Author Topic: head ache from helmet?  (Read 3476 times)
Offline Graphicjunkie
  • Never ride faster than your guardian angel!
  • If guns kill people, my pencil misspells words.
« on: June 15, 2016, 05:12:59 pm »
I've never dealt with this before.  But any one deal with the front of their helmet squeezing the holy crap out of their forehead?  Just above my eyebrows, after wearing for a couple of hours, my forehead gets really sore.  Never had this happen before.  The fit of the helmet is great.  But that gets sore over time.
Is there a fix for this?  Is it a helmet shape thing?  DO I HAVE AN EGG HEAD!  >:(  lol.
Seriously, is there a way to force the front to give more to relieve pressure?  When I take my helmet off, looks like I have a bar code across my forehead!
thx.
2009 Black ABS - Night Fury (Shoodaben*ZX14 Header*Dual Two Bros*Vstream*heated grips*fender extender*lowered foot pegs*radiator protector*LEDs*wedges*TechSpec*Corbin/Smuggler*switchbacks*Stebel)
2008 Neutron Silver  - Silver Streak (GONE)
Colorado
Offline Dave Scott
  • COG#: 8603
Re: head ache from helmet?
« Reply #1 on: June 15, 2016, 05:21:09 pm »
it happens to me with some helmets too.  I stick with HJC brand becasue they fit me well.
Offline The Pope
  • North Carolina AAD
  • COG#: 9994
« Reply #2 on: June 15, 2016, 05:28:43 pm »
Short answer: yes
Longer answer: Yes, as different helmet manufactures have different shapes. You'll need to try several different brands and models to figure out which one works best for you.
The Pope
Offline Dave Scott
  • COG#: 8603
« Reply #3 on: June 15, 2016, 05:31:05 pm »
Offline jdegraff
  • COG#: 11713
« Reply #4 on: June 15, 2016, 06:31:51 pm »
As has been stated. Some are round and some are egg shaped. All cheap helmets suck.
Go try on a Shoei (lower cost), ARAI (mid cost), and a Shuberth (Spendy).
Once you find the brand with the right shape for your head you will know it instantly.
I wore HJC helmets for years. I will never wear one again. My next Dual Sport helmet will be an Arai. That thing fit like a dream.
Offline JTX
  • TEXAS 2015 ZG14
    • 2015
« Reply #5 on: June 15, 2016, 07:13:42 pm »
I have an HJC IS MAX 2 and, its not bad for a few hours, then I start to get some forehead pressure but near the top.  I press on the back of the helmet a bit and it relieves it.  But after a couple days of riding, my forehead is a bit sore.
I'll be looking at different brand in a couple years when I replace it, but so far its not bad enough to change .
Offline Zarticus
  • COG#: 10785
« Reply #6 on: June 15, 2016, 08:14:01 pm »
you can take the back side of a spoon & reshape the forehead area a little by applying pressure against the spoon & sliding it back & forth. It's compresses the foam a little & can make a lot of difference  :beerchug:
1986 Honda V65 Magna, Black
1984 Honda V65 Magna, Black
1983 Honda V45 Sabre, Red
Offline Arabian Red
  • COG#: 11292
« Reply #7 on: June 15, 2016, 08:14:39 pm »
I had an issue with a new Shoei RF1100 due to me egg head and I fixed it by removing the internal padding and using the curved side of a large metal spoon to form the frontal part of the helmet foam liner to tailor fit it to me head by pressing on it. It took a little work but my helmet fits perfectly now and I can wear it for hours now without an issue.
« Reply #8 on: June 15, 2016, 08:43:21 pm »
Awesome idea!  Thx!  I will give that a shot!
Colorado
Offline Daddoz777
  • COG#: 12282
« Reply #9 on: June 15, 2016, 09:06:01 pm »
Yes, this has happened to me and it was from a helmet that was too round for my oval-ish head.  My 2 cts. is be cautious about spooning your helmet.  I think there are many who would strongly recommend you don't.
2015 Concours, Candy Lime Green "Granny 2"
2002 BMW R1150RT "Gretchen"
2004 Kawasaki 1600 Mean Streak, Candy Lime Green "Granny" (Sold)
Offline Throttle 8
  • COG#: 12220
« Reply #10 on: June 15, 2016, 11:36:30 pm »
you can take the back side of a spoon & reshape the forehead area a little by applying pressure against the spoon & sliding it back & forth.   :beerchug:
Won't that cause a headache? :rotflmao:
2000 ZX12R Ninja
Offline DaddyFlip
  • COG#: 12341
« Reply #11 on: June 16, 2016, 01:56:16 am »
Rather than compress that area with a spoon and reduce the shock absorbing capacity of that portion of the foam, you can take some foam off with very fine sandpaper. Still reduces protection slightly but Better than being compressed. Better still, find a better fit with a different helmet. Also, if you are a LD rider, a helmet you could otherwise wear all day in your recliner will start to press on your forehead due to wind pressure on the helmet. Raising your screen and riding behind it for awhile will take that pressure off.
2001 ZR-7s "Ol' Red"
Offline gsun
  • CDA #560
  • COG#: 9127
« Reply #12 on: June 16, 2016, 03:28:38 am »
I found the HJC helmets were better for an oval head like mine. Still had to do the spoon thing but very little and no problems. Two helmets like that. The Shoei is more for round heads as well as the Schuberth. At least the older Schuberth. Could not wear either.
