Author Topic: Rebuilding BMW air head help  (Read 868 times)
Offline Chris
  • COG#: 6354
« on: August 31, 2010, 02:07:00 pm »
My son is rebuilding an older air head to put into a Dneper.  All is good except a special tool is needed to install the main rear seal on the engine.    Just wanted to know if anyone in the Seattle area would have one I could borrow?    --chris  - on the trailing edge of technology
--On the trailing edge of technology--
Offline klrider
  • COG#: 1887
« Reply #1 on: September 01, 2010, 04:23:00 pm »
Chris,    If he hasn't done so he might check with the Airheads forums. I used to hang around there and they were pretty active and helpful.    http://www.bmwmoa.org/forum/forumdisplay.php?f=13    There are two or three forums for the airhead bikes nowadays.    Good luck!
Pat  COG 1887
IBA 5830  AMA LIFE  NRA LIFE  VSSA LIFE VCDL NTA FTA VTA, DRZ-400SM K9, YAMMIE KODIAK
Offline Chris
  • COG#: 6354
« Reply #2 on: September 02, 2010, 01:48:00 am »
Thanks for the info.  He is checking other places, I just thought I woud see about here.  The tool is only $35 or so.  If he doesn't find someone right away he will buy one.  He is frugal enough for a connie so he doesn't want to buy a one time tool.  :)    --chris    - on the trailing edge of technology
« Last Edit: September 02, 2010, 03:49:00 am by Chris »
