Author Topic: Turn Signal Ignorance  (Read 14775 times)
Offline Cooljerk
  • COG#: 11040
« on: July 02, 2013, 03:59:09 pm »
I'm a new Connie rider. One thing I have noticed is that I am not cancelling my turn signals when I should. Very Bad! :-\
The turn indicators on the dash aren't very visible (for me) because they are so far below the line of sight and because of bright ambient light. Another issue is that I am new to this bike and my autopilot has not had enough training to turn the damn things off each and every time.
I'll bet some of you have come up with fixes for this, like an audible alarm or adding additional lights on the dash or windscreen to get them in line of sight...?
2004 Connie, 94 BMW R100GS, 74 Honda CB750, 67 Matchless G15.
Offline S Smith
  • Northeast Area Director
  • COG#: 3184
Re: Turn Signal Ignorance
« Reply #1 on: July 02, 2013, 04:04:43 pm »
...or just remembering to cancel as soon as the turn is made  ;D
| Steve Smith | COG #3184 |
Offline ddtmoto
« Reply #2 on: July 02, 2013, 04:21:31 pm »
Your turn is not complete until you cancel the signal. It's just a part of the turn, any turn. Now hit the gas....!
04 GSXR1000
97 TLS1000
01 DRZ400E
09 Black on black ZG14...
Offline dcman98
  • COG#: 10264
« Reply #3 on: July 02, 2013, 04:30:48 pm »
Usually I'm pretty good at turning them off, but there have been a few times where I've ridden a dozen blocks with the blinker going because there are too many other things to look at. When I finally do turn it off, I just tell myself that I did myself a favor by looking incompetent to all the cars around me, which made them more wary of where I'd go next.  :)
« Reply #4 on: July 02, 2013, 04:37:51 pm »
Murph used to sell brighter bulbs.
I have them,  but even with them, I too have left the blinkers on. (Everyone has)
I've considered adding a beeper. (Something obnoxious) so (after I embarrass myself because I didn't hear it, and everyone else DID) ,,, I'll never forget again!
Offline higworld
    • Higworld Chronicles
  • COG#: 10794
« Reply #5 on: July 02, 2013, 04:44:19 pm »
I have NO idea if this will work, but I used to have one on my BMW GS.  Worked like a champ.  I notice their web site lists four different Kawasaki options.  One might fit.
https://www.kisantech.com/index.php?cat_id=4&catname=signalMinder
Rick Higgins - '92 Concours (Cyclops)
"I’m lost. I’ve gone to look for myself. If I should return before I get back, please ask me to wait."
Offline DGOLD
  • 1995 c10, 2001 c10, 2010 c14
  • COG#: 10054
« Reply #6 on: July 02, 2013, 04:50:00 pm »
I added the GTR1400 / Concours 14 '08-'13 LED Mirror Kit  from Projekt D which flashes the turn signal in my side mirror. I am happy with the product but still go far too long before canceling the turn signal!
Offline Larry
  • COG#: 9359
« Reply #7 on: July 02, 2013, 05:06:23 pm »
If you go to the link below, it should tell you exactly which model you need.
https://www.kisantech.com/application.php
10 Kawi Concours 14 ABS
Offline Edward
  • COG#: 10829
« Reply #8 on: July 02, 2013, 07:24:21 pm »
Anyone know of someone using this signal minder on a C100 with success?
The idea of not having self-cancelling turn signals was annoying, but not annoying enough to keep me from buying the bike after I rode it!
 :great:
Offline Cooljerk
  • COG#: 11040
« Reply #9 on: July 02, 2013, 07:41:22 pm »
Well, I went shopping on e-bay. There are some cheap Yamaha FZ6/Fazer flush mount turn signals that might work. I ordered them. I'll let you all know how they work. http://www.ebay.com/itm/300916525282?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1438.l2649
I plan to mount them on top of the dash near the screen vent holes. That way I won't fail to notice them as they light up the fairing. They are also another set of lights for iron beasts to notice before pulling out in front of me. They are small, smoke colored when not lit, so they should be nearly invisible when not in use.
Offline Stasch
  • COG#: 6830
« Reply #10 on: July 02, 2013, 07:45:53 pm »
I have a beeper installed on my C10, which I added when I owned a Voyager XII simultaneously.
The Voyager had self cancelling TS's and I switched back and forth between the bikes all the time.
The Voyager was just right, turning off the signals during freeway lane changes and for turns.   Coming back to the C10 - I would forget.  Everyone said, 'just remember to turn it off', but it didn't work.
