Author Topic: Anyone seen a tire do this?  (Read 1040 times)
Offline AwesomeDad
« on: June 07, 2020, 05:13:26 pm »
Here I thought I was being proactive and tire shopping early...
Any ideas what happened to my front tire?
JJ
2017 C14, 2001 Valkyrie
Offline antibus
  • COG#: 11339
Re: Anyone seen a tire do this?
« Reply #1 on: June 07, 2020, 08:54:49 pm »
I had that happen to my tires prior to improving the suspension.
CDA #0542
Offline cra-z1000
  • Keeping it upright..
  • COG#: 9790
« Reply #2 on: June 07, 2020, 09:02:44 pm »
New tire ?
Unless your old tire was doing something like that it wouldn't be a suspension issue . That is a defective tire if its new .
1987 C 10
80 Kawasaki KZ 1000 MK 2
74 Honda 750 four ss
73 Suzuki 550 triple
72 Honda 550 four
Offline AwesomeDad
« Reply #3 on: June 07, 2020, 10:11:41 pm »
Sorry was busy getting the bike home.
It’s a 2017 year I’ve had since new oct 2018.
Stock tires that came on it 7500 miles.
I haven’t touched the suspension and fork oil is what came in it...
JJ
Offline RWulf
  • COG#: 7122
« Reply #4 on: June 08, 2020, 12:21:39 pm »
That sure looks like a radial with too much air.
Offline Boomer
  • Wickford, UK
    • Boomers GTR Site
« Reply #5 on: June 08, 2020, 01:11:00 pm »
If those are the stock Bridgestone BT021's (and they do look like them) then they are crap and most of them do exactly that.
Ditch them and fit your choice of Michelin PR4GT, PR5GT, Pirelli Angel GT or GT2, or any of several other tyres that I am sure others will now chime in with.
They will give you better dry grip, way better wet grip, better mileage and better feel.
Kawasaki fit Bridgecraps because they are Japanese, not because they are good.
I'm told some of their later tyres are good, but the front BT021 is barely decent for the first 3000 miles and then goes downhill rapidly.
I have run PR3, Angel GT, and currently have PR4 (non-GT) and have never had any of the problems I had with the OEM BT021.
I'm getting 14k miles out of my front PR4s and 10k from the rears.
George "Boomer" Garratt
Wickford, UK
CDA-007
Offline AwesomeDad
« Reply #6 on: June 08, 2020, 01:24:05 pm »
I was in the process of tire shopping and that was the plan... Figured I had a little bit more time...
Offline AwesomeDad
« Reply #7 on: June 08, 2020, 01:28:53 pm »
I have checked them religiously try to keep 42 front and rear cold... and typically the tpms never agrees with my gauge. I’ve seen as low as 39 indicated on the bike when I know it’s 42. Could I have lost a little disconnecting my pump sure. But yesterday the bike was showing 44 front and rear all day. I would think for a tire to do this it would have to be a lot more than just 2-3psi over inflated...
Offline Pilgrim
  • '12 Black
« Reply #8 on: June 08, 2020, 02:28:49 pm »
Yes, but not as bad as yours.   If you got 7500 on the stock tire, consider it done and get yourself some new tires.
Offline Bikejunkie1013
  • COG#: 8620
« Reply #9 on: June 08, 2020, 02:32:36 pm »
I noticed my 2015 wore the front tire faster, the rear was good but the front was toast.
I watch tire pressure closely.
My worst mileage tire was a rear ContiMotin less the 4200 miles to the cords mid tour :'(
2015 GREEN C-14
2013 Ninja 1000 Black and White
2016 Versys 1000 Green
2003 ZRX1200r Red,1988 KLR250
1985 GPZ 900r Red
« Reply #10 on: June 08, 2020, 02:36:45 pm »
When the OEM tire is near the end of it's life, it does that "very" quickly...
Offline AwesomeDad
« Reply #11 on: June 08, 2020, 02:42:55 pm »
Good to know new shoes on order...
