimes forget to respond to all of them.
Fred H.
Offline Old Man on a Connie
  • South West Area Director
  • COG#: 9932
  • Membership Level: Area Director
« Reply #21 on: April 19, 2013, 01:54:23 am »
I need to go take a rape shower. Had mine in for warranty repair of a weepy valve cover seal. Told the dealer your gonna be in there anyway. Cut me a deal on the 15k. Sure, we'll knock an hour of labor off. $720.00 bucks and NO ADJUSTMENTS!. Hell Fred, I'll fly you to Vegas, Put you up in my house for free, Give you your choice of adult beverage and treat you to a show on the strip. Help me adjust my suspension and I'll hook you up with my sister (OK, you probably don't want that)  :)) :)) :)). And the warranty work was done half a**ed. Travelling Fred road show. I think your onto something buddy.
"I don't always ride street bikes, but when I do, It's a Concours. A C14 '11 silver to be precise."
Offline gsun
  • COG#: 9127
« Reply #22 on: April 19, 2013, 01:54:57 am »
Fred - you did my valves for me and all it cost me was your videos! Thanks!
Offline David_Phillips_GA
  • Big Wheels
  • COG#: 8635
« Reply #23 on: April 19, 2013, 02:02:19 am »
I was quoted $700.00 - $1100.00 at the dealer ship where I bought my C1400. At another dealer I was quoted $650.00- $700.00.
So I went with the second quote, They made no adjustments to the valves. They did replace my front rotors under warranty and put new brake pads on that I brought with me. That was the 15000 service.
David.
David A. Phillips
Offline Texas Concours14
  • COG#: 9760
« Reply #24 on: April 19, 2013, 02:04:53 am »
Fred, I would be very interested in a 6 hour ride to the metroplex if you start doing valve adjustments. Please let us know if you are going to do this. Price is not the deciding factor for me; having the job done right is what matters most. Valve adjustment is the one job I fear screwing up (even with your excellent videos), and I don't trust local mechanics to do it.
2010 Concours 14
