Author Topic: Helmets with visors  (Read 5122 times)
Offline daddykevin
    • Smarter Investing
  • COG#: 9739
Helmets with visors
« on: August 08, 2011, 03:23:12 am »
My daily commute takes me into the sun both ways. Does anyone have any experience with a visor on a helmet? I'm thinking of the AFX FX-50 in Hi-Vis Yellow and wonder how the visor will behave during my commute.
Top speed is only about 50 on this daily ride, but I would like to use the helmet on group rides as well.
I'm running a Rifle windscreen, and don't seem to get any buffeting during my normal rides. My seat is standard height.
Thanks.
DaddyKevin
aka Kevin Nichols
Financial Planner/Hedge Fund Manager
Daily Commuter/Motorcycling Savant
Jazzy
  • Guest
Re: Helmets with visors
« Reply #1 on: August 08, 2011, 05:21:19 am »
I have an older Nolan 102 with the visor on the outside and it works fine for me. It's about time for a new one and I'll probably go for the N-103 or maybe the N-90. Both have the visor on the inside. You can get great reviews and videos on the revzilla.com website!
Offline Slybones
  • COG#: 6953
« Reply #2 on: August 08, 2011, 10:06:46 am »
http://www.super-visor.com/index.html
I tried one of these super-visor attachments to the helmet shield a while back on my Nolan. It worked pretty good. Never had it fly off or anything like that. When you ride into the sun, you just have to tip your head down some to get the right angle to block the run.  It also offered some shade it a sense. When the sun was just high overhead, it did the visor effect and nice there too. The mounting stuff came loose over time, and if you ever replace your faceshield you'll need new mouting stuff.
I saw someone at a regional rally with the sunshield strips that go across the top the visor, called sunblocker in this link. Its on my old Nolan now. Worked ok. Got in the way when the shield was completely down. Had to keep the shield flipped up at least a tiny bit to have clean view. When the shield down and head tilted worked good. Shield down and head straight it was partially obstructing view. So I kept the shield at least partially flipped up. Cold in winter.
New Scorpion has the buildin sun visor. Works nice when sun is over head. Could be better then the sun is straight in the eyes. They make different shades which would help that. But then wonder if it would be too dark otherwise. What I have done most this summer is ride with sun glasses for just regular sunny day viewing. then when the sun gets straight out in front, flip down the integrated visor. The combo of the sun glasses and the visor get the job done when the sun is straight in your eyes. -- Just not as nice on daily commute mornings where I might not have the sun glasses and then the sun is at the right angle.
2003 Concours, 121K
2005 GL1800ABS, 52K
COG #6953, IBA 28004
Offline daddykevin
    • Smarter Investing
  • COG#: 9739
« Reply #3 on: August 08, 2011, 04:19:43 pm »
I am currently running the Nolan N-100 with no visor. I generally keep the faceshield open for airflow (Texas!), but would close it if I had a visor. Is there a visor that will retrofit to the N-100? If so, I'd love to see it.
DaddyKevin
aka Kevin Nichols
Offline S Smith
  • Northeast Area Director
  • COG#: 3184
« Reply #4 on: August 08, 2011, 04:35:44 pm »
One of my helmets is a Scorpion EXO-1000. It has an internal smoke visor and full clear face shield. I like the flexibility.  Normally I just wear non-polarized sunglasses
Offline wild man
  • COG#: 6174
« Reply #5 on: August 08, 2011, 05:32:19 pm »
http://www.super-visor.com/sunblocker.htm
I've been using a similar product for about 5 years on my Shoei X11. Works really great when the sun is directly in front and well enough to the side.  I've got the insert postitoned so that I can tilt my head slightly and cover the sun when its just at the horizon.
Bill
USAF Ret, KC0IGL
AMA#333772, IBA#19247
2007 KLR 650, 1997 ATK 605
Offline Ranger Jim
  • COG#: 6720
« Reply #6 on: August 08, 2011, 11:13:59 pm »
I've used the Super-Visor and the SunShield products. Both work pretty well. I've also used a 2" strip of tape across the top of the helmet visor which also worked pretty well. You pays yo' money and you takes yo' chances.
JIM CULP
Offline wally_games
« Reply #7 on: August 09, 2011, 12:06:34 am »
My commute is also into the sun both directions. I have a Fogcity Speed Tint strip that fits on the inside of my clear RF-1100 shield. It works really well and is clear enough that you can actually see through it a little bit. It fits at the top but doesn't interfere with the faceshield seal. I've almost decided to put on on my dark smoke shield also.
http://www.cyclegear.com/spgm.cfm?L1=&L2=&L3=&L4=&item=TUC_55-0043_G
A buddy of mine just runs a couple of strips of black tape across the top outside of his shield. With a black helmet it's almost un-noticable.
Offline MizzouMike
  • "I'm like a rain magnet"
  • COG#: 8862
« Reply #8 on: August 09, 2011, 12:21:29 am »
+1 on the sunvisor...
http://www.aerostich.com/helmet-sunblocker.html
It works well, but I think I will go N103 when I replace my current full face lid.
« Last Edit: August 09, 2011, 12:23:59 am by MizzouMike »
2014 BMW R1200GS
AMA, COG, IBA
Offline Shiney
  • COG#: 8965
« Reply #9 on: August 09, 2011, 01:23:39 pm »
I cannot believe no-one has suggested a strip of electrical tape at the top edge of the visor. :-[
« Reply #10 on: August 09, 2011, 03:54:41 pm »
Greg I am even cheaper then that.   I just tilt my head down more.
Offline Necron99
  • rise again....