Offline AmphibSailor
  • Cibolo, TX Hooligan
  • COG#: 12210
« Reply #13 on: June 16, 2016, 06:14:27 am »
Rather than compress that area with a spoon and reduce the shock absorbing capacity of that portion of the foam, you can take some foam off with very fine sandpaper. Still reduces protection slightly but Better than being compressed. Better still, find a better fit with a different helmet...
 :iagree:
However, messing with the foam will definitely void the warranty and might reduce the helmet's protective abilities.
A good article that talks about different head shapes and gives some good info on which helmets fit which shape of head is WebBike World-Helmet's by Head Shape.
The attached gif illustrates what is meant by head shape..hth.
Offline ChrisD
  • COG#: 12153
« Reply #14 on: June 16, 2016, 08:41:26 am »
You could drive a little slower....might take the pressure off some.   :great:
Outside of that if you like the helmet a lot see if they have a smaller headpiece or smaller pads to replace.
Offline Alan
  • COG#: 11662
« Reply #15 on: June 16, 2016, 11:38:42 am »
I have an oval head, the majority of helmets are made to favor a round head.
Most helmets give me a hot spot on my forehead after about 90 minutes.
This is to the point of wanting to take the helmet off and throe it in the ditch by the side of the road.
So several years ago I went to the IMS in Chicago to look for a new helmet.
I tried on every brand and model of helmet there, bound a determined to find a helmet I could wear.
I do not to open face or flip ups, so focused on full face only.
Found the Arai Signet Q to fit perfectly, as it turns out this is the longest oval helmet made.
After getting it did a 4 hour test wear, rode and never to took the helmet of even a gas stops.
Never figured on buying a helmet for 500 bucks, but if can wear it all day with no hot spots well worth it.
Don't Panic!
AMA Charter Life 34 years
GWRRA Member 3 years
LIMNCS #147
'77 BMW R100/7 Manfred
'79 Yamaha MX175
'00 Yamaha YZ250
'01 Yamaha TTR125
'04 Yamaha YZ250F
'08 Suzuki DR650SE Mootzimo
'09 Honda GL1800Navi/XM HAFACAR
'12 Kawasaki ZG1400 Concours
Highly recommend http://letsrideclyde.com/
Offline WANDRNG
  • SouthWest AAD
    • Wandering Back Roads
  • COG#: 12077
« Reply #16 on: June 16, 2016, 02:17:09 pm »
Keep in mind, even within a brand, different models fit different head shapes better.  :truce:
Just because one brand model fits your skull perfectly doesn't mean all their models will.
You need to know your head shape and then do some research at the links provided in various posts above.
Buy a helmet from a place that has a good exchange policy (for unriden helmets, if you ride with it, has bug splats, they won't take it back) - then sit an watch at least an hour+ of TV with it strapped on. Any pain or discomfort at all, try something else (size, model, brand). Cause an hour on the couch ain't nothing compared to an hour of riding (as mentioned above, air pressure, movement, temperature, etc)
Life is too short to live the same day twice.
2015 Concours 14 -- 2007 Kawasaki KLR650 -- 2003 Honda Magna 750 -- 2 V65 Magnas
Wandering Back Roads: RRs -- Wandering the Northwest -- Heading East Out West
« Reply #17 on: June 16, 2016, 03:39:02 pm »
I have read threads here speaking about oddly shaped heads.  In all the helmets I've owned, I've never had this issue.  So I figured it was more of a case for those people that were out side the norm.  But apparently not.
This is on my brand new Kabuto Ibuki helmet.  I can't send it back now.   Sadly, I never felt the additional pressure on my forehead when trying on.  I didn't feel it until the first long ride, after hours of riding.  By then, I'm way past Revzilla's return policy.
I like the sandpaper idea too.  I will give that a shot.  Thanks!
Colorado
Offline Old Steve
  • COG#: 10537
« Reply #18 on: June 21, 2016, 03:16:17 am »
I went with the Signet Q for the same reason.  I was lucky, though - the guys at The Helmet Center only let me try on two other helmets before they tossed the Signet Q at me.  I wore it in the store for about 20 minutes and almost forgot I had it on.
Picking a helmet is like choosing a bowling ball - the one that your buddy loves may be unusable for you.
Offline Daisy
  • All About the Symmetry
« Reply #19 on: June 21, 2016, 07:42:14 am »
I've used sandpaper and spoons in the past, but I also found that adding a piece of thin foam rubber about a millimetre or two thick across the front edge can ease the pressure. When I got the Shark Evoline it caused me severe headaches and it was then I discovered that I have a bump on my head just inside my hairline. I suspect that one of my parents may be Klingon.
Offline Solomookie
  • COG#: 11738
« Reply #20 on: June 21, 2016, 11:52:29 am »
There's an easy way to tell, Daisy...  How do you feel about blood worms as an appetizer?
'98 Connie x 2, farkle expenditures nearing the GNP of Bolivia; it's a sickness.
Offline Brian
  • COG#: 12360
« Reply #21 on: June 21, 2016, 07:25:03 pm »
I have the same problem.
This helmet solved it.
http://www.revzilla.com/motorcycle/ls2-vector-podium-helmet
Few hundred cheaper than the Arai.
