Author Topic: Central Indiana Tech Session - Sunday April 24 10am  (Read 5318 times)
Offline Tinsailor
  • COG#: 7402
Re: Central Indiana Tech Session - Sunday April 24 10am
« Reply #50 on: May 17, 2016, 12:43:26 pm »
I will be there on my C10 looking for advice on adjusting  valves :)
They should be in good shape unless you've put a whoooooole Loy of miles on her since I last saw you.
Offline Tinsailor
  • COG#: 7402
« Reply #51 on: May 17, 2016, 12:49:40 pm »
And the tyre changing may be something as well  >:( see this
Mark I suppose those are the valve stems I put in it, there's an inner nut, I believe, just tighten that up with the outer ones but also check out the rubber washers. Shouldn't be a difficult fix.
Offline Scubadoguk
  • poo poo occurs
  • COG#: 11248
« Reply #52 on: May 18, 2016, 12:47:01 am »
yeah they leak a bit BUT I figure I will try what you suggest sometime soon:)vand good to know about the valves that looked a BIG job :) thanks for the heads up
poo poo occurs, British by birth American by choice.
Offline Tinsailor
  • COG#: 7402
« Reply #53 on: May 24, 2016, 10:54:22 am »
There's not much to it
