Author Topic: Are the Ohlins ZX14 forks a direct swap?  (Read 20323 times)
Offline ZG
  • COG#: 9735
« on: May 09, 2012, 08:23:51 pm »
And if so are all years the same?
I'm thinking about a full Ohlins setup (forks and shock) but I see that Ohlins doesn't offer complete forks for the Concours 14, only the springs. Ohlins does offer complete forks for the ZX14 though...  >:D
« Last Edit: August 19, 2012, 03:18:27 am by ZG »
Re: Are ZX14 forks a direct swap?
« Reply #1 on: May 09, 2012, 08:46:20 pm »
I just did a comparison of the 2009 C14 ABS and 2009 ZX14 front fork assembly on the Ron Ayers Microfiche. The parts are almost identical. There are one of two bolts or washers that may be slightly different. But it looks like they would swap over. Although I would look closer at the parts that are different before buying, just in case they may make a differance that could be crucial.
Offline Rev Ryder
    • Presbychuck
  • COG#: 7235
« Reply #2 on: May 09, 2012, 08:51:33 pm »
In 2007, I put a "new take off" set of 2007 ZX14 forks onto my C-10.  SInce then, I have compared them to the C-14 forks and VUSUALLY could discern no difference other than the anodizing (color).  I did NOT measure them for length or the steering stop tabs, but they APPEARED to be the same in a casual inspection.  There... that's worth about nothing I reckon. LOL
Fortis non Ferox
 Shafties Can't Wheelie
Offline mcrider007
« Reply #3 on: May 09, 2012, 10:07:13 pm »
If your C14 has ABS then you better own (or have access) to a drill press.
Offline ZG
  • COG#: 9735
« Reply #4 on: May 09, 2012, 10:49:08 pm »
Yes, I have an 09 ABS. What would a drill press be needed for?  :017:
Offline mcrider007
« Reply #5 on: May 09, 2012, 11:29:24 pm »
Your ABS sensor doesn't work very well when its taped to the bottom of the forks.
Offline ZG
  • COG#: 9735
« Reply #6 on: May 09, 2012, 11:45:40 pm »
Ah yes, good point!  :-[
This is exactly why I asked you wise folks...
Offline Stewart
  • Aussie living in the USA
  • COG#: 9380
« Reply #7 on: May 09, 2012, 11:54:21 pm »
Your being kind when you say wise. And I'm not sure about folks either.
Stewart
2010 Concours14
COG 9380
Offline Rev Ryder
    • Presbychuck
  • COG#: 7235
« Reply #8 on: May 10, 2012, 01:11:56 am »
now just cuz I'm still trying to figure out what's wrong with tape don't mean ya gotta step him back here.   :)
Fortis non Ferox
Offline Sparkie
« Reply #9 on: May 10, 2012, 07:38:06 pm »
I'd be curious to here more about this. Did you use the ZX14 triple clamps also? How was the ride? Got pics? Mark  ;)
2006 Kawasaki Concours (Sold)
2006 Ducati 620 Multistrada
2016 Yamaha FJR 1300A
Offline ZG
  • COG#: 9735
Re: Are the Ohlins ZX14 forks a direct swap?
« Reply #10 on: May 10, 2012, 11:46:45 pm »
I just got an encouraging pm from Loren... More to come on this hopefully...  :popcorncouple:
His pm... (I hope you're cool with this bro, I know this will wet the appetite of others too...  ;D)
"Hi Jay,
I have a pair of Ohlins ZX14 forks being fitted out with the C14 Ohlins springs.  I hope to have them sometime late next week, if the shop has no problems with the spring change.
I'm keeping my fingers crossed that it will be a simple swap once the forks are
I already put an Ohlins on the rear, and liked the change, so the nexted step was the forks.
I will let you know how it works out.
Loren"
Offline Rev Ryder
    • Presbychuck
  • COG#: 7235
« Reply #11 on: May 11, 2012, 02:54:01 am »
Yes I did use the ZX14 Triples but adapted the ZG stem to the lower and used regular ZG stem bearings.  THe steering stop had to be cut a great deal and the upper triple had to be trimmed some.  Then, in order to have a speedo, I had to do some creative work and use a ZZR1200 front wheel, rotors, and speedo drive that I cut way down to fit.  Then, since the rotors were 320mm instead of 310 like the ZX and C-14 have, I had to space the rotary calipers out 5mm.
