Author Topic: MondoMotos - LED Lighting and lots more  (Read 51271 times)
Offline 4Bikes
Re: MondoMotos - LED Lighting and lots more
« Reply #200 on: November 27, 2015, 09:19:55 pm »
Brian, I have the MM-10's and like them. The finish however,  faded to a bronze and is no longer black.  Will the the new lights have an improved finish?  If they do, I'm thinking about a new set, and using the old MM-10's for my truck bed. I assume the plugs are the same, so the swap should be easy.
Offline Gumby
  • Black 2011
  • COG#: 10640
« Reply #201 on: November 28, 2015, 05:38:20 am »
Mine did the same thing.  ???
Brian already mentioned the new ones should be better.
Greetings COG members
Just a note to let you know the MM10 has received a third revision and we expect to start shipping the new light kits this week.
While the light housing itself remains very much the same (size/shape) and and utilizes the same CREE Chip, the Version 3 light offers two major refinements:
-   Interchangable Lens (Amber Option)
-   Powdercoat Finish (Further reduces possiblity of fading due to UV light)
We expect to start shipping pre-orders this week and new orders can be placed as soon as tomorrow.
Hope 2015 is getting off to a good start for all.
thanks,
-Brian
Offline MondoMotos
    • MondoMotos
  • COG#: 10575
« Reply #202 on: January 06, 2016, 05:17:42 pm »
Hello COG'rs
I apologize for the slow reply to the above. As with most I am sure, the holidays have kept me way too busy. The fading or bronzing issue was one we became aware of sometime in late 2013. At that time we asked our supplier to address the issue and as a result a second UV coating was applied to the lights in an effort to fend off what we thought might be causing it. It took several more months to determine if this indeed resolved the problem. As it turned out, it didnt really help. As it turned out bronzing or fading is a somewhat common problem with Black anodized metals. Also with black plastics/rubbers used on cars (my 2 year old jeep has seriously faded fender flares).Oddly, the fading/bronzing issue seems to be somewhat random and not effecting all the lights. We have the older lights installed on all the shop bikes and the ones that see the most sunlight (and abuse) on our DRZ rentals (arizona sun is quite powerful) show no bronzing after 1.5 years of desert riding and 1.5 years of day to day use back in Michigan.
One option for the faded lights is to paint using a high temp auto paint (the lights do get hot). Its a fairly easy thing to do. A little masking tape on the lens, clean the body of the light with alcohol (fast drying), spray a few light coats, let dry, remove the tape from the lens and you're set.
In short we started to look into other finish options for the lights. In 2015 we began to offer the Version 3 lights that use a different finishing technique and to date we havent heard of any further problems with fading/bronzing.
Going into 2016, operating MondoMotos has been and still remains a very important part of my life. I have and will continue to do my best to do so with integrity, honesty and fairness. That said, as a way of saying "thank you" to the COG community, we have  revised the current COG10 discount. In effect as of today COG members can use the new COG15 coupon code at checkout for a 15% reduction on the MM10 light kit.
Thanks and Ride Safe,
-Brian
« Last Edit: January 06, 2016, 09:25:31 pm by MondoMotos »
Thanks,
-Brian
  • OtP Co-ordinator (USA) (ie: Slave Labor)
« Reply #203 on: January 06, 2016, 05:26:32 pm »
Not sure why I haven't seen this discussion previously.
Definitely interested. Looks good.
Will do a complete read thru and make a decision.
  ($$ short as I just survived Christmas and my wife's charge card!)
14 Connie (Traveler II)
03 Connie (Buddy)
Offline flyboy3107
  • COG#: 11978
« Reply #204 on: January 09, 2016, 12:43:13 am »
I have a set of these, they are awesome! I have them mounted under my mirrors. I will take a picture when I get a minute.
Offline Sailor_chic
  • COG#: 11610
« Reply #205 on: January 11, 2016, 12:45:46 am »
Nice discount, however the lights are still out of stock. When will these be available to ship?
Nicole     Port St Lucie, FL.
