Author Topic: Shoodaben Engineering's LOCKDOWN FLASH SALE!  (Read 1160 times)
« on: April 06, 2020, 03:19:04 pm »
      50.00 off on all Concours 14 flashes!
    https://sites.google.com/site/shoodabenengineering/concours1400
    Steve
Re: Shoodaben Engineering's LOCKDOWN FLASH SALE!
« Reply #1 on: April 06, 2020, 04:06:43 pm »
Yahoooo!!
Err,,, uh,,, oops,,,,
     Just realized; I already have one.  {drat}  :-[
Ya'll get em' while their cheap!!
Offline Road Runner
  • Beep! Beep! ... YeeHa!
  • COG#: 12399
« Reply #2 on: April 09, 2020, 12:40:28 am »
Yahoooo!!
+1  :great:
David L. Hamil
Offline WFL
  • Still kicking, HARD, TOO!
  • COG#: 13006
« Reply #3 on: April 16, 2020, 07:14:36 pm »
Christmas in April! Thought i would have to wait a year to save $50 ;) Too bad it [the April Christmas] comes along with all the other crap currently going on.
So before I head into my nice, warm 40* garage to pull out my ECU could you explain the ramifications of flashing it with your Mtn Runner flash on a C 14 that is still under factory warranty. I have a 2017
purchased new in Nov of 2018 with less than a 1,000 miles on it. I plan on purchasing the Kaw extended warranty before the 3 year factory warranty runs out.  So any idea what happens if an engine related problem occurs. Can or will the dealer discover the flash? Does it make a difference as to warranty coverage?
I would suspect that if a repair has nothing to do with the engine [brakes, abs  controller, gauges, etc.] Kaw could not legally denied a warranty claim, but as to engine related problems I'm not so sure.
Any thoughts on this or actual experience? Thanks
"To argue with a person who has renounced the use of reason is like administering medicine to the dead." ~ Thomas Paine
« Reply #4 on: April 16, 2020, 08:16:10 pm »
1) Why wait? Buy the extended warranty now.
2) Dealers can't see if the bike was flashed...
        So, not a problem...
« Last Edit: April 17, 2020, 12:17:20 am by connie_rider »
« Reply #5 on: April 16, 2020, 11:40:45 pm »
Dealers can't see it, but more importantly I have flashed just shy of 1000 concours (this sale is going over 1000) and there's never been an engine related failure. I tune, but not to grenade your engine. Steve
Offline ron203
  • COG#: 9847
« Reply #6 on: April 17, 2020, 12:27:16 am »
Steve, I've got one complaint. You flashed my old Decel flash (circa 2015 to Mtn Runner) last month and now every time I ride it, I can't seem to keep it under 80 on my local roads and have a weird grin on my face. Help!    ;)
Well done, sir!
2014 C-14
2008 Goldwing
Offline WFL
  • COG#: 13006
« Reply #7 on: April 17, 2020, 01:53:28 pm »
HI STEVE, thanks for checking in on my question. I didn't mean to imply that your flash would damage the engine, I was actually thinking of a mechanical manufacturing defect on  the part of Kaw in regard to an engine problem. However if the dealer can't "see" the flash then obviously the dealer could not wiggle out of a warranty claim by claiming that your flash had some how caused the engine problem/damage.  By the way i was thinking last night how much insurance should one purchase on the shipment of the ECU when sending it down to FL? I get the impression replacement ECUs are expensive! Thanks
« Reply #8 on: April 17, 2020, 03:13:07 pm »
 Please email me at Steve @ Shoodabenengineering dot com and I'll send you all the info you need.
  Steve
Offline RyanP
« Reply #9 on: July 05, 2020, 05:30:32 pm »
What is considered the Classic Flash these day?
« Reply #10 on: July 05, 2020, 08:26:51 pm »
as of current; Mountain Runner is the base flash, based on the prior
Classic, the EVO, and also the Decell enhanced baseline..
so, Mountain Runner is newest based flash.. designed for 89 octane.. great improvement over anything prior, and still allows great decell ..
It is followed by the next tier, Mountain Runner Premium, which is a bit more "spicey", but does require running 91 or better octane, to allow full hard runs above "half throttle" : note tho, in an emergency, i.e. you are in b.f.e. and can't get 91, simply resist from "max throttle" and all will be fine until you can add some octane booster, or replace with full 91 or greater.. I have this flash, it is an amazing piece of work, and I have 92 everywhere around me for hundreds of miles..
Top Performance is the "Hammer" flash, designed for all out "rear tire removal", it also requires 91+ octane, but is soo close to the MRP flash, you likely will never see the difference, unless you are truely racing this bike hard... The Hammer also has reduced "engine braking" effect, which the MRP has proven desirable when in mountains, and relying on the engine to slow you down..
meantime, read about them..
also this...
http://forum.cog-online.org/shoodaben-engineering/mountain-runner-flash-dumb-question-octane/
 :great: :motonoises:
« Last Edit: July 05, 2020, 08:30:01 pm by MAN OF BLUES »
Offline Vic
« Reply #11 on: July 05, 2020, 11:23:41 pm »
I'm certainly up for better power delivery and smoother overall rideability, but can anyone specifically comment on how Steve's flashes alter the overall engine operating temps and fan cycling?
I've learned to compensate for the stock Kawi's ECU shortfalls to the point of debating dropping the money for quite some time.  But after the last road trip to Central Valley area CA, the temps had the Kawi fan on all the time, and me just cursing under my breath at how hot the bike runs thanks to the ambient temperature during the heat spell.
...thanks in advance.
And btw, I'm pretty much about to pull the trigger anyway!
« Reply #12 on: July 05, 2020, 11:34:08 pm »
just do it.. :nananana: :rotflmao: :rotflmao:
I did mine just prior to the National last year.. I rode in 95* temps all day, there and back.. and my bike's temps were pretty much the lowest I had seen, not to mention I jumped up in mpg, by a HUGE amount.
MRP man.. MRP...
Offline RyanP
« Reply #13 on: July 09, 2020, 02:18:18 am »
Steve said the Classic is now the Hammer
« Reply #14 on: July 09, 2020, 02:03:34 pm »
  The hammer started with the classic flash - My updated original flash from 5 years ago - And then vvt changes were made for even more power.
   Just as an FYI... My original flash and the flashes it inspired lack any help with the engine braking via the secondary throttle controls.
   When I first released that flash 5 years ago, it was the COG guys who wanted more engine braking for mountainous riding and better throttle control, and that's why the Mountain Runner flashes exist. It was strictly as a response to what riders want. Being in Florida, I would not have naturally developed the Mountain Runner flashes, Because flat Florida just doesn't need  it.  However  I'm thankful that the COG guys pushed me to do so, because my customers now have CHOICES and are't stuck with a single flash because it's all I think you would ever need.
  Steve
Offline ron203
  • COG#: 9847
« Reply #15 on: July 09, 2020, 06:27:06 pm »
  Steve
...and us "mountain hoodgers" like it! Well done.
2014 C-14
2008 Goldwing
Offline RyanP
« Reply #16 on: July 18, 2020, 01:30:21 am »
I rode my 1st C14 last year and my 2nd a few days ago. Both from a dealership, both 2015's, and both with an unknown ecu history.
I didn't realized which one was flashed until this morning, or at least I'm pretty sure one of them was flashed.
One felt lethargic at low revs, vibrated more and shifted poorly. I believe the fuel cut makes the jump from 1st to 2nd bigger than it really is?
The flashed one was smooth as silk, shifted great and felt much faster. Shifted better too. So I think I took a placebo flash test without even knowing it.
