Author Topic: Ironbutt route tracking  (Read 458 times)
Offline rmills944
« on: June 07, 2018, 06:21:16 pm »
For those that have done an ironbutt, what's a good tracking app to document your ride for you and trace your route? I'd like to get something to make documentation easier.
Offline SATXRIDER
  • COG#: 12274
Re: Ironbutt route tracking
« Reply #1 on: June 07, 2018, 06:36:26 pm »
rmills
Do you have a GPS?  That is obviously the best way to track.  Another option is a Spotwalla device, but those can get pricey if you're just looking at a once in a while long trip.  For me, I just use Google Maps to set up the route and then print that out.  You need to take pictures of all receipts next to your odometer when you gas up to help track your miles between fill ups.  I'm sure you will get more expert advice on this forum.
Steve
2013 C-14
2006 ZX-14
1982 GS1100
Offline rmills944
« Reply #2 on: June 07, 2018, 07:29:32 pm »
I've been planning to do receipts like the webpage says and all, but the route isn't the most straight-forward across Arkansas - no direct highway. I can do it, but would liek something that tracked what time I was where. I found one called "GPS Tracker" that tracks just about anything - I could do screenshots from that. I just wanted to see what everyone else was using for electronic documentation.
Offline BDF
« Reply #3 on: June 07, 2018, 07:49:17 pm »
I use a SPOT with Spotwalla but it really does not make documenting a ride any easier. The rider is still required to get a receipt for all stops over (I think) 10 minutes, is required to get a receipt for all fuel stops, and must stop for fuel in intervals of 350 miles max. And the starting and ending point witness statements are still required.
Where Spotwalla does come in handy is if you get fuel and no receipt (a closed fuel station when the pump is out of paper or the paper is jammed), you can use Spotwalla data to help document that you really were at that fuel station at that time. Along with a charge card receipt of the actual purchase, of course. The other advantage is that the IBA will calculate the miles between your stop points from the receipts via the shortest distance, so if you actually take a longer route between stops there is not really any other way of documenting those extra miles. It is still best to make sure the points you have recepits for actually add up to slightly over the minimum miles required to certify a specific ride but Spotwalla <may> help if the mileage is very slightly under the limit and yet you did really cover all the miles needed.
Brian
Online who me?
  • COG#: 11932
« Reply #4 on: June 07, 2018, 08:32:24 pm »
Spotwalla has phone apps
Dont know exactly the name but Ive got it on my iphone(Left phone on bike)
I believe it is free or very low cost
Drawback is if your phone is off grid it doesnt track
95 C10 The Mule
02 C10 parts are parts
Offline Sailor_chic
  • COG#: 11610
« Reply #5 on: June 07, 2018, 08:59:47 pm »
When I use to ride, I used MyRoute-app https://www.myrouteapp.com/routelab for my route planning. It is definitely worth the money for the gold version. And now they have MyRoute-app Navigation https://navigation.myrouteapp.com/en which makes your planned routes available on your Android or apple device. This navigation app also has route tracking.
Nicole     Port St Lucie, FL.
2013 C14 Black
2006 Vmax
IBA # 60267
Offline BDF
« Reply #6 on: June 07, 2018, 11:33:35 pm »
Yep, Spotwalla will take cell phone input. Other than a similar name, it is a private site and has no connection whatsoever with SPOT (Find Me SPOT, the satellite locating service), so it works exactly the same with a smart phone other than the limitation that you pointed out, you have to have cell coverage. But it is a really nice service, it is free, and the owner is a great guy who is more than accommodating, and a long- distance rider himself, and more than willing to help people use his site / service.
Brian
