Author Topic: Z1/KZ Dynamo cover oil leak  (Read 834 times)
« on: December 17, 2017, 05:42:38 pm »
The left side cover which covers the Dynamo on my 900 is leaking. The grommet the wires go through is known to leak at some point. The fix is a new grommet, cut and re-solder the wires back together after running them through the new grommet. Not my idea of a good time...simple enough but I really don't want to cut wires. So I was thinking of taking the dynamo cover off and hosing everything with brake clean. Then slather the entire grommet/inside wires with Honda Bond and put back together. Or should I just bite the bullet and replace the grommet? If you have not used Honda Bond before it is pretty runny compared to RTV. I know some of you Z1/KZ owners have dealt with this problem. Thanks, Tim
Offline m in sc
Re: Z1/KZ Dynamo cover oil leak
« Reply #1 on: December 18, 2017, 02:29:51 pm »
case sealant is a good idea, ive done it myself. 3bond is wonderful stuff.
« Reply #2 on: December 25, 2017, 06:11:17 pm »
As you've already sed you don't want to cut the wires, seal it.
But, I think I would use oil resistant RTV. {Gasket maker}
If the RTV doesn't work you can always go to plan B. (Cut and new grommet)
Offline ZXtasy
  • COG#: 12569
« Reply #3 on: December 25, 2017, 06:26:04 pm »
Indeed on the right track Tim, I helped a friend resurrect an old KZ1000B, the leaking at that point was one of the last niggles. He emery clothed the junction a lot, then used top quality oil/heat resistant bond and the weepage stopped.
Offline Deepsea
« Reply #4 on: March 26, 2018, 12:03:21 pm »
So, did you get the leak fixed?
Retired Navy Saturation Diver