2013 C14 Black
2006 Vmax
IBA # 60267
Offline MondoMotos
    • MondoMotos
  • COG#: 10575
« Reply #206 on: February 08, 2016, 04:36:52 pm »
Sorry for the late reply.
The MM10 Light Kits are back in stock as of Feb 2.
-Brian
Thanks,
-Brian
Offline Texas Concours14
  • COG#: 9760
« Reply #207 on: February 08, 2016, 05:15:46 pm »
Nice product with quick delivery. I recently installed the lights on my 2010 C14 and mounted them on Canyon Cages so as to have a larger triangle of light as per VP01 on page 8 of this thread.
My only complaint (too strong of a word - let's call it an "undesirable attribute") has to do with the wiring harness. The harness is plenty long but the length of the "Y" in the harness that supplies power to the two lights is too short to reach the left and right Cages after having to snake the wiring backwards to exit the body-ware plastic near the gear shift lever and rear brake pedal, respectively. There was a lot of soldering and heat shrink tubing involved to make the wires longer. Not a big deal but another 18 inches on the Y of the harness would have been convenient.
2010 Concours 14
Offline MondoMotos
    • MondoMotos
  • COG#: 10575
« Reply #208 on: February 09, 2016, 03:19:28 pm »
Thanks for the feedback.
We designed the harness to be as universal as possible and quite honestly, this is the first I have heard of anyone having an issue with any portion not being long enough.
I have done a few installs on Connies over the years and havent had an issue. That said, I havent done any installs on bikes with Canyon Cages. I can only assume that is what presented the issue during your install.
Would it have been beneficial to have Plug-n-Play "extensions"?
-Brian
Thanks,
-Brian
Offline Sailor_chic
  • COG#: 11610
« Reply #209 on: February 10, 2016, 04:22:09 am »
Brian, has the issue with the color of the housing fading been addressed?
2013 C14 Black
2006 Vmax
IBA # 60267
  • COG#: 9760
« Reply #210 on: February 10, 2016, 01:09:05 pm »
-Brian
Thanks for the response. Yes, the issue pertained to installation on the Canyon Cages. An option for extensions would be helpful for those who don't do the conventional mounting on front forks or mirrors.
2010 Concours 14
Offline AriBklyn
  • Got Mule?
  • COG#: 10574
« Reply #211 on: February 28, 2016, 08:50:39 pm »
I just came across this thread too. Usually only go to the forum section and C-10 emporium. Finally been seriously looking into adding some much needed extra lighting to my bike.
I've been looking in several places amazon, ebay, Murphs, etc to try to piece together everything I'll need including some type of bracket to mount the lights which I need, right?
Since I know nothing about things electrical or the difference between a relay and a wiring harness I won't know if I got everything I will need in order to install them. Also many of the pictures in the older posts aren't available anymore so hard to envision where and what they would actually mount to.
Have I reached the Garden of Eden...so, you're saying I won't need ANYTHING else in order to install these?
Thanks all!
Offline MizzouMike
  • "I'm like a rain magnet"
  • COG#: 8862
« Reply #212 on: February 28, 2016, 10:11:34 pm »
That is going to depend on where and how you are looking to mount them.   I chose to mount them as daytime running lamps.  The supplied brackets were not large enough for the stock C-10 caliper bolts, so I ended up purchasing the Denali mounts.   I really like the way they turned out, and you can't beat the price!
Thanks all!
« Last Edit: February 28, 2016, 10:26:26 pm by MizzouMike »
2000 Concours - "Red Foxx -2"
2001 KLR-650 - "Clara Bell"
AMA, COG, IBA
Offline AriBklyn
  • Got Mule?
  • COG#: 10574
« Reply #213 on: February 29, 2016, 06:36:15 am »
Thanks for the visual! Nice. The more I see it the more I'm starting to like that placement of the lights. Although that upper mount looks like Larry Buck's mount? That's what I had in mind originally but sadly he's not fabricating them currently.
