Author Topic: that ain't scenery, its a distraction  (Read 1545 times)
Offline RWJC
  • COG#: 9827
« on: September 27, 2011, 08:34:35 pm »
Enroute to work, trying to focus on the road and all the many intersections in morning rush hour: ...going down a 6 lane why, and following behind a plumber's pickup. "He" told me to change lanes, so I did...and VERY glad I did...this id10t had put his aluminum ladder on his top rack w/o strapping it down. Had I not moved, it would have appeared to have struck my windshield or my chest. Worse, my daughter was on the back with me. God is good. WOW! Later that day and 110mi later, a woman makes a right, I am making a left, double white lines at a controlled intersection. She ignores the lines, and tries to come in my line. On blast of the train horn...she moved quickly!. I had room in a turn lane next to me, luckily no one was coming.
Ride safe everyone...and be careful.. :motonoises:
~RWJC
COG #9827
"Dress for the crash, not for the ride."
02'VN800-SOLD 59,348mi 02'ZG1000-GONE 05'Nomad-SOLD   05'ZG1000-(12/1)5500mi(1/1)8220mi
Re: that ain't scenery, its a distraction
« Reply #1 on: September 28, 2011, 04:46:04 pm »
I had a truck stopping at a cross street fail to tie his rebar down and I saw it flying right at me.  I felt very lucky as I watch the rebar hit the road just behind me in the rear view.  That would have hurt.
Offline mellow yellow
  • COG#: 9301
« Reply #2 on: September 28, 2011, 10:32:16 pm »
had two cars try to merge at the same spot and had to duck from some of the debris that was flying overhead.
05 connie
Offline RWJC
  • COG#: 9827
« Reply #3 on: September 29, 2011, 09:46:46 pm »
ya cain't fix stoopid!!!   :rotflmao:
~RWJC
COG #9827
Offline wild man
  • COG#: 6174
« Reply #4 on: October 01, 2011, 01:08:50 pm »
Two summers ago I was riding through Pennsylvania on the interstate enjoying the beautiful scenery that
is PA.   There was a semi directly ahead of me, I was at the appropriate distance, we were both at the speed limit,
then suddenly out of the corner of my eye I noticed something pop off of the rear wheel.  It was half way to me before
I determined it was a piece of tire. Popped the handle bar to the left and a 40 lbs chucked missed my windshield by
3 '.
Bill
USAF Ret, KC0IGL
AMA#333772, IBA#19247
2007 KLR 650, 1997 ATK 605
« Reply #5 on: October 01, 2011, 01:15:49 pm »
3 '.
That's why I try not to follow semi's. And especially not close. I try to pass quickly and far to the other side of the lane. A piece of tire tread could kill you.
Trailers commonly use retreads on trailers. Retreads can and do lose partial and full caps off the tires. So I don't take the chance of being hit by a carcass
 if at all possible.  :o
Offline RWJC
  • COG#: 9827
« Reply #6 on: October 07, 2011, 12:50:30 am »
Had a cop follow me for a few stop lights on a well known bad highway. If I was near the front, I would safely accelerate to 1/4 mile ahead of the pack. When I stopped at the gas station, he asked what I was doing. I explained I make left turns (no turn lane) off the highway, and have almost been rear-ended a few times. I figure a 1-2-1/4 mile gap gives me enough leeway to make that turn with little worry. He understood as he told me of several accidents he has seen with cars.
~RWJC
COG #9827
Online SteveJ.
  • COG#: 5603
« Reply #7 on: October 12, 2011, 10:43:09 pm »
Good post. Let me add:
A lot of tractors also use recaps.
Also, a lot of those big trucks have a million plus miles of pounding down some pretty nasty roads, big chunks of iron can and do fall off.
The energy released by a tire blowing out is equal to about two sticks of TNT.
A lot of the drivers are very fatigued.
Blind spots are numerous around a big truck.
Maintenance is just enough to get by on virtually all trucks. I've only worked for two companies that would replace shocks when worn out. This makes stopping distances even longer than they already are.
Sum up: No good can come from hanging close to a truck, or worse yet, cutting off a truck to make a quick turn in front of it.
Disclaimer: I drive a rig, have for about 40 years. I currently have about 2 million miles w/out a preventable accident(1977). A non preventable accident is a much higher threshold than "not at fault".
Tick Tock, baby (Ironbuttal)
Offline Diff22000
« Reply #8 on: October 13, 2011, 06:19:14 am »
Also dont forget if you are behind a truck to look between the tyres  (from a distance) as he is going along to check if he has anything wedged in the gap between the tyres.  I always have a look and it has saved me on more than 5 occasions when a brick or something similar has managed to release itself from the gap.
