Author Topic: 180/55 rear experiences anyone?  (Read 757 times)
Offline JaL3
« on: April 25, 2018, 10:37:58 pm »
Got a set of Angel A-specs super cheap, the catch being that the rear is 180/55. Has anyone tried that size on their C-14?  I still have the stock Brickstone, can't imagine it could be any worse at least ..
Regards, Jay with 2016 ZG1400, Ivan's flash, seat modded by Spencer, Puig spoiler, Canyon Cages, Bar Risers, Rigid Industries aux LEDs, Switchback LEDs front and rear, Two Brothers Black Series Slip-On.
A skeptic that believes anything when provided with evidence.
Offline Freddy
Re: 180/55 rear experiences anyone?
« Reply #1 on: April 26, 2018, 01:37:22 am »
I had one on some years ago and couldn't tell any difference.   :beerchug:
Offline Deepsea
« Reply #2 on: April 26, 2018, 04:38:45 am »
The 180/55 is 8mm larger in DIA, 10mm narrower, 25.14mm larger in Circumference. The 180/55 will turn less per mile than the 190/50 (813.39 v 823.85 R)
 All this means is you probably won't be able to tell any difference.
Retired Navy Saturation Diver
Offline RoadKillHeaven
  • How hard can it be? 。◕‿◕。
« Reply #3 on: April 26, 2018, 05:13:43 am »
I run 215/55 r16 instead of 205/60/16 (OE size) on my daily driver car. I can tell the difference. Smaller size gives you that extra pick up. When I had 215/60 r16 tires on the same car, I could tell it needed to stay in a particular gear a bit longer to attain the same velocity!
As for C14, or any other bike I've had, I've never installed non-OE size tires. So I cannot comment on that.
Cheers...
Offline JaL3
« Reply #4 on: April 26, 2018, 04:27:21 pm »
Thanks guys!
I was just a bit worries that it may screw up the KTRC due to the different Sir Cumference (the knight that designed the round table  ;D )
Offline Redlion61
  • Rusty Red Rider
  • Connie Forever!
    • Personal Website
  • COG#: 10098
« Reply #5 on: April 26, 2018, 04:32:18 pm »
Thanks guys!
K-Trac sensor is mounted on the rotor plate, no? How would the circumference difference change how the sensor picks up rotating speed?
Chris Dupuis
IT Guy, 2012 Connie ZG14 Rider
Offline Texas Concours14
  • COG#: 9760
« Reply #6 on: April 26, 2018, 05:54:37 pm »
I just recently switched to the 55's and took a road trip with a bunch of twisties; also using Angel GT instead of Michelin 4 GT so two variables in my comparison (as well as replacing old tire with new one). I have read on this forum that turn in is much better with the 55's. I guess so but not all that dramatic, but maybe I have forgotten what it was like with the 50's. It did make the speedometer more accurate; 60 mph by GPS reads as 61 mph with the 55's tires instead of 64 mph with the 50's tires.
2010 Concours 14
Offline JaL3
« Reply #7 on: May 01, 2018, 01:48:30 am »
Thanks guys!
Doesn't it look for the difference in rotation speed between front & rear?
Offline Max
  • CDA 264
  • COG#: 8762
« Reply #8 on: August 01, 2018, 01:49:09 am »
i ran 2 sets of them, i had them left over from another bike i traded.  they work fine.   turns a little easier, gets a little less mileage. if i had another 2 sets leftover i would run them out too.