  • COG#: 9384
« Reply #11 on: August 09, 2011, 09:21:51 pm »
I wear transition riding goggles (sun glass frame, vented gasket) under my helmet.  I love that, because they change when it's bright they're light when they don't need to be.
http://www.bikershades.com/Riding-Sunglasses-with-Transition-Lenses-p/pc047phc-yellow.htm
« Last Edit: August 09, 2011, 09:23:26 pm by Necron99 »
Offline 2linby
  • I rode today, did you?
  • COG#: 5539
« Reply #12 on: August 10, 2011, 03:01:22 am »
A decent pair of safety sunglasses does the trick for me.  And if you are in need of "cheaters" this link gives you some great and very inexpensive, options.
http://www.safetyglassesusa.com/safreadglas.html#top
No affilliation........blah, blah, blah......
Offline AngryBaby
  • '08 Concours14
« Reply #13 on: August 10, 2011, 04:11:45 am »
I would like to try out one of the helmets by Arai or ICON that look like dirt helmets but are marketed for street use.  My only fear is that the big visor on the front would cause my head to get jerked around.  The visor on these would more than likely serve to block the sun.  Anyone have any experience with these????
The strip of tinting at the top of the shield seems to be the cheapest, quickest and easiest solution!!!!
Offline Ranger Jim
  • COG#: 6720
« Reply #14 on: August 10, 2011, 11:56:20 am »
Actually the cheapest, easiest solution is about a 1.5" strip of electrical tape (I think I pointed this out about 5 comments up).
JIM CULP
Offline daddykevin
    • Smarter Investing
  • COG#: 9739
« Reply #15 on: August 10, 2011, 02:23:25 pm »
AngryBaby, this is exactly what I am/was concerned about, and the reason for the original post. I would like to know if anyone has had experience with one of these helmets, and, whether or not, it has a tendency to pull your head back while riding at 70 mph behind a Rifle screen.
I get the electrical tape trick, and all the other ideas, all of which have merit. But, once again, last night, I fought the sun on my commute home. I need something else that is designed for the street, or I'm pulling out my 20 year old Bell Moto 6 with the 4" visor.
Best,
DaddyKevin
aka Kevin Nichols
Offline Slybones
  • COG#: 6953
« Reply #16 on: August 10, 2011, 03:41:13 pm »
So how far off is having one of those helmets, from attaching one of them super-visor attachments in the link posted earlier.  I never tried the super-visor with a shorty shield where the helmet was in lots of air flow all the time. I did use it for several years with no problems behind a normal height Cee Bailey shield. - I had it installed with one of the lift kits shown on that site. The thing I found was that I was needing to get a new lift kit every year or so, as it would start to come loose. I eventually tried one of the other strip ideas.  Its been a few years now, but I dont recall being annoyed with it yanking my head around. Not that it could not have happened, just that I did not find it a problem and remove it for that. It was coming loose again and I tried something different.
2003 Concours, 121K
2005 GL1800ABS, 52K
Offline AngryBaby
  • '08 Concours14
« Reply #17 on: August 10, 2011, 04:26:42 pm »
Electrical tape might work but it looks tacky...guess i actually should have said : The strip of tinting at the top of the shield seems to be the cheapest, quickest, easiest and cleanest looking solution!!!!
Offline wally_games
« Reply #18 on: August 10, 2011, 04:46:36 pm »
The tinted strip that I mentioned earlier, that goes on the inside of the shield, works great. Even adds that little extra bit to the dark shield. And, it's pretty cheap.
Offline mellow yellow
  • COG#: 9301
« Reply #19 on: August 11, 2011, 02:25:01 am »
does it leave any adhesive on the shield when you take it off?
05 connie
Offline Just Kruse'n
  • COG#: 10280
« Reply #20 on: August 11, 2011, 05:43:00 pm »
[/quote]
Electrical tape on the inside of the visor is not noticable and works great.  I use it on the inside of BOTH visors on my Scorpion EXO900s' and love the results.
Ed Kruse
Naples FL
GWRRA #124374
Chapter FL2-G
COG #102806
'02 Silver GL1800
'11 Kawasaki Concours 14
"Just Kruse'n"
Offline Steve_Cramer_GA
    • savvypaddler.com
  • COG#: 8200
« Reply #21 on: August 12, 2011, 06:29:19 pm »
I have used a bunch of these approaches.
SuperVisor wouldn't stay stuck.
Tinted strip (can you believe someone is flogging these for $10?!) worked OK.
Black electrical tape works quite well, no residue problem.
I'm currently sporting 2" blue painter's masking tape. Quite the jaunty look, IIDSSM.
I'm thinking about using black spray paint on the inside across the top. I think that will look pretty good. If not, hey, it's an old shield. (And an old rider, come to that).
Steve
2000 C10, 2000 ZRX1100, CDA0297
Offline Jim M.
  • COG#: 7951
« Reply #22 on: September 05, 2011, 09:28:58 pm »
Put the electrical tape across the BOTTOM of the face shield. When you flip the shield up, it becomes a visor. When the shield is down, you don't even notice it.
Offline MizzouMike
  • COG#: 8862
« Reply #23 on: September 05, 2011, 10:02:47 pm »
ask my how I figured that out...... :-[
2014 BMW R1200GS
AMA, COG, IBA
Offline daddykevin
    • Smarter Investing
  • COG#: 9739
« Reply #24 on: September 06, 2011, 02:36:37 am »
Thank you to everyone for the input. The correct answer is the AFX-FX50 with it's visor will block the sun nicely, the drop down tinted shade works very well, but a little tight for those who wear glasses, and the helmet doesn't "lift". At least up to 70 mph.
DaddyKevin
aka Kevin Nichols
