Author Topic: 1999 KLR - can you identify these pieces????  (Read 1008 times)
Offline LegendsCar95
  • COG#: 10194
« on: July 08, 2012, 09:46:58 pm »
It's my buddies bike and I'm trying to help him out.     It's a '99 with some absurb amount of miles and he was changing the clutch and found this in his crankcase oil strainer.....   Bike runs ok so he's not sure when it might have occured, but he would like to identify them.
Thanks!
Offline danodemotoman
  • COG#: 2877
Re: 1999 KLR - can you identify these pieces????
« Reply #1 on: July 08, 2012, 10:44:26 pm »
 Looks like it may be the ends of the tensioner spring for the counter balancer commonly referred to as the 'doohickey' problem. The doohickey is a weldment plate that the spring attached too. Both are common failures on a pre 2008 KLR and even post KLR's the spring has limited tension travel.
 So typically the ends of the spring break.
 Have him join a local KLR tech/wrench session and the replacement occurs at most sessions and he can order a replacement upgrade doohickey and spring from Eagle Mfg. No need to buy the tools as there are available at the tech sessions.
 Once failure occurs DO NOT adjust the balancer until repair as any release of tension may allow the chain slack to increase. Best to repair this problem asap tho many a kLR has ran with this problem for many miles.
http://eagle-m-e.com/balancer_system.htm
  • COG#: 10194
« Reply #2 on: July 08, 2012, 11:37:43 pm »
Dan - I can't thank you enough for the detailed response.   The folks over @ the KLRFORUM thought the exact same thing.
I can't believe COG even answers questions outside of a Concours!!!   :)
Thanks again - this helps a TON.
  • COG#: 2877
« Reply #3 on: July 09, 2012, 11:49:35 pm »
 Hey you are welcome, some of us are multi cult members!  ;)
 C10
 KLR
 Fairlane
 Rambler