Handling is very firm and solid sportbike-ish.  The much shorter forks created and tremendous change in rake and weight bias, however, the steering stem offset helped all of this have a much less dramatic affect on trail so tip in is a little firmer than stock, but low speed handling (with wider bars) is enhanced as well as high speed stability due to a slightly increased overall trail.  Brake dive is 1/20th of what it was and there is zero flex and no need for a fork brace at all.  Remarkably, when other Connie riders ride it, they comment on the well planted rear and wonder what I've done there.  But only a fluid change to 15weight back there has been done.  Here's a pic from ten minutes after the install on 2007 and before painting the rest of the bike or even finishing the fitting of all the plastic to cover the turbocharger.  A lot has changed since then, but not with the forks (except they have endured two crashes and some skinning).
And to further jack this thread, click the link in my sig line to see how they deal with being pile driven landing from altitude on the ol fat lady.
« Last Edit: May 11, 2012, 03:05:10 am by Rev Ryder »
Fortis non Ferox
Offline Raymond
  • COG#: 8125
« Reply #12 on: May 11, 2012, 10:59:29 pm »
I don't know... A Traxxion AK-20 Cartridge kit seems a lot easier and probably provides the same performance increase. They made a night 'n day difference over the stock internals. I guess I'm getting a bit lazier nowadays...
The AK-20 cartridges and Penske shock made one hell of a difference...
RayK        COG# 8125  CDA# 0273  '08 ZG 1400
Offline dirt_biker
  • Best bike I've ever road.
  • The only way to ride and I Love it! (C14)
  • COG#: 9307
« Reply #13 on: May 11, 2012, 11:48:07 pm »
ZX14 forks will mount right on NON ABS C14, how ever if you would like to put them on the 08 - 12 with ABS you will need to drill 12mm hole and the 2 mounting hols and tap them, also the mounting area is not flat and needs to be ground down or milled down so it's flat, the spacing from the sensor and the rotor is .028 to .035, we used a drill press and mill bit. one of us was holding the fork level  the other carefully move the fork to trim off the excess.
on the 2010 we had to drill 12 mm from the back side and on the front side 18mm 1/2 way in. also the mounting area is not flat and needs to be ground down or milled down so it's flat,also the hole is larger and only needs 1 mounting hole and turned as the mounting hole is out a little further way from the sensor.
« Last Edit: May 29, 2012, 05:05:13 am by dirt_biker »
2015 C14,  Full AreaP, and 2" Risers, Garmin GPS, Rosta CC, PR3's, These are the other rides I have now. 76 KZ900, 98 KX500, 06 CR450R, 75 CR250M, 04 Vforce 700, 09 KFX450r
Offline ZG
  • COG#: 9735
« Reply #14 on: May 12, 2012, 12:37:13 am »
ZX14 forks will mount right on NON ABS C14, how ever if you would like to put them on the 08 or 09 you will need to drill 12mm hole and the 2 mounting hols and tap them, also the mounting area is not flat and needs to be ground down or milled down so it's flat, the spacing from the sensor and the rotor is .028 to .035, we used a drill press and mill bit. one of us was holding the fork level  the other carefully move the fork to trim off the excess.
Thanks for the pics and post DB, that is very helpfull!
Yes, I have an 09 ABS, looking at the pics you posted that is also an 09 ABS right? So is that your bike? What year ZX14 Ohlins forks are those that you mounted? Or are the Ohlins ZX14 forks non-year specific?
Any issues with the ABS not working as designed since you've done this mod?
Thanks bro!  :beerchug:
Offline dirt_biker
  • COG#: 9307
« Reply #15 on: May 12, 2012, 01:15:57 am »
Yes the 09 is mine Gold fork :) and 10 is my Friend's bike Silver forks, and the ZX14 forks are OEM. NOT Ohlins, we picked them up off E-Bay,  they made a big improvement ( very adjustable ) 8) better all the way round.