Now a beeper has its drawbacks.  You need one loud enough to hear even at freeway speed, so imagine sitting in a left turn lane for 45 seconds with a loud beeper going off every other second.  Not good.
I wired mine to a relay so that it would only beep if the brake light was NOT lit.
The Voyager has been gone for a few years now and I have been cured from Turn Signal Forgetitus, and disconnected the beeper.
Contact RWulf for his solution.  He uses a vibrator embedded in the seat foam instead of an audible beeper.
Offline Cooljerk
  • COG#: 11040
« Reply #11 on: July 03, 2013, 01:12:16 am »
I'd like to hear more about the vibrator in the seat foam! Now there's a FARKLE! or is that FARTKLE? :))
Offline Ranger Jim
  • COG#: 6720
« Reply #12 on: July 03, 2013, 11:51:07 am »
His girlfriends make him go around in circles all the time.   :great:
JIM CULP
Offline SugarRay
  • Loud CLOTHES save lives !
« Reply #13 on: July 03, 2013, 03:22:46 pm »
How any bike/road vehicle could come without self cancelling blinkers is beyond me. How's this sound?  Push the blinker switch once for 15 seconds twice for 30 and three times for no delay if you're so inclined. Make it a standard feature like keeping the headlights on and not able to start with kickstand down while in gear....
Who's gonna build it  :)) ?
Offline worncog
  • COG#: 9584
« Reply #14 on: July 03, 2013, 03:42:51 pm »
Behavior modification. Whether you learn to turn them off or let the machine do it for you, you have been trained. Me, I have added as part of my cornering sequence. When bike becomes vertical after turn, push button to reset/center switch.
But, let them take away every decision you have to make to ride the bike...you might as well drive a cage cuz they even park for you now(no intent to segway). JMO
RWTW, COBDR, SM 500, BVF...
Offline SugarRay
« Reply #15 on: July 03, 2013, 03:57:18 pm »
Its already built and for sale , Signal Dynamics Self-Canceling Turn Signal Module 01501. If putting this device on my bike and it is never used because of my attention  to blinker turning off-ing  :) hooray me! But if it saves my azz just once when my concentration slips after a long hot day in the saddle...hooray modern technology ! :beerchug:
Offline Larry
  • COG#: 9359
« Reply #16 on: July 03, 2013, 04:11:02 pm »
Anybody using the Signal Dynamics device on here?  Wondering what the difference is between it and the Kisan Tech SM-3?
Offline Gumby
  • Black 2011
  • COG#: 10640
« Reply #17 on: July 03, 2013, 04:29:02 pm »
 :popcorn:
« Reply #18 on: July 03, 2013, 06:26:40 pm »
This. For me it's just up-shifting, and I find I am often canceling the turn signal more than once, as I run up through the gears, and occasionally will catch myself pushing the button after up-shifting when I had never even turn them on. Does that guarantee I will never forget... well no, but I don't really care at that point, if I rarely forget.
Offline mattchewn
  • COG#: 10993
« Reply #19 on: July 03, 2013, 06:43:06 pm »
If you don't use them then u cant forget to cancel them! Plus I hear the bulbs last much longer that way too!
2018 H2 SXSE.  (FAT SXSE)
2011 GSX1250 FA
2009 Ninja 500R. (wifes')
2001 Bandit 650  (kids')
Offline Gumby
  • Black 2011
  • COG#: 10640
« Reply #20 on: July 03, 2013, 07:10:24 pm »
  :rotflmao:
Offline mattchewn
  • COG#: 10993
« Reply #21 on: July 03, 2013, 09:10:45 pm »
Gumby,
NICE!!!
2011 GSX1250 FA
Offline LakeTrax
« Reply #22 on: July 03, 2013, 10:39:25 pm »
Keep up the good work you two... :rotflmao:
Forget to forget this "turn signal" stuff Matt...
Just start kickin' and flashin' those SIZE 13 Alpinestars out on either side when you're turning and call it "foot-flashing"!
« Last Edit: July 03, 2013, 10:41:24 pm by LakeTrax »
Offline mattchewn
  • COG#: 10993
« Reply #23 on: July 04, 2013, 12:42:14 am »
I'm diggin' the shoes bro! Cant wait to plant one o' them size 13's in the quarter panel of some dipsh2t that cuts me off!
2011 GSX1250 FA
Offline LakeTrax
« Reply #24 on: July 04, 2013, 04:21:29 pm »
Glad you like 'em buddy... Side mirrors come off very nicely too with a well placed size 13. ;)