Offline MizzouMike
  • COG#: 8862
« Reply #214 on: February 29, 2016, 01:52:46 pm »
Yes, it is a Larry Buck mount.  I really like it, The C-10 was my commuter for four years, and driving early/late during the dark drove my descision for the lights.   I installed the mondomotors as daytime running lights, as a very cost effective alternative to some of the other options out there.
AMA, COG, IBA
Offline robertv
  • Go Hawks!
« Reply #215 on: September 29, 2016, 03:57:25 am »
A buddy of mine wants to order these but currently shows out of stock! When is the next availability date for these?
-Brian
« Last Edit: October 23, 2016, 12:55:49 pm by DoerOfThings, Reason: fix quote »
2008 C14, silver [current]
2000 C10, red [sold]
Offline Irreverend Joe
  • COG#: 12367
« Reply #216 on: October 11, 2016, 06:30:19 pm »
-Brian
Hi, Brian,
The MM10 V3's are out of stock now, do you have a date for those yet?
Thank you!
2009 C14 non-ABS, Metallic Diablo Black, Area P full system, Canyon Cages (front and back), Murph's risers and wedges, Givi ES450 Monolock trunk, Phil's rack, Sargent low seat, Steve's flash, Top Block swing arm and axle sliders
2011 Honda CBR250R, not farkled much yet but I'm working on it
Offline robertv
  • Go Hawks!
« Reply #217 on: January 05, 2017, 08:29:02 pm »
Looks like these folks are changing their business as you can't order lights directly, only from ebay according to the site. Hopefully they update their site for those who need support or info as all the PDFs, pics/gallery is no longer available.
  • COG#: 12367
« Reply #218 on: January 05, 2017, 08:43:02 pm »
Thanks for the tip, Robert - I managed to hunt them up on eBay just now, their eBay seller name is Mondostore, which took me a while to find - they just have two listings (the lights and the superseal connectors), with some purported links (which are dead) to wiring harnesses and such.  Seller feedback is 0 at the moment - I'm thinking about getting the lights, but I'll probably wait until they're closer to being fully up and running.
Offline scout
« Reply #219 on: January 31, 2017, 09:14:14 pm »
MM10 LED Light Kit
A few posts back, the co. stated these lights would be available Feb, 2. Since it is recent, is that 2017? Right?
Have sent 3 emails to co. on avail. in the past few days- are they still in business?   ---No Reply uc=sing Ebay or the co. Website.
Any replies, thanks.
Offline robertv
  • Go Hawks!
« Reply #220 on: February 01, 2017, 08:36:17 pm »
That Feb 2 was of last year 2016.  Not sure what or why the business has changed including responses, but availability is now only via ebay under the products link from the site http://www.mondomotos.com/about.html
Offline Hawkdriver
  • COG#: 11777
« Reply #221 on: February 01, 2017, 09:51:26 pm »
FWIW - I've been using their lights for a couple years now and am still very satisfied.
Offline scout
« Reply #222 on: February 02, 2017, 12:01:48 am »
After so many try and fail, I give up - do not need another Advanced Sport Touring retailer in my dealings. I will politely recuse  myself from elaboration.
Offline Pat and Sher in MA
  • COG#: 7670
« Reply #223 on: March 15, 2017, 12:42:07 am »
I just went to the site and selected products and they list two different light sets and you can purchase using PayPal.
Seems to work for me but I'm not great with these computers so who knows.  :-[  Also not sure how the COG discount code
would work with the PayPal payment because I didn't go through the whole process.
Good luck
Pat & Sher in Ma.  04 C10 Dark Angel,  87 Ninja 600RX,  85 GPz 750 Turbo, 79 KZ1300 (x2)
Offline mattchewn
  • COG#: 10993
« Reply #224 on: March 15, 2017, 03:22:48 pm »
scout,
Mondo is not comparable to AST in any way shape or form. I also just checked their site, easy peazy PayPal deal. I have had a set of MM10's on my C14 for a couple years. Nicely done complete setup.
