Author Topic: Reverse fliectomy?  (Read 296 times)
Offline JerBear
  • COG#: 12777
Reverse fliectomy?
« on: March 10, 2019, 11:53:23 am »
Steve, it is my intention to try one of your Flashes for my C14.  I have the secondary flies for the throttle bodies that I removed (but saved) many years ago.  You told me they would need to be replaced before a flash would be fully helpful.  Is there any words of wisdom IE orientation (positioning on the plates) or locking fluids for retaining screws that I should use?
If you'd prefer, PM me and this is not urgent I'm planning to do a TB synch next month so I'll be in there anyway.  I may as well put them back in.  Also you have several types of flashes don't you?  Perhaps I can talk with you about he type that would benefit me the most.
Jerry
2008 Silverdammit C14
Offline Gscott
  • 09 C14
  • COG#: 12413
Re: Reverse fliectomy?
« Reply #1 on: March 11, 2019, 09:43:16 am »
Had to replace my flies when I got my ECU flashed by Steve. After I replaced got a DTC about the secondary butterflies, (wish I could remember the code number) sent Steve PM he called me back quickly and over the phone we got the problem solved by shutting bike off and restarting a few times.
    Found code #62
« Last Edit: March 11, 2019, 10:21:20 am by Gscott, Reason: code # »
« Reply #2 on: March 12, 2019, 11:19:03 pm »
   Stuff some paper towels between the secondary and primary throttles to catch an errant screw if one gets away. Not to much, you'll need to pull it out once the fliy is back in. I dipmy screwdriver tip in rtv silicone to help it hold the screw. I also use red locktite on the threads. Finally, be sure not to let the fly crowd the walls of the venturii. If it does, the throttle shaft will drag and not close. this will show up as a constant high idle.
  I do have several flashes for the concours, and it's best to email me at Steve@shoodabenengineering.com  with your phone # so we can discuss options. Thanks, Steve
Offline Bikejunkie1013
    • JMP Cycle Kawasaki
  • COG#: 8620
« Reply #3 on: April 01, 2019, 01:19:23 am »
I have a similar issue with my Z1000. I want to flash it and the previous owner gave me the butterflies but no screws.
Anyone know what size these little screws would be??
2015 GREEN C-14, 2013 Ninja 1000 Black and White, 2010 Z1000 Titanium and Black
2003 ZRX1200r Red, 1988 KLR250 Teal, white and green, 1985 GPZ 900r red