« Last Edit: May 12, 2012, 01:21:16 am by dirt_biker »
Offline ZG
  • COG#: 9735
« Reply #16 on: May 12, 2012, 02:31:44 am »
Got it, thanks DB.
So did you use the Connie triple clamps? Did the ZX14 forks stick up out of the upper tripple clamp further than the oem Connie forks?
Offline Rev Ryder
    • Presbychuck
  • COG#: 7235
« Reply #17 on: May 12, 2012, 02:34:17 am »
Nicely done Dirt Biker.  How were the spring rates on the ZX forks?  DId you need to change them?
Fortis non Ferox
Offline dirt_biker
  • COG#: 9307
« Reply #18 on: May 12, 2012, 11:37:15 am »
We used the C14 triple clamps and added 7mm spacer rings to the top of the springs to keep the ride height the same as the c14 and still have the top  adjusters in the stock setting. as for the springs the zx14 springs are .90 and c14 are 1.2, the ride is more supple and ride can be tuned for stiffer compression and rebound  :beerchug: ;)
Offline rcannon409
  • COG#: 9616
« Reply #19 on: May 12, 2012, 12:25:36 pm »
Nice project Dirtbiker!  A question on the machining needed for the abs sensor.  That machining needed is way out of my garage-level abilities. Do you think it would be a big deal for a machine shop to deal with?  Assuming  a person coudl get this done locally, the project would nto even cost that much.
Offline dirt_biker
  • COG#: 9307
« Reply #20 on: May 12, 2012, 10:02:44 pm »
We did it in the garage with a drill press, if you take it to a shop to have it done take the old forks so they can compare so they get it right >:D
« Last Edit: May 12, 2012, 10:07:47 pm by dirt_biker »
Offline Loren
    • Baldwin Motorbike Saddles
  • COG#: 9775
« Reply #21 on: May 20, 2012, 10:51:50 pm »
Install was easy breazy.  The fork is already prepped for the ABS sensor direct from Ohlins, although mine is a non-ABS model.  Many thanks to Dan Kyle at Kyle Racing www.kyleusa.com for being so willing to make the spring swap work.
« Last Edit: May 20, 2012, 10:58:54 pm by Loren »
Loren
www.MotorbikeSaddles.com
Offline ZG
  • COG#: 9735
« Reply #22 on: May 21, 2012, 01:29:19 am »
OMG Loren man that is sweet! I must have now!!!
So did you do the Ohlins C14 spring kit?
I've been talking to Gary Christopher at Ohlins over the past couple weeks, Ohlins is coming out with a full cartridge kit for the C14 in the next month or so for $599...
I've been talking to him about putting this cartridge kit in the ZX14 Ohlins forks, we were just waiting until your install regarding the ABS sensor mount...
So what I'm hearing from you then is the Ohlins ZX14 forks come standard with the ABS mount right??
Can you please post up some more pics how those gorgeous gold Ohlins forks look on your Connie bro...  :)
Oh, and by the way, nice TB fork sliders bro, I have em too...  8)
« Last Edit: May 21, 2012, 01:44:49 am by ZG »
Offline Loren
  • COG#: 9775
« Reply #23 on: May 21, 2012, 02:02:03 am »
These are the forks used.  http://www.ohlins.com/Our-products-new/Motorcycle/Products/Touring/FGRT-807/
They came with the ABS sensor mount machining already done.  I did not request it, since my bike does not have ABS.  They have been fitted with the Ohlins C14 springs.  http://www.ohlins.com/Our-products-new/Motorcycle/Products/Sport/08769-13/
I've been talking to him about putting this cartridge kit in the ZX14 Ohlins forks...
Why would they be fitting out the Ohlins ZX14 forks with a Ohlins C14 cartridge kit?  I believe their C14 cartridge kit would be to retrofit OEM C14 forks.  Is that not correct?
Loren
Offline ZG
  • COG#: 9735
« Reply #24 on: May 21, 2012, 02:19:41 am »
Sorry, maybe I'm misspeaking or just flat out confused, I'm not a wrencher by any means...
So I should just have them put the Ohlins C14 spring kit in the ZX14 Ohlins forks??
