Author Topic: accessory wires for versys 650  (Read 648 times)
Offline JP
  • COG#: 5068
« on: October 09, 2018, 07:09:02 pm »
Just bought 2015 versys 650 abs and love it. looking to add heated grips and aux lights. owners manual shows a set of wires for each under front left side and they are there. Cannot get power to either set with engine running, or off, or just ignition switch turned to on,  no power,  even with good ground from battery no 12volts.  Aux 5 amp fuse is good and has power to its block going through it. Any ideas?
Offline JPD
  • COG#: 12064
Re: accessory wires for versys 650sg
« Reply #1 on: October 10, 2018, 03:03:31 am »
Go to the versys fourm. You will find that there is a relay that needs to be installed. Ma k wants alot for it but it can be found for a lot less by looking up the base part number.
Offline JP
  • COG#: 5068
« Reply #2 on: October 10, 2018, 10:55:52 am »
Will do thanks, but still puzzled as to why there is no voltage on the wires marked for heated grips. Seems they would have to be either the coil power for the relay or the operating power for the load. If neither then do not understand why they are there. In my checking if I come up with anything interesting will post , thanks again.
Offline Bikejunkie1013
  • COG#: 8620
« Reply #3 on: October 10, 2018, 05:57:51 pm »
The power leads require a power relay 99994-0556 to activate the leads
2015 GREEN C-14
2013 Ninja 1000 Black and White
2016 Versys 1000 Green
2003 ZRX1200r Red,1988 KLR250
1985 GPZ 900r Red
Offline JP
  • COG#: 5068
« Reply #4 on: October 10, 2018, 07:52:13 pm »
OK thanks...stumbling thru this only owned bike few days. Looks like local stores have relay for $36 hunting around to see if can find one little less if not off to Kawi shop. thanks to all...
Offline MtnRider
  • COG#: 12840
2015 Black C14
Offline JPD
  • COG#: 12064
« Reply #6 on: October 11, 2018, 02:32:02 am »
I used an omron relay 27002-1086. $14.50 on ebay.
Offline Tinsailor
  • COG#: 7402
« Reply #7 on: April 06, 2019, 01:39:11 pm »
That same relay is on C-14’s, I used the one that was on my Connie I tore up. So what I’m saying if you can find a parts bike, it’s on any C-14.
