Author Topic: Guinea pig wanted  (Read 245 times)
Offline PeterL
  • Keep that platypus away from me!
  • COG#: 13031
Guinea pig wanted
« on: April 07, 2020, 09:11:53 pm »
(Can you let me know if you do NOT see the attached photographs? Trying to figure out why some do and others do not. Thanks.)
I've been running prototypes of my latest gadget on two of my bikes. Now I'm looking for somebody who will install and test this on THEIR baby and give me feedback.
This is a complete C14-specific accessory switch package: a waterproof control module (w/illuminated & color coded LED switches) with attached umbilical, and an assembled and wired relay array. The idea is for durn near anybody to be able to install this in an hour or two tops. The control housing itself attaches to your clutch reservoir via 3 embedded Neodymium magnets (no screws). This DOES require you to be using standard ferrous hardware, not aluminum. The control umbilical cable is 5 feet long, sufficient to reach most anywhere you might want to mount the relay package, and terminates in a standard automotive Molex connector.
The relay assembly measures only 59mm wide by 36mm deep by 50mm tall (2.3" x 1.4" x 2"), exclusive of the wiring exiting the bottom. Each relay is rated for 30 amps at 12 volts. It has a matching Molex connector for the control lead insuring easy and foolproof hookups.
And that's pretty much the complete switch installation. I include a handful of zip ties for securing the wiring. The only tasks for the owner to perform are to connect the following wires:
- One 12v+ POWER (red) and one ACCESSORY POWER OUT (yellow) lead per circuit. You only need connect the circuits you'll actually use now. Others can sit until needed.
- One GROUND (black) lead, handles the LED and relay activation circuits. Accessory power is grounded downstream of each accessory load.
One available- cost is $50 plus your time to document what you like (or don't) with the product. Please PM me if interested.
Ride safe,
Peter
« Last Edit: April 08, 2020, 05:02:23 pm by PeterL »
Mine all mine: 2008 C14 ABS (aka "Thunder")
projects: 1982 cb750F (project "Ichigo"), 1983 VF750S (x2) (I named the first one "SabreOne" just so's I could name the second one "SabreTwo-th"), and something that started life as an '03 SV1000s but has now mutated beyond recognition...
just gifted: 2003 BMW K1200RS, 2018 Multistrada 950, 2019 Yamaha Tracer GT (Nice. But I'd still rather have my friend than his bikes, y'know?)
Offline Not So Wild Turkey
  • COG#: 10559
Re: Guinea pig wanted
« Reply #1 on: April 08, 2020, 08:37:19 pm »
A week ago i would have been your huckleberry.  Sad to say I'm fully invested in wiring all of my stuff to a fz1 block with previously mounted switches.  Not willing to undo what I've done.  Best of luck though.  It looks great
2012 Concours Arabian Red & 80 Suzuki GS1100E
2003 VTX1800R Black / 1979 Suzuki GS1000E / 1969 Norton Commando
Yamaha DT3 250 / Kawasaki 100 G4TR
Offline PeterL
  • COG#: 13031
« Reply #2 on: April 09, 2020, 07:53:56 pm »
The deal has been taken.
In a few weeks, once I've received the feedback, and presuming all is positive, I'll be releasing this to our eBay store.
I have a 2-switch variant for regular handlebar motorcycles in the pipeline as well. That one is probably about a month out at this point. I'll post a note here when it is released, but as it is NOT Connie specific I'm not planning to echo anything to the Accessories board.
Cheers,
Peter