Offline llmotoll
  • COG#: 10391
« Reply #12 on: June 08, 2020, 09:13:36 pm »
Same happened to my new 2012 bike. I too was quite attentive to air pressure and it still happened. I changed them before they got that bad.
My riding style was different back then, I always thought it may have contributed. Used to be heavy on front break entering a turn. After completing the Total Control class my riding style has changed completely over the years
2016 Moondust C14
2012 Kawasaki Concours 14 ABS ~ Sold
2001 Suzuki SV650 ~ Sold
CDA#415
« Reply #13 on: June 11, 2020, 09:04:58 pm »
I bet you counter steer huh?
Offline Colt45
  • COGnito Ergo Zoom
  • COG#: 7914
« Reply #14 on: June 13, 2020, 02:18:55 am »
Yeah, I think they all do that.  Looks like you trail brake a lot.  I only got ~3k out of my OEM front.  They were triangular slicks with tread in the middle at 3k.
'00 748/853 "Rosetta"
Offline Christopher
« Reply #15 on: June 13, 2020, 08:57:08 am »
My OE tires did this as well. I left the suspension adj factory except I turned up preload a bit. I got about 5-6k out of them though. 2nd set were Angel's, didn't do it, 3rd set are RS'3 aren't doing it. Recently I had a suspension specialist adj my rebound and preload,  kinda futile as the springs are weak as s*** but whatever,  it's better than what it was. Currently at about 7k on RS's, the center is just starting to flatten out.
Offline Nickrides
  • Nickrides
  • Nickrides
« Reply #16 on: June 15, 2020, 10:20:20 pm »
Thats one UGLY looking tire
I personally wouldn't ride on that one
The Dunlop RS 2's are cheap these days and quite nice.
Nick
Offline AwesomeDad
« Reply #17 on: June 16, 2020, 02:25:30 am »
Nick
No I trailered it home and got new tires....
Offline ursharkfuel
  • God got one thing wrong: Stupid should be PAINFUL!
  • COG#: 13146
« Reply #18 on: June 19, 2020, 09:46:28 pm »
Nick
I replaced a Michelin front tire that looked just like it except the sides were nearly smooth. I hope the Conti Motion I just installed does not do that. This morning made 250 miles on it, and so far it has made my new to me Connie feel even better!  :great:
Enjoy the ride,
Jon
2011 Connie 14, 2008 KLR 650, 87 Kawasaki Ninja 1000, 82 Kawasaki GPZ 750, 87 Honda Hurricane 1000, 84 Yamaha FJ 1100, 76 Honda CB 750K, 73 Kawasaki KZ 900 Z1 based drag bike (not street legal), 82 Honda Aspencade 1100, 1 new and 2 used Harley mistakes, 76 Triumph Bonneville 750
Offline DUMB A$$
« Reply #19 on: June 27, 2020, 08:24:21 pm »
My Avon storms would do that and was told I like to hang the turns too much. GT pilot 5 on now and nothing so far.
DUMBA$$
Offline Stasch
  • COG#: 6830
« Reply #20 on: June 28, 2020, 11:28:14 am »
I've had tires do this in varying degrees of severity.
My opinion is that its due to the dual compound construction of sport touring tires along with the rounded profile of motorcycle tires.
Stan Visser - COG#: 6830
Offline PeteTN_zgtr
« Reply #21 on: June 29, 2020, 07:35:25 am »
I've thought this as well. Obviously varies by tire. Pilot power, RS-1, and Angel GT (non a-spec) fronts all did this to varying degrees for me with handling getting weird as they got more square. Last front I had was a Shinko 011 (single compound) that handled well and stayed alot rounder.  Trying a Angel ST front (also single compound) now but there going to get scarce so I'll probably go back to the 011 front. 011 rear got almost to 7k miles. Front still had about 1-2k left when I changed the set. Might try the 016 rear with 011 front. Frankly the matched Verge 011 set handled very well using 180-55 rear as there's no 190-55.
